how to solve this multiple linux timer with single signal handler
OP (Firma: Student) #3552830
/*The handler checks that the value stored in sival_ptr matches a given
timerID variable. The sival_ptr is the same as the one we set in
makeTimer(), though here it lives in a different structure. Obviously,
it got copied from there to here on the way to this signal handler. The
point is that the timerID is what is used to determine which timer just
went off and determine what to do next */
static void timerHandler( int sig, siginfo_t *si, void *uc )
    timer_t *tidp;
    tidp = si->si_value.sival_ptr;
    if ( *tidp == firstTimerID )
        TASK1(Task2ms_Raster);
   else if ( *tidp == secondTimerID )
       TASK2(Task10ms_Raster);
    else if ( *tidp == thirdTimerID )
        TASK3(Task100ms_Raster);
/* The function takes a pointer to a timer_t variable that will be
filled with the timer ID created by timer_create(). This pointer is also
saved in the sival_ptr variable right before calling timer_create(). In
this function notice that we always use the SIGRTMIN signal, so
expiration of any timer causes this signal to be raised. The signal
handler I've written for that signal is timerHandler. */
 static int makeTimer( char *name, timer_t *timerID, int expireMS, int
intervalMS )
     //sigset_t mask;
    struct sigevent         te;
    struct itimerspec       its;
    struct sigaction        sa;
    int                     sigNo = SIGRTMIN;
    /* Set up signal handler. */
    sa.sa_flags = SA_SIGINFO;
    sa.sa_sigaction = timerHandler;
    sigemptyset(&sa.sa_mask);
    if (sigaction(sigNo, &sa, NULL) == -1)
        perror("sigaction");
    /* Set and enable alarm */
    te.sigev_notify = SIGEV_SIGNAL;
    te.sigev_signo = sigNo;
    te.sigev_value.sival_ptr = timerID;
    timer_create(CLOCK_REALTIME, &te, timerID);
    its.it_interval.tv_sec = 0;
    its.it_interval.tv_nsec = intervalMS * 1000000;
    its.it_value.tv_sec = 0;
    its.it_value.tv_nsec = expireMS * 1000000;
    timer_settime(*timerID, 0, &its, NULL);
    return 1;
int main()
     makeTimer("First Timer", &firstTimerID, 2, 2);   //2ms
   makeTimer("Second Timer", &secondTimerID, 10, 10);    //10ms
   makeTimer("Third Timer", &thirdTimerID, 100, 100);  //100ms
I am using single handler to call the task for every 2ms, 10ms and
100ms. I am using multiple timers with single signal handler. How to
identify which timer just went. In debug mode : the last debug control
session is : static void timerHandler( int sig, siginfo_t *si, void *uc
){ . Could anyone help me how to solve this ?  you will get more info
here : http://www.graphics-muse.org/wp/?p=868
