XMEGA EBI Base Address
(Firma: matzetronics) #3698628
Unter dieser Adresse wird (als 'hugemem') der angeschlossene RAM Chip in
den Adressraum eingeblendet (mit Hilfe der RAS und CAS Leitungen).
Auf dem XMega Xplained A1 Board z.B. ist der 8MByte SDRAM als 3-Port
eingebunden und EBI CS so programmiert, das der Chip ab Adresse 0x800000
in den Adressraum eingeblendet wird, mit einer Länge von ebenfalls
0x800000:
#define CONFIG_HAVE_HUGEMEM
//! Base address of SDRAM on board
#define BOARD_EBI_SDRAM_BASE    0x800000UL
//! Size of SDRAM on board, given in bytes.
#define BOARD_EBI_SDRAM_SIZE    0x800000UL
Als Beispiel mal die EBI Init für das XPlained A1:
static void InitSDRAM(void) {
   * Configure the EBI port with 12 address lines, no address latches or
   * low pin count, and set it in SDRAM mode with 3-port EBI port.
  ebi_setup_port(12, 0, 0, EBI_PORT_3PORT | EBI_PORT_SDRAM);
   * Configure the EBI chip select for an 8 MB SDRAM located at
   * \ref BOARD_EBI_SDRAM_BASE.
  ebi_cs_set_mode(&cs_config, EBI_CS_MODE_SDRAM_gc);
  ebi_cs_set_address_size(&cs_config, EBI_CS_ASIZE_8MB_gc);
  ebi_cs_set_base_address(&cs_config, BOARD_EBI_SDRAM_BASE);
  /* Configure the EBI chip select to be in SDRAM mode. */
  ebi_sdram_set_mode(&cs_config, EBI_CS_SDMODE_NORMAL_gc);
  /* Setup the number of SDRAM rows and columns. */
  ebi_sdram_set_row_bits(&sdram_config, 12);
  ebi_sdram_set_col_bits(&sdram_config, 10);
  /* Further, setup the SDRAM timing. */
24
  ebi_sdram_set_cas_latency(&sdram_config, 3);
25
  ebi_sdram_set_mode_delay(&sdram_config, EBI_MRDLY_2CLK_gc);
26
  ebi_sdram_set_row_cycle_delay(&sdram_config, EBI_ROWCYCDLY_7CLK_gc);
27
  ebi_sdram_set_row_to_precharge_delay(&sdram_config, EBI_RPDLY_7CLK_gc);
28
  ebi_sdram_set_write_recovery_delay(&sdram_config, EBI_WRDLY_1CLK_gc);
29
  ebi_sdram_set_self_refresh_to_active_delay(&sdram_config,
30
      EBI_ESRDLY_7CLK_gc);
31
  ebi_sdram_set_row_to_col_delay(&sdram_config, EBI_ROWCOLDLY_7CLK_gc);
32
  ebi_sdram_set_refresh_period(&sdram_config, BOARD_EBI_SDRAM_REFRESH);
33
  ebi_sdram_set_initialization_delay(&sdram_config,
34
      BOARD_EBI_SDRAM_INITDLY);
35
36
  /* Write SDRAM configuration into the EBI registers. */
37
  ebi_sdram_write_config(&sdram_config);
38
  /* Write the chip select configuration into the EBI registers. */
39
  ebi_cs_write_config(EBI_SDRAM_CS, &cs_config);
40
41
  ebi_enable_cs(EBI_SDRAM_CS, &cs_config);
42
  do {
43
    // Wait for SDRAM to initialize.
44
  } while (!ebi_sdram_is_ready());
45
46
  /* Debug: Enable LED1: SDRAM is ready. */
47
  LED_PORT.OUTCLR = OLED1;
48
    _delay_ms(100);
49
  LED_PORT.OUTSET = OLED1;
50
Gast #3698716
Das mit der Startadresse hab ich mir schon gedacht. Da das Register
BASEADDR aber nur 12 Bit groß ist, vermute ich dass es sich hierbei nur
um einen Multiplikator handelt. Im Datenblatt steht das die Basisadresse
ein Vielfaches von 4096 sein muss und wenn man nun  4096 mit der größten
Zahl die in BASEADDR stehen kann (4096) multipliziert, kommt man auf die
16MB die max vom EBI Adressiert werden können. Leider bekomme ich das
EBI aber immer noch nicht zum Laufen und hänge deshalb den Code an.  Es
wird übrigens 512K SRAM verwendet.
#define SRAM_groese   0x80000
#define Basisadresse  0x80000  // ACHTUNG MUSS EIN VIELFACHES VON 4096 SEIN
#define BASEADDR_ (Basisadresse/4096)
void EBI_SRAM_init (void) {
  PORTH_OUTSET = (1<<RAM_CE)|(1<<RAM_WE)|(1<<RAM_OE); // setze alle low aktiven signale auf 1 (Datenblatt Seite 269)
  EBI_CTRL = 0b01001001;      // AL1&2 und 3port 8bit datenbus
  EBI_CS0_CTRLA = 0b00101101; // 512Kb  CS=Sram
  EBI_CS0_CTRLB = 0b00000111; // /7CLK
  EBI_CS0_BASEADDR = BASEADDR_;
  __far_mem_write(Basisadresse,1);
  if(__far_mem_read(Basisadresse) == 1) FT232_sende_String("\nEBI OK\n");else FT232_sende_String("\nEBI FEHLER\n");
Gast #3698865
Vielen Dank für den Link!
Nur leider wird bei den meisten Beispielen SDRAM benutzt. Ich hab jetzt
mal versucht ob der RAM Hardwaremäßig funktioniert (Code im Anhang) und
das tut er . Außerdem habe ich bemerkt das die Adress Latch´s  nicht
aktualisiert werden wenn es übers EBI läuft.
void uint8_t EBI_SRAM_Read (uint32_t Adresse) {
  PORTK_OUT = ((uint32_t)Adresse >> 16);
  PORTH_OUTSET = (1<<RAM_REG_1);
  PORTH_OUTCLR = (1<<RAM_REG_1);
  PORTK_OUT = ((uint32_t)Adresse >> 8);
  PORTH_OUTSET = (1<<RAM_REG_0);
  PORTH_OUTCLR = (1<<RAM_REG_0);
  PORTK_OUT = (uint32_t)Adresse;
  PORTJ_DIR = 0x00;
  PORTH_OUTCLR = (1<<RAM_OE);
  return (PORTJ_IN);
void EBI_SRAM_write (uint32_t Adresse,uint8_t byte) {
23
24
  PORTH_OUTSET = (1<<RAM_OE);
25
  PORTJ_DIR = 0xFF;
26
  PORTJ_OUT = byte;
27
  PORTH_OUTCLR = (1<<RAM_WE);
28
  PORTH_OUTSET = (1<<RAM_WE);
29
