1 | #include <avr/io.h>
2 | #include <avr/interrupt.h>
3 |
4 | // UART0
5 | #define UART0_BAUD 9600UL
6 | #define UART0_UBRR_VAL ((F_CPU+UART0_BAUD*8)/(UART0_BAUD*16)-1)
7 | #define UART0_BAUD_REAL (F_CPU/(16*(UART0_UBRR_VAL+1)))
8 | #define UART0_BAUD_ERROR ((UART0_BAUD_REAL*1000)/UART0_BAUD)
9 |
10 | #if ((UART0_BAUD_ERROR<990) || (UART0_BAUD_ERROR>1010))
11 | #error Systematischer Fehler der Baudrate(UART0) groesser 1% und damit zu hoch!
12 | #endif
13 |
14 | void uart0_init(void)
15 | {
16 | UBRR0 = UART0_UBRR_VAL;
17 | UCSR0B |= (1 << TXEN0);
18 | UCSR0C = (1 << UCSZ01) | (1 << UCSZ00);
19 | }
20 |
21 | int uart0_putc(uint8_t c)
22 | {
23 | while(!(UCSR0A & (1<<UDRE0))) {}
24 |
25 | UDR0 = c;
26 | return 0;
27 | }
28 |
29 | void uart0_puts (char *s)
30 | {
31 | while (*s)
32 | {
33 | uart0_putc(*s);
34 | s++;
35 | }
36 | }
37 |
38 | // UART1
39 | #define UART1_BAUD 9600UL
40 | #define UART1_UBRR_VAL ((F_CPU+UART1_BAUD*8)/(UART1_BAUD*16)-1)
41 | #define UART1_BAUD_REAL (F_CPU/(16*(UART1_UBRR_VAL+1)))
42 | #define UART1_BAUD_ERROR ((UART1_BAUD_REAL*1000)/UART1_BAUD)
43 |
44 | #if ((UART1_BAUD_ERROR<990) || (UART1_BAUD_ERROR>1010))
45 | #error Systematischer Fehler der Baudrate(UART1) groesser 1% und damit zu hoch!
46 | #endif
47 |
48 | void uart1_init(void)
49 | {
50 | UBRR1 = UART1_UBRR_VAL;
51 | UCSR1B |= (1 << TXEN1);
52 | UCSR1C = (1 << UCSZ11) | (1 << UCSZ10);
53 | }
54 |
55 | int uart1_putc(uint8_t c)
56 | {
57 | while(!(UCSR1A & (1<<UDRE1))) {}
58 |
59 | UDR1 = c;
60 | return 0;
61 | }
62 |
63 | void uart1_puts (char *s)
64 | {
65 | while (*s)
66 | {
67 | uart1_putc(*s);
68 | s++;
69 | }
70 | }
71 |
72 |
73 | volatile uint32_t _millis;
74 | volatile uint32_t millis;
75 | volatile uint16_t second;
76 |
77 | ISR(TIMER0_COMPA_vect)
78 | {
79 | _millis++;
80 | millis++;
81 |
82 | if(millis == 1000)
83 | {
84 | second++;
85 | millis = 0;
86 | }
87 | }
88 |
89 |
90 | int main(void)
91 | {
92 | // UART
93 | uart0_init();
94 | uart1_init();
95 |
96 | // millis
97 | TCCR0A = (1 << WGM01); // CTC Modus
98 | TCCR0B |= (1 << CS01) | (1 << CS00); // Prescaler 64
99 | OCR0A = 124; // (F_CPU/PRESCALER)/1000-1
100 | TIMSK0 |= (1 << OCIE0A); // Compare Interupt erlauben
101 | sei();
102 |
103 | while(1)
104 | {
105 | static uint16_t last_second;
106 | if(last_second != second)
107 | {
108 | last_second = second;
109 |
110 | char str[10];
111 | uart0_puts("UART0 >> ");
112 | itoa(second, str, 10);
113 | uart0_puts(str);
114 | uart0_puts("\n\r");
115 |
116 |
117 | uart1_puts("UART1 >> ");
118 | itoa(second, str, 10);
119 | uart1_puts(str);
120 | uart1_puts("\n\r");
121 | }
122 | }
123 | }
