1 | /*
2 | * LCDTEST5.asm
3 | *
4 | * Created: 20.04.2014 16:14:50
5 | * Author: Fritz
6 | */
7 | ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
8 | ;;Steureung eines LCD
9 | ;;
10 | ;;PortD ausgang:
11 | ;;0 - Db0
12 | ;;1 - Db1
13 | ;;2 - Db2
14 | ;;3 - Db3
15 | ;;4 - Db4
16 | ;;5 - Db5
17 | ;;6 - Db6
18 | ;;7 - Db7
19 | ;;
20 | ;;PortB ausgang:
21 | ;;0 - RS
22 | ;;1 - E
23 | ;;2 - Kontroll LED1
24 | ;;3 - Leer
25 | ;;4 - Leer
26 | ;;5 - Leer
27 | ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
28 |
29 |
30 | ;;;;;;;;;;;;AVRinit;;;;;;;;;;;;
31 | .include "m8adef.inc"
32 |
33 |
34 |
35 | ;Reset and Interrupt vector ;VNr. Beschreibung
36 | rjmp main ;1 POWER ON RESET
37 | reti ;2 Int0-Interrupt
38 | reti ;3 Int1-Interrupt
39 | reti ;4 TC2 Compare Match
40 | reti ;5 TC2 Overflow
41 | reti ;6 TC1 Capture
42 | reti ;7 TC1 Compare Match A
43 | reti ;8 TC1 Compare Match B
44 | reti ;9 TC1 Overflow
45 | reti ;10 TC0 Overflow
46 | reti ;11 SPI, STC Serial Transfer Complete
47 | reti ;12 UART Rx Complete
48 | reti ;13 UART Data Register Empty
49 | reti ;14 UART Tx Complete
50 | reti ;15 ADC Conversion Complete
51 | reti ;16 EEPROM Ready
52 | reti ;17 Analog Comparator
53 | reti ;18 TWI (I²C) Serial Interface
54 | reti ;19 Store Program Memory Ready
55 | ;------------------------------------------------------------------------
56 |
57 | main:
58 |
59 | ldi r16, LOW(RAMEND) ;Stackinit
60 | out SPL, r16
61 | ldi r16, HIGH(RAMEND)
62 | out SPH, r16
63 |
64 | ldi r16,0b00000101
65 | out DDRC,r16
66 | out PORTC,r16
67 | .def temp = r16
68 | .def temp2 = r20
69 | .def temp3 = r21
70 | .def DHTmaske = r22
71 | .equ LCD_PORT = PORTD
72 | .equ LCD_DDR = DDRD
73 | .equ LCDS_PORT = PORTD
74 | .equ LCDS_DDR = DDRD
75 | .equ LCD_RS = 1
76 | .equ LCD_RW = 2
77 | .equ LCD_E = 3
78 | .equ RH_H =0x0060
79 | .equ RH_2 =0x0065
80 | ;.equ RH_L =0x0061
81 | ;.equ Temp_H =0x0062
82 | ;.equ Temp_L =0x0063
83 | ;.equ checksumme =0x0064
84 | .equ sensor1 =0x45
85 | .equ sensor2 =0x19
86 |
87 |
88 | .def arg = r17 ;argument for calling subroutines
89 | .def arg2 = r18 ;argument for mathematics
90 | .def return = r19 ;return value from subroutines
91 | .def byte = r25
92 |
93 |
94 | ;;;;;;LCDinit;;;;;;
95 |
96 | ;wartezeit zur initialisirung des
97 | ldi temp,200
98 | rcall waitMs
99 | rcall LCD_init
100 |
101 |
102 | ldi ZL,LOW(text*2)
103 | ldi ZH,HIGH(text*2)
104 | ldi arg,0x00
105 | rcall LCD4ZTxt
106 |
107 | ldi YH,HIGH(RH_2)
108 | ldi YL,LOW(RH_2)
109 | ldi DHTmaske,0x01
110 | ldi arg,0x46
111 | rcall LCD_pos
112 | rcall DHT_lesen
113 |
114 | rcall wait2s
115 |
116 | ldi DHTmaske,0x04
117 | ; out DDRC,DHTmaske
118 | ; out PORTC,DHTmaske
119 | ldi YH,HIGH(RH_H)
120 | ldi YL,LOW(RH_H)
121 |
122 | ldi arg,0x1a
123 | rcall LCD_pos
124 | rcall DHT_lesen
125 |
126 |
127 |
128 |
129 | ; ldi temp,1
130 | ; rcall waitMs
131 |
132 |
133 |
134 | ; mov arg,byte
135 | ; rcall LCD_number
136 | ; ldi arg,0x40
137 | ; rcall LCD_pos
138 | ; mov arg,byte
139 | ; rcall LCD_alsBit
140 | ; ldi arg,0x14
141 | ; rcall LCD_pos
142 | ; ldi arg,0x43
143 | ; rcall LCD_alsBit
144 |
145 | ; rcall DHT_lesen
146 |
147 |
148 | ;;;;;;Main;;;;;;
149 | ;durch diese Routine
150 |
151 | Auto: ;takt das nächste zeichen auf dem display
152 |
153 | ;rcall LCD_clear ;zu sehen sein
154 |
155 | ;inc LCDtoSend
156 | wdr
157 |
158 |
159 | rjmp Auto
160 |
161 |
162 |
163 | ;;;;;;Routinen;;;;;;
164 |
165 |
166 | ;***********************************************************************************
167 | ; the following source is from AVRbeginners.net .great work- well documented
168 | ; the advantage of read the busyflag in 4-bit mode is, no delay's needed
169 | ;***********************************************************************************
170 | LCD_command8: ;used for init (we need some 8-bit commands to switch to 4-bit mode!)
