1 | ;/*------------------------------------------------------------------*/
2 | ;/* --- STC MCU Limited ---------------------------------------------*/
3 | ;/* --- STC12C5Axx Series MCU ISP/IAP/EEPROM Demo -------------------*/
4 | ;/* --- Web: www.STCMCU.com -----------------------------------------*/
5 | ;/* If you want to use the program or the program referenced in the */
6 | ;/* article, please specify in which data and procedures from STC */
7 | ;/*------------------------------------------------------------------*/
8 |
9 | ;/*Declare SFR associated with the IAP */
10 | IAP_DATA EQU 0C2H ;Flash data register
11 | IAP_ADDRH EQU 0C3H ;Flash address HIGH
12 | IAP_ADDRL EQU 0C4H ;Flash address LOW
13 | IAP_CMD EQU 0C5H ;Flash command register
14 | IAP_TRIG EQU 0C6H ;Flash command trigger
15 | IAP_CONTR EQU 0C7H ;Flash control register
16 |
17 | ;/*Define ISP/IAP/EEPROM command*/
18 | CMD_IDLE EQU 0 ;Stand-By
19 | CMD_READ EQU 1 ;Byte-Read
20 | CMD_PROGRAM EQU 2 ;Byte-Program
21 | CMD_ERASE EQU 3 ;Sector-Erase
22 |
23 | ;/*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
24 | ENABLE_IAP EQU 82H ;if SYSCLK<20MHz
25 |
26 | ;//Start address for STC12C5Axx EEPROM
27 | IAP_ADDRESS EQU 0400H
28 | ;-----------------------------------------
29 | ORG 0000H
30 | LJMP MAIN
31 | ;-----------------------------------------
32 | ORG 0100H
33 | MAIN:
34 | MOV P1,#0FEH ;1111,1110 System Reset OK
35 | LCALL DELAY ;Delay
36 | ;-------------------------------
37 | MOV DPTR,#IAP_ADDRESS ;Set ISP/IAP/EEPROM address
38 | LCALL IAP_ERASE ;Erase current sector
39 | ;-------------------------------
40 | MOV DPTR,#IAP_ADDRESS ;Set ISP/IAP/EEPROM address
41 | MOV R0,#128 ;Set counter (512)
42 | MOV R1,#4
43 | CHECK1: ;Check whether all sector data is FF
44 | LCALL IAP_READ ;Read Flash
45 | CJNE A,#0FFH,ERROR ;If error, break
46 | INC DPTR ;Inc Flash address
47 | DJNZ R0,CHECK1 ;Check next
48 | DJNZ R1,CHECK1 ;Check next
49 | ;-------------------------------
50 | MOV P1,#0FCH ;1111,1100 Erase successful
51 | LCALL DELAY ;Delay
52 | ;-------------------------------
53 | MOV DPTR,#IAP_ADDRESS ;Set ISP/IAP/EEPROM address
54 | MOV R0,#128 ;Set counter (512)
55 | MOV R1,#4
56 | MOV R2,#0 ;Initial test data
57 | NEXT: ;Program 512 bytes data into data flash
58 | MOV A,R2 ;Ready IAP data
59 | LCALL IAP_PROGRAM ;Program flash
60 | INC DPTR ;Inc Flash address
61 | INC R2 ;Modify test data
62 | DJNZ R0,NEXT ;Program next
63 | DJNZ R1,NEXT ;Program next
64 | ;-------------------------------
65 | MOV P1,#0F8H ;1111,1000 Program successful
66 | LCALL DELAY ;Delay
67 | ;-------------------------------
68 | MOV DPTR,#IAP_ADDRESS ;Set ISP/IAP/EEPROM address
69 | MOV R0,#0 ;Set counter (512)
70 | MOV R1,#2
71 | MOV R2,#0
72 | CHECK2: ;Verify 512 bytes data
73 | LCALL IAP_READ ;Read Flash
74 | CJNE A,2,ERROR ;If error, break
75 | INC DPTR ;Inc Flash address
76 | INC R2 ;Modify verify data
77 | DJNZ R0,CHECK2 ;Check next
78 | DJNZ R1,CHECK2 ;Check next
79 | ;-------------------------------
80 | MOV P1,#0F0H ;1111,0000 Verify successful
81 | SJMP $
