Hallo zusammen, ich habe ein rieeeesen Problem. Die Arrayvariable: char a[] = {'-', '0', '.', '1', '2', '3',} // -0.123 muss ich in einen float-Wert convertieren. Welche Möglichkeiten gibt es da? Hat jemand einen Ansatz für mich? Vieln Dank Sunset
Ich würde das ganze in einen String verwandeln und dann mit scanf (o.ä) zurückkonvertieren. Martin
NAME atof - convert a string to a double. SYNOPSIS #include <stdlib.h> double atof(const char *nptr); DESCRIPTION The atof() function converts the initial portion of the string pointed to by nptr to double. The behaviour is the same as strtod(nptr, (char **)NULL); except that atof() does not detect errors. RETURN VALUE The converted value. CONFORMING TO SVID 3, POSIX, BSD 4.3, ISO 9899 SEE ALSO atoi(3), atol(3), strtod(3), strtol(3), strtoul(3)
NAME strtod, strtof, strtold - convert ASCII string to floating point number SYNOPSIS #include <stdlib.h> double strtod(const char *nptr, char **endptr); float strtof(const char *nptr, char **endptr); long double strtold(const char *nptr, char **endptr); DESCRIPTION The strtod, strtof, and strtold functions convert the ini tial portion of the string pointed to by nptr to double, float, and long double representation, respectively. The expected form of the (initial portion of the) string is optional leading white space as recognized by is space(3), an optional plus (``+'') or minus sign (``-'') and then either (i) a decimal number, or (ii) a hexadeci mal number, or (iii) an infinity, or (iv) a NAN (not-a- number). A decimal number consists of a nonempty sequence of deci mal digits possibly containing a radix character (decimal point, locale dependent, usually ``.''), optionally fol lowed by a decimal exponent. A decimal exponent consists of an ``E'' or ``e'', followed by an optional plus or minus sign, followed by a non-empty sequence of decimal digits, and indicates multiplication by a power of 10. A hexadecimal number consists of a ``0x'' or ``0X'' fol lowed by a nonempty sequence of hexadecimal digits possi bly containing a radix character, optionally followed by a binary exponent. A binary exponent consists of a ``P'' or ``p'', followed by an optional plus or minus sign, fol lowed by a non-empty sequence of decimal digits, and indi cates multiplication by a power of 2. At least one of radix character and binary exponent must be present. An infinity is either ``INF'' or ``INFINITY'', disregard ing case. A NAN is ``NAN'' (disregarding case) optionally followed by `(', a sequence of characters, followed by ')'. The character string specifies in an implementation-dependent way the type of NAN. RETURN VALUE These functions return the converted value, if any. If endptr is not NULL, a pointer to the character after the last character used in the conversion is stored in the location referenced by endptr. If no conversion is performed, zero is returned and the value of nptr is stored in the location referenced by endptr. If the correct value would cause overflow, plus or minus HUGE_VAL (HUGE_VALF, HUGE_VALL) is returned (according to the sign of the value), and ERANGE is stored in errno. If the correct value would cause underflow, zero is returned and ERANGE is stored in errno. ERRORS ERANGE Overflow or underflow occurred. CONFORMING TO ANSI C describes strtod, C99 describes the other two func tions. SEE ALSO atof(3), atoi(3), atol(3), strtol(3), strtoul(3)
> The behaviour is the same as > > strtod(nptr, (char **)NULL); > > except that atof() does not detect errors. Deshalb sollte man besser gleich strtod nehmen.
oder einfach den Punkt im Array suchen und dann über die 10-er Potenzen ausrechnen, Vorzeichen prüfen und gegebenenfalls mit -1 multiplizieren.
Erstmal großen Dank für Eure Beiträge. Zur Zeit 'funktioniert' es mit der atof-Funktion. Da bekomme ich aber Rundungsfehler rein. Z.B. im Array steht(als ascii): '-0.1' atof macht daraus(als float) '-0.09999899'. Bei Ganzzahlen funktionierts richtig. Naja, das Wochenende muss auch genutzt werden. Andreas' Vorschlag ist auch eine Überlegung wert. Sunset
Die Rundungsfehler sind nun halt mal Systembedingt, da 0,1 eine unendliche Binärzahl ergibt. Ich nehme an, daß das eine 32 Bit Floating Bibliothek ist. Wenn du es genau haben willst, die Zahl als Festkommazahl nutzen (z.B. 1000 fach als integer). Gruß Thomas
> Zur Zeit 'funktioniert' es mit der atof-Funktion. Da bekomme ich > aber Rundungsfehler rein. Z.B. im Array steht(als ascii): '-0.1' > atof macht daraus(als float) '-0.09999899'. Das ist kein Fehler von atof, sondern eine immanente Eigenschaft von Fließkommazahlen. 0,1 ist im Dualsystem eine periodische Zahl. So wie man im Dezimalsystem den Wert 1/3 nicht exakt darstellen kann, so kann man im Dualsystem den Wert 1/5 und damit auch 1/10 nicht exakt darstellen.
Ich vergaß zu erwähnen, das ich mit Codevision füe den mega128 das Programm schreibe. Ich habe zum Vergleich mal die atof-Sequenz mit dem Keil-C166-Compiler(für 16bit) getestet, der löst perfekt in float auf.
Ich glaube eher, daß dessen atof den angezeigten Wert halt rundet, so
daß du es nicht siehst.