171 | in temp, LCD_DDR ;we need to set the high nibble of DDRD while leaving
172 | ;the other bits untouched. Using temp for that.
173 | sbr temp, 0b11110000 ;set high nibble in temp
174 | out LCD_DDR, temp ;write value to DDRD again
175 | in temp, LCD_PORT ;then get the port value
176 | cbr temp, 0b11110000 ;and clear the data bits
177 | cbr arg, 0b00001111 ;then clear the low nibble of the arg
178 | ;so that no control line bits are overwritten
179 | or temp, arg ;then set the data bits (from the arg) in the
180 | ;Port value
181 | out LCD_PORT, temp ;and write the port value.
182 | sbi LCDS_PORT, LCD_E ;now strobe E
183 | nop
184 | nop
185 | nop
186 | cbi LCDS_PORT, LCD_E
187 | in temp, LCD_DDR ;get DDRD to make the data lines input again
188 | cbr temp, 0b11110000 ;clear data line direction bits
189 | out LCD_DDR, temp ;and write to DDRD
190 | ret
191 |
192 | LCD_putchar:
193 | push arg ;save the argmuent (it's destroyed in between)
194 | in temp, LCD_DDR ;get data direction bits
195 | sbr temp, 0b11110000 ;set the data lines to output
196 | out LCD_DDR, temp ;write value to DDRD
197 | in temp, LCD_PORT ;then get the data from PortD
198 |
199 | ;.if LCDS_DDR == LCD_DDR ;if the same port
200 |
201 | cbr temp, 0b11111110 ;clear ALL LCD lines (data and control!)
202 | ;.else
203 | ; cbr temp, 0b11110000
204 | ;.endif
205 | ;cbr temp, 0b11111110 ;clear ALL LCD lines (data and control!)
206 |
207 | cbr arg, 0b00001111 ;we have to write the high nibble of our arg first
208 | ;so mask off the low nibble
209 | or temp, arg ;now set the arg bits in the Port value
210 | out LCD_PORT, temp ;and write the port value
211 | sbi LCDS_PORT, LCD_RS ;now take RS high for LCD char data register access
212 | sbi LCDS_PORT, LCD_E ;strobe Enable
213 | nop
214 | nop
215 | nop
216 | cbi LCDS_PORT, LCD_E
217 | pop arg ;restore the arg, we need the low nibble now...
218 | cbr temp, 0b11110000 ;clear the data bits of our port value
219 | swap arg ;we want to write the LOW nibble of the argument to
220 | ;the LCD data lines, which are the HIGH port nibble!
221 | cbr arg, 0b00001111 ;clear unused bits in argument
222 | or temp, arg ;and set the required argument bits in the port value
223 | out LCD_PORT, temp ;write data to port
224 | sbi LCDS_PORT, LCD_RS ;again, set RS
225 | sbi LCDS_PORT, LCD_E ;strobe Enable
226 | nop
227 | nop
228 | nop
229 | cbi LCDS_PORT, LCD_E
230 | cbi LCDS_PORT, LCD_RS
231 | in temp, LCD_DDR
232 | cbr temp, 0b11110000 ;data lines are input again
233 | out LCD_DDR, temp
234 | ret
235 |
236 | LCD_command: ;same as LCD_putchar, but with RS low!
