Hallo Freunde,
Ich versuche gerade meine RTC zu stellen und den gestellten Wert aus der
RTC wieder aus zu lesen... Leider klappt das nicht...
Wo mache ich was falsch?! Hat jemand vill. eine Library für diese Uhr ?
#include <avr/io.h>
#include "i2cmaster.h"
#define Dev24C02 0xA2
int main(void)
unsigned char ret;
DDRB = 0xff; // use all pins on port B
for output
PORTB = 0xff; // (active low LED's )
i2c_init(); // init I2C interface
ret = i2c_start(RX8564+I2C_WRITE); // set device address and write
mode
if ( ret ) {
i2c_stop();
}else {
i2c_write(0x05);
i2c_write(0x75);
i2c_stop();
/* write ok, read value back from eeprom address 0x05, wait
until
the device is no longer busy from the previous write
operation */
i2c_start_wait(RX8564+I2C_WRITE); // set device address and
write mode
i2c_write(0x05); // write address = 5
i2c_rep_start(RX8564+I2C_READ); // set device address and
read mode
ret = i2c_readNak(); // read one byte
i2c_stop();
