1 | #include <msp430.h>
2 |
3 | int value;
4 |
5 | int main(void) {
6 |
7 | WDTCTL = WDTPW | WDTHOLD; // Stop WDT
8 |
9 | // GPIO Setup
10 | P1OUT &= ~BIT0; // LED2 aus
11 | P1DIR |= BIT0; // P1.0/LED2 als Ausgang
12 | P4OUT &= ~BIT6; // LED1 aus
13 | P4DIR |= BIT6; // P4.6/LED1 als Ausgang
14 | P4SEL1 |= BIT2; // P4.2 als ADC Eingang A10
15 | P4SEL0 |= BIT2;
16 |
17 | PJOUT = 0; // Setup XT1
18 | PJSEL0 = BIT4 | BIT5;
19 | PJDIR = 0xFFFF;
20 |
21 | PM5CTL0 &= ~LOCKLPM5;
22 |
23 | // XT1 Setup
24 | CSCTL0_H = CSKEY >> 8; // Unlock CS registers
25 | CSCTL1 = DCOFSEL_0; // Set DCO to 1MHz
26 | CSCTL2 = SELA__LFXTCLK | SELS__DCOCLK | SELM__DCOCLK;
27 | CSCTL3 = DIVA__1 | DIVS__1 | DIVM__1; // Set all dividers to 1
28 | CSCTL4 &= ~LFXTOFF; // Enable LFXT1
29 | do {
30 | CSCTL5 &= ~LFXTOFFG; // Clear XT1 fault flag
31 | SFRIFG1 &= ~OFIFG;
32 | } while (SFRIFG1&OFIFG); // Test oscillator fault flag
33 | CSCTL0_H = 0; // Lock CS registers
34 |
35 | // Configure ADC12
36 | ADC12CTL0 &= ~ADC12ENC; // disable ADC12
37 | ADC12CTL0 = ADC12ON; // ADC12 on
38 | ADC12CTL1 = ADC12SHS_1; // TA0CCR1 als SHS
39 | ADC12CTL2 = ADC12RES_1; // 10-bit Auflösung + Low Power Mode
40 | ADC12MCTL0 = ADC12WINC | ADC12INCH_10; // Window Comparator + A10 als Input
41 | ADC12HI = 0x300; // Oberer Threshold 3/4 VDD
42 | ADC12LO = 0x100; // Unterer Threshold = 1/4 VDD
43 | ADC12IER0 = ADC12IE0; // enable conversion complete Interrupt für ADC12MEM0
44 | ADC12IER2 = ADC12OVIE | ADC12HIIE; // enable Interrupt für oberen und unteren Threshold des Window Comparators
45 |
46 | // Configure Timer_A
47 | TA0CTL = TASSEL_1 + MC_1; // ACLK + Up-Mode
48 | TA0CCTL0 = CCIE; // enable Interrupt
49 | TA0CCTL1 = OUTMOD_3; // PWM Set/Reset
50 | TA0CCR0 = 4; // Periode setzen -> 32768/4 = 8192 Messwerte pro Sekunde
51 | TA0CCR1 = 1; // Sample-and-hold Dauer 4 - 1 = 3 Takte => ca. 90µS
52 | __bis_SR_register(LPM3_bits + GIE); // LPM3 + globale Interrupts aktiv
53 | }
54 |
55 | #pragma vector = ADC12_VECTOR
56 | __interrupt void ADC12_ISR(void) {
57 | switch(__even_in_range(ADC12IV, ADC12IV_ADC12RDYIFG)) {
58 | case ADC12IV_NONE: break; // Vector 0: No interrupt
59 | case ADC12IV_ADC12OVIFG: break; // Vector 2: ADC12MEMx Overflow
60 | case ADC12IV_ADC12TOVIFG: break; // Vector 4: Conversion time overflow
61 | case ADC12IV_ADC12HIIFG: // Vector 6: ADC12BHI
62 | ADC12IFGR2 &= ~ADC12HIIFG; // Clear Interrupt Flag
63 | P1OUT |= BIT0; // LED2 on
64 | break;
65 | case ADC12IV_ADC12LOIFG: // Vector 8: ADC12BLO