237 | push arg
238 | in temp, LCD_DDR
239 | sbr temp, 0b11110000
240 | out LCD_DDR, temp
241 | in temp, LCD_PORT
242 | ;cbr temp, 0b11111110
243 | ;.if LCDS_DDR == LCD_DDR ;if the same port then
244 | cbr temp, 0b11111110 ;clear ALL LCD lines (data and control!)
245 | ;.else
246 | ; cbr temp, 0b11110000
247 | ;.endif
248 | cbr arg, 0b00001111
249 | or temp, arg
250 |
251 | out LCD_PORT, temp
252 | sbi LCDS_PORT, LCD_E
253 | nop
254 | nop
255 | nop
256 | cbi LCDS_PORT, LCD_E
257 | pop arg
258 | cbr temp, 0b11110000
259 | swap arg
260 | cbr arg, 0b00001111
261 | or temp, arg
262 | out LCD_PORT, temp
263 | sbi LCDS_PORT, LCD_E
264 | nop
265 | nop
266 | nop
267 | cbi LCDS_PORT, LCD_E
268 | in temp, LCD_DDR
269 | cbr temp, 0b11110000
270 | out LCD_DDR, temp
271 | ret
272 |
273 | LCD_getchar:
274 | in temp, LCD_DDR ;make sure the data lines are inputs
275 | andi temp, 0b00001111 ;so clear their DDR bits
276 | out LCD_DDR, temp
277 | sbi LCDS_PORT, LCD_RS ;we want to access the char data register, so RS high
278 | sbi LCDS_PORT, LCD_RW ;we also want to read from the LCD -> RW high
279 | sbi LCDS_PORT, LCD_E ;while E is high
280 | nop
281 | in temp, PinD ;we need to fetch the HIGH nibble
282 | andi temp, 0b11110000 ;mask off the control line data
283 | mov return, temp ;and copy the HIGH nibble to return
284 | cbi LCDS_PORT, LCD_E ;now take E low again
285 | nop ;wait a bit before strobing E again
286 | nop
287 | sbi LCDS_PORT, LCD_E ;same as above, now we're reading the low nibble
288 | nop
289 | in temp, PinD ;get the data
290 | andi temp, 0b11110000 ;and again mask off the control line bits
291 | swap temp ;temp HIGH nibble contains data LOW nibble! so swap
292 | or return, temp ;and combine with previously read high nibble
293 | cbi LCDS_PORT, LCD_E ;take all control lines low again
294 | cbi LCDS_PORT, LCD_RS
295 | cbi LCDS_PORT, LCD_RW
296 | ret ;the character read from the LCD is now in return
297 |
298 | LCD_getaddr: ;works just like LCD_getchar, but with RS low, return.7 is the busy flag
299 | in temp, LCD_DDR
300 | andi temp, 0b00001111
301 | out LCD_DDR, temp
302 | cbi LCDS_PORT, LCD_RS
303 | sbi LCDS_PORT, LCD_RW
304 | sbi LCDS_PORT, LCD_E
305 | nop
306 | in temp, PinD
307 | andi temp, 0b11110000
308 | mov return, temp
309 | cbi LCDS_PORT, LCD_E
310 | nop
311 | nop
312 | sbi LCDS_PORT, LCD_E
313 | nop
314 | in temp, PinD
315 | andi temp, 0b11110000
316 | swap temp
317 | or return, temp
318 | cbi LCDS_PORT, LCD_E
319 | cbi LCDS_PORT, LCD_RW
320 | ret
321 |
322 | LCD_wait: ;read address and busy flag until busy flag cleared
323 |
324 | rcall LCD_getaddr
325 | andi return, 0x80
326 | brne LCD_wait
327 | ret
328 |
329 |
330 | LCD_delay:
331 | clr r2
332 | LCD_delay_outer:
333 | clr r3
334 | LCD_delay_inner:
335 | dec r3
336 | brne LCD_delay_inner
337 | dec r2
338 | brne LCD_delay_outer
339 | ret
340 |
341 | LCD_init:
342 | ;**** for the most LCD you must write 3times a dummy command before you change to 4Bit***
343 | ;this is corrected by www.bellibot.com :-)) - before !you have only one LineLCD ***
344 |
345 | ldi temp, 0b00001110 ;control lines are output, rest is input
346 | in temp,LCD_DDR
347 | andi temp,0b00001111 ;LCD pins input
348 | out LCD_DDR,temp
349 | in temp,LCDS_DDR
350 | ori temp, (1<<LCD_RS)|(1<<LCD_RW)|(1<<LCD_E) ;controllpins output
351 | out LCDS_DDR, temp
352 |
353 | rcall LCD_delay ;
354 | ldi arg, 0x30 ;
355 | rcall LCD_command8
356 |
357 | rcall LCD_delay
358 | ldi arg, 0x30 ;NOW: 2 lines, 5*7 font, 4-BIT MODE! ** DUMMY ***
359 | rcall LCD_command8 ;
360 |
361 |
362 | rcall LCD_delay
363 | ldi arg, 0x30
364 | rcall LCD_command8
365 |
366 | rcall LCD_delay ;first, we'll tell the LCD that we want to use it
367 | ldi arg, 0x20 ;in 4-bit mode.
