Unerklärlicher Type error mit std_logic_vector
Gast #3580679
Hallo habe hier für mich eine unklare Fehlerreihe.
# ** Error: ../../../grpPwmGen/unitPwmGenCtrlpath/src/PwmGenCtrlpath-Beh-a.vhd(27): Type error resolving infix expression "=" as type ieee.std_logic_1164.STD_ULOGIC_VECTOR.
# ** Error: ../../../grpPwmGen/unitPwmGenCtrlpath/src/PwmGenCtrlpath-Beh-a.vhd(27): Choice in selected signal assignment must be locally static.
# ** Error: ../../../grpPwmGen/unitPwmGenCtrlpath/src/PwmGenCtrlpath-Beh-a.vhd(28): Type error resolving infix expression "=" as type ieee.std_logic_1164.STD_ULOGIC_VECTOR.
# ** Error: ../../../grpPwmGen/unitPwmGenCtrlpath/src/PwmGenCtrlpath-Beh-a.vhd(28): Choice in selected signal assignment must be locally static.
# ** Error: ../../../grpPwmGen/unitPwmGenCtrlpath/src/PwmGenCtrlpath-Beh-a.vhd(31): Type error resolving infix expression "=" as type ieee.std_logic_1164.STD_ULOGIC_VECTOR.
# ** Error: ../../../grpPwmGen/unitPwmGenCtrlpath/src/PwmGenCtrlpath-Beh-a.vhd(31): Choice in selected signal assignment must be locally static.
# ** Error: ../../../grpPwmGen/unitPwmGenCtrlpath/src/PwmGenCtrlpath-Beh-a.vhd(32): Type error resolving infix expression "=" as type ieee.std_logic_1164.STD_ULOGIC_VECTOR.
# ** Error: ../../../grpPwmGen/unitPwmGenCtrlpath/src/PwmGenCtrlpath-Beh-a.vhd(32): Choice in selected signal assignment must be locally static.
# ** Warning: ../../../grpPwmGen/unitPwmGenCtrlpath/src/PwmGenCtrlpath-Beh-a.vhd(27): (vcom-1322) Selected waveforms choice cannot be checked for array length.
# ** Warning: ../../../grpPwmGen/unitPwmGenCtrlpath/src/PwmGenCtrlpath-Beh-a.vhd(28): (vcom-1322) Selected waveforms choice cannot be checked for array length.
hier wäre ein auszug von der entity und vom architecutre:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use work.Global.all;
use work.PwmGenPack.all;
entity PwmGenCtrlpath is
  port(
    iClk                : in  std_ulogic;
    inRstAsync          : in  std_ulogic;
    -- inputs
    iRisingKeyEdge      : in  std_ulogic_vector(3 downto 0);
    -- WaveGen
    oSelLevel           : out natural range 0 to 2; -- reload/dec/inc
    oSelLevelA          : out natural range 0 to 2; -- reload/dec/inc
    oSelLevelB          : out natural range 0 to 2; -- reload/dec/inc
    oLevelA             : out unsigned(cCounterWidth - 1 downto 0);
    oLevelB             : out unsigned(cCounterWidth - 1 downto 0);
    iLevelLessADetected : in  std_ulogic;
    iLevelLessBDetected : in  std_ulogic;
    -- pwm signal
23
    oPwmSig             : out std_ulogic
24
25
end PwmGenCtrlpath;
---------------------------------------------------------------------*-vhdl-*--
-- File        : PwmGenCtrlpath-Beh-a.vhd
-- Description : <short overview about functionality>
-- History (yyyy-mm-dd):
-- yyyy-mm-dd last update by firstname lastname
architecture Beh of PwmGenCtrlpath is
begin                                   -- Beh
  -- Insert your code here
  -- dummy assignments FIXME
  --oPwmSig   <= '1' when (iLevelLessADetected = '1')
  -- else '0';
  oPwmSig  <= '1' when (iLevelLessADetected = '1') else '0';
23
  oSelLevel  <= 0 when (iLevelLessBDetected = '0') else 2; --bei 0 wird iDin genommen und iDin bekommt Zero also RegLevel wird zurückgesetzt
24
  --oLevelA  <= "00011110" when (iRisingKeyEdge(0) = '1') else cDefaultLevelA; --30
25
  --oLevelB  <= "10111110" when (iRisingKeyEdge(0) = '1') else cDefaultLevelB; --190
26
  SelektorLevelA : with iRisingKeyEdge select oSelLevelA <= --Selektor mit der der korrekte Wert für die LevelRegister übernommen wird
27
    1 when (iRisingKeyEdge(0) = '1'),
28
    2 when (iRisingKeyEdge(1) = '1'),
29
    0 when others;
30
  SelektorLevelB : with iRisingKeyEdge select oSelLevelB <=
31
    1 when (iRisingKeyEdge(2) = '1'),
32
    2 when (iRisingKeyEdge(3) = '1'),
33
    0 when others;
34
35
end architecture Beh;
ist die Syntax vom with Select falsch oder darf man beim with kein array
benutzen?
Für Hilfe wäre ich sehr dankbar!
#3580724
Ich habe das with-select-when zwar noch nie verwendet, würde aber sagen,
dass das beim when im wesentlichen eine Konstante sein muss. Also kein
() oder =, passt ja auch nicht zur ganzen Idee des with-Ausdrucks. Das
Stichwort in der Fehlermeldung ist da "locally static". VHDL hat da zwei
Varianten (globally static, locally static, etc.).
http://www.eda.org/comp.lang.vhdl/FAQ1.html#static
Für deinen Anwendungszweck reicht doch auch ein ganz altmodisches
when-else.