82 | ;-------------------------------
83 | ERROR:
84 | MOV P0,R0
85 | MOV P2,R1
86 | MOV P3,R2
87 | CLR P1.7 ;0xxx,xxxx IAP operation fail
88 | SJMP $
89 |
90 | ;/*----------------------------
91 | ;Software delay function
92 | ;----------------------------*/
93 | DELAY:
94 | CLR A
95 | MOV R0,A
96 | MOV R1,A
97 | MOV R2,#20H
98 | DELAY1:
99 | DJNZ R0,DELAY1
100 | DJNZ R1,DELAY1
101 | DJNZ R2,DELAY1
102 | RET
103 |
104 | ;/*----------------------------
105 | ;Disable ISP/IAP/EEPROM function
106 | ;Make MCU in a safe state
107 | ;----------------------------*/
108 | IAP_IDLE:
109 | MOV IAP_CONTR,#0 ;Close IAP function
110 | MOV IAP_CMD,#0 ;Clear command to standby
111 | MOV IAP_TRIG,#0 ;Clear trigger register
112 | MOV IAP_ADDRH,#80H ;Data ptr point to non-EEPROM area
113 | MOV IAP_ADDRL,#0 ;Clear IAP address to prevent misuse
114 | RET
115 |
116 | ;/*----------------------------
117 | ;Read one byte from ISP/IAP/EEPROM area
118 | ;Input: DPTR(ISP/IAP/EEPROM address)
119 | ;Output:ACC (Flash data)
120 | ;----------------------------*/
121 | IAP_READ:
122 | MOV IAP_CONTR,#ENABLE_IAP ;Open IAP function, and set wait time
123 | MOV IAP_CMD,#CMD_READ ;Set ISP/IAP/EEPROM READ command
124 | MOV IAP_ADDRL,DPL ;Set ISP/IAP/EEPROM address low
125 | MOV IAP_ADDRH,DPH ;Set ISP/IAP/EEPROM address high
126 | MOV IAP_TRIG,#5AH ;Send trigger command1 (0x5a)
127 | MOV IAP_TRIG,#0A5H ;Send trigger command2 (0xa5)
128 | NOP ;MCU will hold here until ISP/IAP/EEPROM operation complete
129 | MOV A,IAP_DATA ;Read ISP/IAP/EEPROM data
130 | LCALL IAP_IDLE ;Close ISP/IAP/EEPROM function
131 | RET
132 |
133 | ;/*----------------------------
134 | ;Program one byte to ISP/IAP/EEPROM area
135 | ;Input: DPAT(ISP/IAP/EEPROM address)
136 | ; ACC (ISP/IAP/EEPROM data)
137 | ;Output:-
138 | ;----------------------------*/
139 | IAP_PROGRAM:
140 | MOV IAP_CONTR,#ENABLE_IAP ;Open IAP function, and set wait time
141 | MOV IAP_CMD,#CMD_PROGRAM ;Set ISP/IAP/EEPROM PROGRAM command
142 | MOV IAP_ADDRL,DPL ;Set ISP/IAP/EEPROM address low
143 | MOV IAP_ADDRH,DPH ;Set ISP/IAP/EEPROM address high
144 | MOV IAP_DATA,A ;Write ISP/IAP/EEPROM data
145 | MOV IAP_TRIG,#5AH ;Send trigger command1 (0x5a)
146 | MOV IAP_TRIG,#0A5H ;Send trigger command2 (0xa5)
147 | NOP ;MCU will hold here until ISP/IAP/EEPROM operation complete
148 | LCALL IAP_IDLE ;Close ISP/IAP/EEPROM function
149 | RET
150 |
151 | ;/*----------------------------
152 | ;Erase one sector area
153 | ;Input: DPTR(ISP/IAP/EEPROM address)
154 | ;Output:-
155 | ;----------------------------*/
156 | IAP_ERASE:
157 | MOV IAP_CONTR,#ENABLE_IAP ;Open IAP function, and set wait time
158 | MOV IAP_CMD,#CMD_ERASE ;Set ISP/IAP/EEPROM ERASE command
159 | MOV IAP_ADDRL,DPL ;Set ISP/IAP/EEPROM address low
160 | MOV IAP_ADDRH,DPH ;Set ISP/IAP/EEPROM address high
161 | MOV IAP_TRIG,#5AH ;Send trigger command1 (0x5a)
162 | MOV IAP_TRIG,#0A5H ;Send trigger command2 (0xa5)
163 | NOP ;MCU will hold here until ISP/IAP/EEPROM operation complete
164 | LCALL IAP_IDLE ;Close ISP/IAP/EEPROM function
165 | RET
166 |
167 | END