368 | rcall LCD_command8 ;LCD is still in 8-BIT MODE while writing this command!!!
369 |
370 |
371 | rcall LCD_delay
372 | ldi arg, 0x28 ;NOW: 2 lines, 5*7 font, 4-BIT MODE! ** this change to 4bit 2 lines **
373 | rcall LCD_command ;after this point you don't can change anything 'show HD44780 Datasheet'
374 |
375 | rcall LCD_wait
376 | ldi arg, 0x0F ;now proceed as usual: Display on, cursor on, blinking
377 | rcall LCD_command
378 |
379 | rcall LCD_wait
380 | ldi arg, 0x01 ;clear display, cursor -> home
381 | rcall LCD_command
382 |
383 | rcall LCD_wait
384 | ldi arg, 0x06 ;auto-inc cursor
385 | rcall LCD_command
386 | ret
387 |
388 | ;******************************************
389 | ; clear Displays
390 | LCD_clear:
391 | push arg
392 | ldi arg, 0b00000001 ; Display clear
393 | rcall LCD_command
394 | rcall LCD_wait
395 | pop arg
396 | ret
397 |
398 | ; Cursor Home
399 | LCD_home:
400 | push arg
401 | ldi arg, 0b00000010 ; Cursor Home
402 | rcall LCD_command
403 | rcall LCD_wait
404 | pop arg
405 | ret
406 |
407 | ;set cursor pos
408 | ;Start Adresse für ein 4 x 20 Zeichen Display
409 | ;Zeile 1: 0x00
410 | ;Zeile 2: 0x40
411 | ;Zeile 3: 0x14
412 | ;Zeile 4: 0x54
413 | LCD_pos:
414 | sbr arg,0b10000000 ; Set DD-RAM-Adress
415 | rcall LCD_command
416 | rcall LCD_wait
417 | ret
418 |
419 | ;*****************************************************
420 | ; Display at the position in arg the string starting at Z (null-term.)
421 | ;
422 | LCD4ZTxt:
423 | sbr arg,0b10000000 ; Set DD-RAM-Adress
424 | rcall LCD_command
425 | rcall LCD_wait
426 | LCD4ZTxt1:
427 | lpm ; Get a char
428 | tst R0 ; Null-Char?
429 | breq LCD4ZTxtR
430 | mov arg,R0
431 | rcall LCD_putchar ; display the cahr
432 | rcall LCD_wait
433 | adiw ZL,1 ; next char
434 | rjmp LCD4ZTxt1 ; do it again
435 | LCD4ZTxtR:
436 | ret
437 | ;**********************************************************************
438 | ;
439 | ; Eine 8 Bit Zahl ohne Vorzeichen hexadezimal ausgeben
440 | ;
441 | ; Übergabe: Zahl im Register arg
442 | ; veränderte Register: keine
443 | ;
444 | lcd_number_hex:
445 | swap arg
446 | rcall lcd_number_hex_digit
447 | swap arg
448 |
449 | lcd_number_hex_digit:
450 | push arg
451 |
452 | andi arg, $0F
453 | cpi arg, 10
454 | brlt lcd_number_hex_digit_1
455 | subi arg, -( 'A' - '9' - 1 ) ; es wird subi mit negativer Konstante verwendet, weil es kein addi gibt
456 | lcd_number_hex_digit_1:
457 | subi arg, -'0' ; ditto
458 | rcall lcd_putchar
459 | rcall LCD_wait
460 | pop arg
461 | ret
462 | ;*********************************************************************
463 | ;
464 | ; Eine 8 Bit Zahl dezimal ohne Vorzeichen ausgeben
465 | ;
466 | ; Übergabe: Zahl im Register arg
467 | ; veränderte Register: keine
468 | ;
469 | lcd_number:
470 | push temp ; die Funktion verändert temp2, also sichern
471 | ; wir den Inhalt, um ihn am Ende wieder
472 | ; herstellen zu können
473 |
474 | mov arg2,arg ; das Register temp1 frei machen
475 | ; abzählen wieviele Hunderter
476 | ; in der Zahl enthalten sind
477 | ldi arg, '0'
478 | lcd_number_1:
479 | subi arg2, 100 ; 100 abziehen
480 | brcs lcd_number_2 ; ist dadurch ein Unterlauf entstanden?