66 | ADC12IFGR2 &= ~ADC12LOIFG; // Clear Interrupt Flag
67 | P1OUT &= ~BIT0; // LED2 off
68 | break;
69 | case ADC12IV_ADC12INIFG: break; // Vector 10: ADC12BIN
70 | case ADC12IV_ADC12IFG0: ADC12CTL0 &= ~ADC12ENC; // Disable ADC12
71 | P4OUT ^= BIT6; // Toggle LED1
72 | value = ADC12MEM0;
73 | break;
74 | case ADC12IV_ADC12IFG1: break; // Vector 14: ADC12MEM1
75 | case ADC12IV_ADC12IFG2: break; // Vector 16: ADC12MEM2
76 | case ADC12IV_ADC12IFG3: break; // Vector 18: ADC12MEM3
77 | case ADC12IV_ADC12IFG4: break; // Vector 20: ADC12MEM4
78 | case ADC12IV_ADC12IFG5: break; // Vector 22: ADC12MEM5
79 | case ADC12IV_ADC12IFG6: break; // Vector 24: ADC12MEM6
80 | case ADC12IV_ADC12IFG7: break; // Vector 26: ADC12MEM7
81 | case ADC12IV_ADC12IFG8: break; // Vector 28: ADC12MEM8
82 | case ADC12IV_ADC12IFG9: break; // Vector 30: ADC12MEM9
83 | case ADC12IV_ADC12IFG10: break; // Vector 32: ADC12MEM10
84 | case ADC12IV_ADC12IFG11: break; // Vector 34: ADC12MEM11
85 | case ADC12IV_ADC12IFG12: break; // Vector 36: ADC12MEM12
86 | case ADC12IV_ADC12IFG13: break; // Vector 38: ADC12MEM13
87 | case ADC12IV_ADC12IFG14: break; // Vector 40: ADC12MEM14
88 | case ADC12IV_ADC12IFG15: break; // Vector 42: ADC12MEM15
89 | case ADC12IV_ADC12IFG16: break; // Vector 44: ADC12MEM16
90 | case ADC12IV_ADC12IFG17: break; // Vector 46: ADC12MEM17
91 | case ADC12IV_ADC12IFG18: break; // Vector 48: ADC12MEM18
92 | case ADC12IV_ADC12IFG19: break; // Vector 50: ADC12MEM19
93 | case ADC12IV_ADC12IFG20: break; // Vector 52: ADC12MEM20
94 | case ADC12IV_ADC12IFG21: break; // Vector 54: ADC12MEM21
95 | case ADC12IV_ADC12IFG22: break; // Vector 56: ADC12MEM22
96 | case ADC12IV_ADC12IFG23: break; // Vector 58: ADC12MEM23
97 | case ADC12IV_ADC12IFG24: break; // Vector 60: ADC12MEM24
98 | case ADC12IV_ADC12IFG25: break; // Vector 62: ADC12MEM25
99 | case ADC12IV_ADC12IFG26: break; // Vector 64: ADC12MEM26
100 | case ADC12IV_ADC12IFG27: break; // Vector 66: ADC12MEM27
101 | case ADC12IV_ADC12IFG28: break; // Vector 68: ADC12MEM28
102 | case ADC12IV_ADC12IFG29: break; // Vector 70: ADC12MEM29
103 | case ADC12IV_ADC12IFG30: break; // Vector 72: ADC12MEM30
104 | case ADC12IV_ADC12IFG31: break; // Vector 74: ADC12MEM31
105 | case ADC12IV_ADC12RDYIFG: break; // Vector 76: ADC12RDY
106 | default: break;
107 | }
108 | }
109 |
110 | // Timer A0 interrupt service routine
111 | #pragma vector=TIMER0_A0_VECTOR
112 | __interrupt void Timer_A(void)
113 | {
114 | ADC12CTL0 |= ADC12ENC; // ADC10 enable set
115 | }
