Hallo, ich habe vor dieses -> http://flosserver.dyndns.org/Sternenhimmel.php Projekt nachzubauen, dazu habe ich mir das Programm von den Jungs schicken lassen. Wenn ich es im AVR Studio builden möchte kommt immer folgene Fehlermeldungen. ../irmp.c:830:31: error: variable 'nec_param' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../irmp.c:851:31: error: variable 'nec_rep_param' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../irmp.c:876:31: error: variable 'samsung_param' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../irmp.c:901:31: error: variable 'matsushita_param' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../irmp.c:926:31: error: variable 'kaseikyo_param' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../irmp.c:976:31: error: variable 'rc5_param' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../irmp.c:1001:31: error: variable 'denon_param' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../irmp.c:1026:31: error: variable 'rc6_param' must be const in order to be put into read-only section by means of '__attribute__((progmem))' ../irmp.c:1126:31: error: variable 'grundig_param' must be const in order to be put into read-only section by means of '__attribute__((progmem))' Darauf hin hab ich ihn angeschrieben. Leider weis er auch nix genaueres über diese Fehlermeldung. Kann mit von euch evtl. jemand sagen was das Problem sein könnte? lg E.T.
1 | On AVR, variables with the progmem attribute to locate data |
2 | in flash memory must be qualified as const. |
http://gcc.gnu.org/gcc-4.6/changes.html Ergo: Entsprechende Daten müssen const sein.
Oder kompilier das ganze mit WinAVR. Da steckt noch ein älterer Compiler drin, der das ohne const verdaut. Oliver
Danke für eure Hilfe, hat prima geklappt. Auch wenn das Programm leider nicht so ganz passt. Die LED's blinken nur im einheitlichen Takt. :-( Vielleicht sieht ja jemand von euch was auf die schnelle, wenn nicht muss ich mal sehen wie ich es hinbekomme. ***lg E.T.***