481 | inc arg ; Nein: 1 Hunderter mehr ...
482 | rjmp lcd_number_1 ; ... und ab zur nächsten Runde
483 | ;
484 | ; die Hunderterstelle ausgeben
485 | lcd_number_2:
486 | rcall LCD_putchar
487 | rcall LCD_wait
488 | subi arg2, -100 ; 100 wieder dazuzählen, da die
489 | ; vorherhgehende Schleife 100 zuviel
490 | ; abgezogen hat
491 |
492 | ; abzählen wieviele Zehner in
493 | ; der Zahl enthalten sind
494 | ldi arg, '0'
495 | lcd_number_3:
496 | subi arg2, 10 ; 10 abziehen
497 | brcs lcd_number_4 ; ist dadurch ein Unterlauf enstanden?
498 | inc arg ; Nein: 1 Zehner mehr ...
499 | rjmp lcd_number_3 ; ... und ab zur nächsten Runde
500 |
501 | ; die Zehnerstelle ausgeben
502 | lcd_number_4:
503 | rcall LCD_putchar
504 | rcall LCD_wait
505 | subi arg2, -10 ; 10 wieder dazuzählen, da die
506 | ; vorhergehende Schleife 10 zuviel
507 | ; abgezogen hat
508 |
509 | ; die übrig gebliebenen Einer
510 | ; noch ausgeben
511 | ldi arg, '0' ; die Zahl in temp2 ist jetzt im Bereich
512 | add arg, arg2 ; 0 bis 9. Einfach nur den ASCII Code für
513 | rcall LCD_putchar ; '0' dazu addieren und wir erhalten dierekt
514 | rcall LCD_wait ; den ASCII Code für die Ziffer
515 |
516 | pop temp ; den gesicherten Inhalt von temp2 wieder herstellen
517 | ret ; und zurück
518 |
519 | ;**********************************************************************
520 | ;
521 | ; Eine 8 Bit Zahl ohne Vorzeichen binär ausgeben
522 | ;
523 | ; Übergabe: Zahl im Register temp1
524 | ; veränderte Register: keine
525 |
526 | ; eine Zahl aus dem Register temp1 binär ausgeben
527 | LCD_alsBit:
528 | push arg ; temp1 gesichert
529 | push temp2
530 | push temp3
531 |
532 | mov temp2, arg;
533 |
534 | ldi temp3, 8; ; 8 Bits werden ausgelesen
535 | lcd_number_loop:
536 | dec temp3;
537 | rol temp2; ; Datenbits ins Carry geschoben ...
