1 | /* ########################################################################## */
2 | /* include */
3 |
4 | #include "ATmega164PA_BtLdr.h"
5 | #include "Bootloader.h"
6 |
7 |
8 | /* ########################################################################## */
9 | /* code constants */
10 |
11 |
12 | /* ########################################################################## */
13 | /* variables */
14 |
15 | u16_t ihex_line_dest_addr = 0;
16 | u8_t ihex_line_dat_len = 0;
17 | u8_t ihex_line_dat_type = 0;
18 | u8_t ihex_line_dat_buf[32];
19 |
20 | u16_t flash_page_num = 0;
21 | u16_t flash_page_addr = 0;
22 | u16_t flash_cnt = 0;
23 |
24 | u8_t SPM_timer = 0;
25 |
26 | /* ########################################################################## */
27 | /* local functions: */
28 |
29 |
30 | /* ########################################################################## */
31 | /* global functions */
32 |
33 | /* +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ */
34 | /* bootloader control */
35 | void bootload_ctl(void)
36 | {
37 | u8_t parser_ret;
38 | u8_t write_ret;
39 |
40 | /* check line from hex file */
41 | parser_ret = ihex_line_parser();
42 |
43 | if( parser_ret == IHEX_LINE_OKAY )
44 | {
45 | /* write to flash */
46 | write_ret = ihex2flash(IHEX_RECTYP_DATA);
47 |
48 | TX1_byte(write_ret);
49 | }
50 | else if( parser_ret == IHEX_LINE_EOF )
51 | {
52 | /* write last data, fill rest with 0xFF */
53 | write_ret = ihex2flash(IHEX_LINE_EOF);
54 | /* send message we're done */
55 | TX1_byte(write_ret);
56 | }
57 | else TX1_byte(parser_ret);
58 |
59 | /* reset RX1 stuff */
60 | mem_set(RX1_buffer, 0x00, (u16_t)sizeof(RX1_buffer));
61 | RX1_timer = UART1_TIMEOUT_MAX;
62 | RX1_ihex_avl = 0;
63 | }
64 |
65 |
66 | /* check received line, length, CRC, data type - no ASCII !!! */
67 | u8_t ihex_line_parser(void)
68 | {
69 | u8_t i;
70 | u16_t crc_sum = 0;
71 |
72 | /* check start code and length */
73 | if( RX1_buffer[0] != ':' || RX1_counter < IHEX_LINE_OVERHEAD_BIN ) return IHEX_ERROR_STRT_LEN;
74 |
75 | /* get data length in line */
76 | ihex_line_dat_len = RX1_buffer[1];
77 |
78 | /* get flash address */
79 | ihex_line_dest_addr = (u16_t)RX1_buffer[2] << 8;
80 | ihex_line_dest_addr += (u16_t)RX1_buffer[3];
81 |
82 | /* get data type */
83 | ihex_line_dat_type = RX1_buffer[4];
84 |
85 | /* CRC check, add all execept ':', incl CRC byte, lower byte sum must be 0 */
86 | for( i = 1; i < RX1_counter; i++ ) crc_sum += (u16_t)RX1_buffer[i];
87 | crc_sum &= 0x00FF;
88 | if( crc_sum != 0 ) return IHEX_ERROR_CRC;
89 |
90 | /* get data and copy to buffer */
91 | if( ihex_line_dat_type == IHEX_RECTYP_DATA && ihex_line_dat_len != 0 )
92 | {
93 | for( i = 0; i < ihex_line_dat_len; i++ )
94 | {
95 | ihex_line_dat_buf[i] = RX1_buffer[i + 5];
96 | }
97 | }
98 | /* extended address for > 64kB? */
99 | else if( ihex_line_dat_type == IHEX_RECTYP_XSADR )
100 | {
101 | /* for now just return error code */
102 | return IHEX_ERROR_EXTADDR;
103 | }
104 | /* EOF? */
105 | else if( ihex_line_dat_type == IHEX_RECTYP_EOF &&
106 | RX1_counter == IHEX_LINE_OVERHEAD_BIN )
107 | {
108 | return IHEX_LINE_EOF;
109 | }
110 | else return IHEX_FLASH_FT_ERROR;
111 |
112 | return IHEX_LINE_OKAY;
113 | }
114 |
115 |
116 | /* write line from hex file to flash page buffer */
117 | u8_t ihex2flash(u8_t dat_type)
118 | {
119 | u8_t ret_val;
120 | u8_t i;
121 | u16_t page_addr_b;
122 |
123 | /* - writing flash page by page
124 | * - a complete page must be written
125 | * - data must be collected until page is full
126 | *
127 | * 1) fill page buffer
128 | * 2) erase page
129 | * 3) write page
130 | *
131 | */
132 |
133 | /* end of hex file, write current page buffer to flash */
134 | if( dat_type == IHEX_LINE_EOF )
135 | {
136 | if( flash_cnt != 0 )
137 | {
138 | eeprom_busy_wait();
139 |
140 | /* erase page */
141 | // SPM_processing((void flash *)flash_page_num, SPM_CMND_ERASE_PAGE);
142 | // SPM_processing(flash_page_num, SPM_CMND_ERASE_PAGE);