538 | brcc lcd_number_bit_carryset_0;
539 | brcs lcd_number_bit_carryset_1;
540 | rjmp lcd_number_loop;
541 |
542 | lcd_number_bit_carryset_0:
543 | ldi arg, '0' ; Bit low ausgeben
544 | rcall LCD_putchar
545 | tst temp3;
546 | breq lcd_number_ende;
547 | rjmp lcd_number_loop;
548 |
549 | lcd_number_bit_carryset_1:
550 | ldi arg, '1' ; Bit high ausgeben
551 | rcall LCD_putchar
552 | tst temp3;
553 | breq lcd_number_ende;
554 | rjmp lcd_number_loop;
555 |
556 | lcd_number_ende:
557 | pop temp3
558 | pop temp2
559 | pop arg
560 | ret
561 | ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
562 | ; Ab hier Routinen zum auslesen und verarbeiten
563 | ; des Sensors DHT22 (AM2302)
564 | ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
565 |
566 |
567 | text:
568 | .db "Temperatur / Rel.FeuOut:",0
569 | ok:
570 | .db "ok",0
571 | fehler:
572 | .db "Fehler! ",0
573 |
574 | fehlender_Sensor:
575 | .db "kein Sensor",0
576 |
577 |
578 | WAIT_40us: ;selbserklärend
579 | push r16
580 | ldi r16,35
581 | loop1: dec r16
582 | nop
583 | nop
584 | brne loop1
585 | pop r16
586 | ret
587 | wait2s:
588 | push r16
589 | push r17
590 | push r18
591 | ldi r16,250
592 | lo_p: ldi r17,220
593 | lo__p: ldi r18,12
594 | lo___p: dec r18
595 | brne lo___p
596 | dec r17
597 | brne lo__p
598 | dec r16
599 | brne lo_p
600 | pop r18
601 | pop r17
602 | pop r16
603 | ret
604 |
605 |
606 | waitMs: push r16 ;r16 retten
607 | push r17 ;r17 retten
608 | push r18 ;r18 retten
609 | ; ldi r16,1 ;Laufvariable ca x ms bei 3,6MHz
610 | lop1: ldi r17,0x38 ;Laufvariable loop1
611 | loop2: ldi r18,5 ;Laufvariable loop3
612 | loop3: dec r18 ;Zähler 3 -1, hier Kalibrierung auf MCU Takt
613 | brne loop3 ;Solange nicht NULL
614 | dec r17 ;Zähler 2 -1
615 | brne loop2 ;Solange nicht NULL
616 | dec r16 ;Zähler1 -1
617 | brne lop1 ;Solange nicht NULL
618 | pop r18 ;r18 wiederherstellen
619 | pop r17 ;r17 wiederherstellen
620 | pop r16 ;r16 wiederherstellen
621 | ret ;Rücksprung
622 |
623 | DHT_lesen:
624 | ;;;;;;;;;;;;;;;;;;;;;;;;;;;;
625 | ; Initialisieren der Startsequenz
626 | ;;;;;;;;;;;;;;;;;;;;;;;;;;;;
627 |
628 | nop
629 | nop
630 | nop
631 | ldi temp,0x00
632 | ldi arg,0x00
633 | out PORTC,arg
634 | ldi r16,6 ;6 mS
635 | rcall waitMs ;min 1ms warten
636 | ; ldi arg,13 ;40 µs warten
637 | ;lo_:
638 | ; dec arg
639 | ; brne lo_
640 |
641 | out PortC,DHTmaske ;über DHT auf 1 setzen (ist Pin an dem der Sensor hängt)
642 | ldi arg,8
643 | lo__: ;20 µs warten
644 | dec arg
645 | brne lo__
646 | ldi arg,0x00
647 | ; cbi PORTC,2
648 | out DDRC,arg ;SensorPin auf eingang schalten
649 | low1: ; hier wird auf ein Nullsignal des Sensors gewartet
650 | in arg,PINC
651 | inc temp
652 | ; breq KeinSensor
653 | and arg,DHTmaske
654 | breq low1
655 | high1:
656 | in arg,PINC
657 | and arg,DHTmaske
658 | brne high1
659 | low2: ; hier wird auf das 2te Nullsignal des Sensors gewartet
660 | in arg,PINC
661 | and arg,DHTmaske
662 | breq low2
663 | high2:
664 | in arg,PINC
665 | and arg,DHTmaske
666 | brne high2
667 | low3: ; hier wird auf das 3te Nullsignal des Sensors gewartet
668 | in arg,PINC
669 | and arg,DHTmaske
670 | breq low3 ;ab hier beginnen die Daten
671 |
672 | rcall DHT_bytlesen
673 | std y+0, byte
674 | rcall DHT_bytlesen
675 | std y+1,byte
676 | rcall DHT_bytlesen
677 | std y+2,byte
678 | rcall DHT_bytlesen
679 | std y+3,byte
680 | rcall DHT_bytlesen
681 | std y+4,byte
682 |
683 |
684 |
685 | ; mov r21,return
686 | ; ldi arg,0x00
687 | ; rcall LCD_pos
688 | ; LDd arg,y+0
689 | ; rcall LCD_alsBit
690 | ; ldi arg,0x40
691 | ; rcall LCD_pos
692 | ; LDd arg,y+1
693 | ; rcall LCD_alsBit
694 | ;ldi arg,0x14
695 | ; rcall LCD_pos
696 | ; LDd arg,y+2
697 | ; rcall LCD_alsBit
698 | ;ldi arg,0x54
699 | ; rcall LCD_pos
700 | ; LDd arg,y+3
701 | ; rcall LCD_alsBit
702 | ;ldi arg,0x0a
703 | ; rcall LCD_pos
704 | ; LDd arg,y+4
705 | ; rcall LCD_alsBit
706 | ; ldi arg,0x1e
707 | ; rcall LCD_pos
708 |
709 |
710 | ;Checksumme überprüfen
711 | ; rcall LCD_pos
712 | ldd arg,y+0
713 | ldd arg2,y+1
714 | add arg,arg2
715 | ldd arg2,y+2
716 | add arg,arg2
717 | ldd arg,y+3
718 | add arg,arg2
719 | ldd arg2,y+4
720 | cp arg,arg2
721 | breq fehler_
722 | ; ldi ZH,HIGH(ok*2)
723 | ; ldi ZL,LOW(ok*2)
724 | ; ldi arg,0x4a
725 | ; rcall LCD4ZTxt
726 | rjmp weitt
727 | fehler_:
728 | ldi ZH,HIGH(fehler*2)
729 | ldi ZL,LOW(fehler*2)
730 | ; ldi arg,0x4a
731 | rcall LCD4ZTxt
732 |
733 | weitt:
734 | ; ldi arg,0x1d
735 | ; rcall LCD_pos ;Position für die Luftfeuchte
736 | rcall umwandeln
737 | ldi arg,0x25 ;% und "RH" anfügen
738 | rcall LCD_putchar
739 | rcall LCD_wait
740 | ldi arg,' '
741 | rcall LCD_putchar
742 | rcall LCD_wait
743 | ldi arg,' '
744 | rcall LCD_putchar
745 | rcall LCD_wait
746 |
747 |
748 | ; ldi arg,0x5d
749 | ; rcall LCD_pos ;Position für die Temperatur
750 | inc r28
751 | inc r28
752 | ldi r29,0x00
753 | rcall umwandeln
754 | ldi arg,0xdf ;grad zeichen
755 | rcall LCD_putchar
756 | rcall LCD_wait
757 | ldi arg,0x43 ;grosses C
758 | rcall LCD_putchar
759 | rcall LCD_wait
760 | ret
761 |
762 |
763 | ;Routine zum erkennen der steigenden Flanke ohne Interrupt
764 | steigendeFlanke:
765 | CLT
766 | ldi return,0x00
767 | anf:
768 | in arg,PINC
769 | inc return
770 | andi arg,0x04
771 | breq anf
772 | brtc keinTflag
773 | ret ;rücksprung nach 2ten mal 1 geunden
774 | keinTflag:
775 | SET ;hier wird das T Flag verwendet umzu
776 | rjmp anf ;ob im zweiten durchlauf die 1 immer noch anliegt
777 |
778 | fallendeFlanke:
779 | CLT
780 | ldi return,0x00
781 | anf_:
782 | in arg,PINC
783 | inc return
784 | andi arg,0x04
785 | brne anf_
786 | brtc keinTflag_
787 | ret ;rücksprung nach 2ten mal 1 geunden
788 | keinTflag_:
789 | SET ;hier wird das T Flag verwendet umzu
790 | rjmp anf_ ;ob im zweiten durchlauf die 1 immer noch anliegt
791 |
792 |
793 | ;;;;;;;;;;;Byte lesen;;;;;;;;;;;;;;;;
794 | DHT_bytlesen:
795 |
796 | ldi temp,0x08
797 | ldi byte,00
798 | ; mov temp2,DHTmaske ;Pin an dem der DHT22 haengt
799 | runde: ;erkennen der Steigenden Flanke
800 | in arg,PINC
801 | and arg,DHTmaske ;Pin an dem der DHT22 haengt
802 | breq runde
803 | ldi arg,14 ;40us warten
804 | wart:
805 | dec arg
806 | brne wart
807 | in arg,PINC
808 | and arg,DHTmaske ;Pin an dem der DHT22 haengt
809 | brbs 1, c_null
810 | sec
811 | c_null:
812 | ldi arg,0x00
813 | rol byte ;
814 | adc byte,arg ;addiert null bei Z=0 und 1 bei z=1 ueber Carry
815 | nulltest: ;Hier wird wieder auf das naechste Low gewartet
816 | in arg,PINC
817 | and arg,DHTmaske ;Pin an dem der DHT22 haengt