143 | // boot_spm_busy_wait();
144 |
145 | /* write page */
146 | SPM_processing((void flash *)flash_page_num, SPM_CMND_WRITE_PAGE);
147 | if( boot_spm_busy_wait() ) ret_val = IHEX_FLASH_EOF_TO;
148 | SPM_R0_to_SPM(0, SPM_CMND_ENABLE_RWW);
149 |
150 | /* reset stuff */
151 | flash_page_num = 0;
152 | flash_cnt = 0;
153 | flash_page_addr = 0;
154 | }
155 | ret_val = IHEX_FLASH_WR_END;
156 | }
157 | /* copy data from new line to page buffer, erase & write page */
158 | else
159 | {
160 | for( i = 0; i < ihex_line_dat_len; i += 2 )
161 | {
162 | flash_page_addr = flash_page_num + flash_cnt;
163 | page_addr_b = flash_page_addr;// << 1;
164 |
165 | SPM_fill_page_buffer((void flash *)page_addr_b, ihex_line_dat_buf[i+1], ihex_line_dat_buf[i], SPM_CMND_FILL_PAGE_BUF);
166 | /* hängt hier nach erstem page write */
167 | LED2_GREEN;
168 | if( boot_spm_busy_wait() ) ret_val = IHEX_FLASH_FILL_TO;
169 | LED2_OFF;
170 |
171 | flash_cnt += 2;
172 |
173 | /* page buffer full => erase page => write page! */
174 | if( flash_cnt == SPM_PAGE_SIZE )
175 | {
176 | eeprom_busy_wait();
177 |
178 | /* erase page */
179 | // SPM_processing((void flash *)flash_page_num, SPM_CMND_ERASE_PAGE);
180 | // SPM_processing(flash_page_num, SPM_CMND_ERASE_PAGE);
181 | // boot_spm_busy_wait();
182 |
183 | /* write page */
184 | SPM_processing((void flash *)flash_page_num, SPM_CMND_WRITE_PAGE);
185 | LED2_RED;
186 | /* hier hängt's nach 1. page write! */
187 | if( boot_spm_busy_wait() ) ret_val = IHEX_FLASH_WR_TO;
188 | LED2_OFF;
189 | SPM_R0_to_SPM(0, SPM_CMND_ENABLE_RWW);
190 |
191 | /* new page */
192 | page_addr_b = flash_page_num;
193 | flash_page_num = ihex_line_dest_addr - (ihex_line_dest_addr % SPM_PAGE_SIZE);
194 | if( flash_page_num == page_addr_b ) flash_page_num += SPM_PAGE_SIZE;
195 | flash_cnt = 0;
196 | }
197 | }
198 | ret_val = IHEX_FLASH_LINE_WR;
199 | }
200 |
201 | LED2_OFF;
202 |
203 | return ret_val;
204 | }
205 |
206 |
207 | #pragma warn-
208 | /* call: SPM_fill_page_buffer((void flash *)addr, ... */
209 | /* fill buffer */
210 | void SPM_fill_page_buffer(void flash *addr, u8_t dat_hi, u8_t dat_lo, u8_t cmnd)
211 | {
212 | #asm
213 | cli
214 | ldd r30,y+3
215 | ldd r31,y+4
216 | ldd r0,y+1
217 | ldd r1,y+2
218 | ld r22,y
219 | WR_SPMCR_REG_R22
220 | spm
221 | sei
222 | #endasm
223 | }
224 |
225 |
226 | /* call: SPM_processing((void flash *)addr, ... */
227 | /* erase page (cmnd = 0x03) / write buffer to page (cmnd = 0x05) */
228 | void SPM_processing(void flash *addr, u8_t cmnd)
229 | {
230 | #asm
231 | cli
232 | ldd r30,y+1
233 | ldd r31,y+2
234 | ld r22,y
235 | WR_SPMCR_REG_R22
236 | spm
237 | sei
238 | #endasm
239 | }
240 |
241 |
242 | /* ??? */
243 | void SPM_R0_to_SPM(u8_t data, u8_t cmnd)
244 | {
245 | #asm
246 | cli
247 | ldd r0,y+1
248 | ld r22,y
249 | WR_SPMCR_REG_R22
250 | spm
251 | sei
252 | #endasm
253 | }
254 | #pragma warn+
255 |
256 |
257 | /* read flash */
258 | void SPM_read_flash(u16_t addr, u16_t len)
259 | {
260 | u8_t byte;
261 |
262 | do
263 | {
264 | #if(0)
265 | /* ASCII, takes too much prog space */
266 | if( (len % 16) == 0 ) TX1_byte('\n');
267 | TX1_byte('0');
268 | TX1_byte('x');
269 | byte = (u8_t)*((u8_t flash *)addr);
270 | TX1_byte(hex_char[(byte & 0xF0) >> 4]);
271 | TX1_byte(hex_char[ byte & 0x0F]);
272 | TX1_byte(' ');
273 | #endif
274 |
275 | byte = (u8_t)*((u8_t flash *)addr);
276 | TX1_byte(byte);
277 | addr++;
278 | len--;
279 | } while( len );
280 | }
281 |
282 |
283 | u8_t boot_spm_busy_wait(void)
284 | {
285 | LED1_RED;
286 | SPM_timer = 10; /* *100 ms */
287 | while( SPMCSR )//& (1<<SPMEN) )
288 | {
289 | if( SPM_timer == 0 ) return 1;
290 | };
291 | LED1_GREEN;
292 | return 0;
293 | }
294 |
295 |
296 | void eeprom_busy_wait(void)
297 | {
298 | while( EECR & (u8_t)(1<<EEPE) );
299 | }
300 |
301 |
302 | void mem_set(u8_t *buf, u8_t val, u16_t len)
303 | {
304 | u16_t i = 0;
305 |
306 | for( i = 0; i < len; i++ ) buf[i] = val;
307 | }