818 | brne nulltest
819 | dec temp
820 | brne runde
821 | ret
822 |
823 | ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
824 | ; Weerte als dezimal Zahl ausgeben
825 | ; in Register Y (r28/r29) steht die Adresse für das erste
826 | ; umzuwandelnde Byte (High Byte)
827 | ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
828 |
829 | umwandeln:
830 | ; ldi arg,0x1e
831 | ; rcall LCD_pos
832 | ldi temp,$00 ;hunderter
833 | ldi temp2,0x00 ;rest
834 | ldi arg,0x00
835 | ldd arg2,y+0
836 | ; ldi arg,0x5e
837 | ; rcall LCD_pos
838 | ; ldd arg,y+1
839 | ; rcall LCD_alsBit
840 | ; ldi arg,0x00
841 | ror arg2 ;bit 9 auf 1 testen
842 | brcc nicht_gesetzt
843 | ldi arg,0x02
844 | add temp,arg
845 | ldi temp2,0x38 ;56 zum Rest addieren(von 256)
846 | nicht_gesetzt:
847 | ror arg2 ; Bit 10 überprüfen
848 | brcc nicht_gesetzt2
849 | ldi arg,0x05
850 | add temp,arg
851 | ldi arg,0x0c ;12 (von 512) zum Rest addieren
852 | add temp2,arg
853 | nicht_gesetzt2:
854 | ldd arg2,y+1
855 | rol arg2
856 | brcc nicht_gesetzt3
857 | inc temp
858 | ldi arg,28 ;Rest von 1(28) addieren
859 | add temp2,arg
860 | nicht_gesetzt3:
861 | rol arg2
862 | brcc nicht_gesetzt4
863 | ldi arg,64
864 | add temp2,arg
865 | nicht_gesetzt4:
866 | rol arg2
867 | brcc nicht_gesetzt5
868 | ldi arg,32
869 | add temp2,arg
870 | nicht_gesetzt5:
871 | rol arg2
872 | brcc nicht_gesetzt6
873 | ldi arg,16
874 | add temp2,arg
875 | nicht_gesetzt6:
876 | rol arg2
877 | brcc nicht_gesetzt7
878 | ldi arg,8
879 | add temp2,arg
880 | nicht_gesetzt7:
881 | rol arg2
882 | brcc nicht_gesetzt8
883 | ldi arg,4
884 | add temp2,arg
885 | nicht_gesetzt8:
886 | rol arg2
887 | brcc nicht_gesetzt9
888 | ldi arg,2
889 | add temp2,arg
890 | nicht_gesetzt9:
891 | rol arg2
892 | brcc nicht_gesetzt0
893 | inc temp2
894 | nicht_gesetzt0:
895 | subi temp2,100 ; 100 abziehen
896 | brcs dht_number_2 ; ist dadurch ein Unterlauf entstanden?
897 | inc temp ; Nein: 1 Hunderter mehr ...
898 | rjmp nicht_gesetzt0 ; ... und ab zur nächsten Runde
899 | ; die Hunderterstelle ausgeben
900 |
901 |
902 | dht_number_2:
903 |
904 | ldi arg,48
905 | add arg,temp
906 | rcall LCD_putchar
907 | rcall LCD_wait
908 | subi temp2, -100 ; 100 wieder dazuzählen, da die
909 | ; vorherhgehende Schleife 100 zuviel
910 | ; abgezogen hat
911 |
912 | ; abzählen wieviele Zehner in
913 | ; der Zahl enthalten sind
914 | ldi arg, '0'
915 | dht_number_3:
916 | subi temp2, 10 ; 10 abziehen
917 | brcs dht_number_4 ; ist dadurch ein Unterlauf enstanden?
918 | inc arg ; Nein: 1 Zehner mehr ...
919 | rjmp dht_number_3 ; ... und ab zur nächsten Runde
920 |
921 | ; die Zehnerstelle ausgeben
922 | dht_number_4:
923 | rcall LCD_putchar
924 | rcall LCD_wait
925 | subi temp2, -10 ; 10 wieder dazuzählen, da die
926 | ; vorhergehende Schleife 10 zuviel
927 | ; abgezogen hat
928 | ldi arg,0x2e ; Punkt einfügen
929 | rcall LCD_putchar
930 | rcall LCD_wait
931 |
932 | ; die übrig gebliebenen Einer
933 | ; noch ausgeben
934 | ldi arg, '0' ; die Zahl in temp2 ist jetzt im Bereich
935 | add arg, temp2 ; 0 bis 9. Einfach nur den ASCII Code für
936 | rcall LCD_putchar ; '0' dazu addieren und wir erhalten dierekt
937 | rcall LCD_wait ; den ASCII Code für die Ziffer
938 |
939 |
940 |
941 |
942 |
943 | ret
