1 | //Main SERVER
2 | #include <sys/types.h>
3 | #include <sys/socket.h>
4 | #include <netinet/in.h>
5 | #include <arpa/inet.h>
6 | #include <stdio.h>
7 | #include <unistd.h>
8 | #include <errno.h>
9 | #include <string.h>
10 | #include <stdlib.h>
11 | #include <sys/select.h>//use select() for multiplexing
12 | #include <sys/fcntl.h> // for non-blocking
13 |
14 | #define MAX_LENGTH 100000
15 | #define PORT 1901
16 |
17 | /* Select() params
18 | * int select(int n, fd_set *readfds, fd_set *writefds, fd_set *exceptfds, struct timeval *timeout);
19 | * FD_SET(int fd, fd_set *set);
20 | * FD_CLR(int fd, fd_set *set);
21 | * FD_ISSET(int fd, fd_set *set);
22 | * FD_ZERO(fd_set *set);
23 | */
24 |
25 | void error(char *message)
26 | {
27 | perror(message);
28 | exit(1);
29 | }
30 |
31 | int main()
32 | {
33 |
34 | // select parameters declared
35 | fd_set original_socket;
36 | fd_set original_stdin;
37 | fd_set readfds;
38 | fd_set writefds;
39 | struct timeval tv;
40 | int numfd, numfd2;
41 |
42 | // socket parameters declared
43 | int socket_fd_ob, socket_fd_hm;
44 | int bytes_read, bytes_sent;
45 | char address_length, address_length2;
46 | char recieve_data[MAX_LENGTH];
47 | char send_data[MAX_LENGTH];
48 | struct sockaddr_in server_address_ob, server_address_hm, client_address;
49 | int z = 0;
50 |
51 | //Socket creation done separately for both OB and HM communications
52 | if ((socket_fd_ob = socket(AF_INET, SOCK_DGRAM, 0)) == -1)
53 | {
54 | error("socket()");
55 | }
56 | if ((socket_fd_hm = socket(AF_INET, SOCK_DGRAM, 0)) == -1)
57 | {
58 | error("socket()");
59 | }
60 |
61 |
62 | fcntl(socket_fd_ob, F_SETFL, O_NONBLOCK); //set socket to non-blocking
63 | fcntl(socket_fd_hm, F_SETFL, O_NONBLOCK); //set socket to non-blocking
64 |
65 | // clear the set ahead of time
66 | FD_ZERO(&original_socket);
67 | FD_ZERO(&original_stdin);
68 | FD_ZERO(&readfds);
69 | FD_ZERO(&writefds);
70 |
71 | // add our descriptors to the set (0 - stands for STDIN)
72 | FD_SET(socket_fd_ob, &original_socket);//instead of 0 put socket_fd_ob
73 | FD_SET(socket_fd_ob, &readfds);
74 | FD_SET(0,&original_stdin);
75 | FD_SET(0, &writefds);
76 |
77 | // since we got s2 second, it's the "greater", so we use that for
78 | // the n param in select()
79 | numfd = socket_fd_ob + 1;
80 | numfd2 = socket_fd_hm + 1;
81 |
82 |
83 | // wait until either socket has data ready to be recv()d (timeout 10.5 secs)
84 | tv.tv_sec = 1;
85 | tv.tv_usec = 500000;
86 |
87 | server_address_ob.sin_family = AF_INET;
88 | server_address_ob.sin_port = htons(1901);
89 | server_address_ob.sin_addr.s_addr = inet_addr("127.0.0.3");
90 | bzero(&(server_address_ob.sin_zero),sizeof(server_address_ob));
91 |
92 | server_address_hm.sin_family = AF_INET;
93 | server_address_hm.sin_port = htons(1901);
94 | server_address_hm.sin_addr.s_addr = inet_addr("127.0.0.1");
95 | bzero(&(server_address_ob.sin_zero),sizeof(server_address_hm));
96 |
97 | // Bind socket to the particular addresses
98 |
99 | if (bind(socket_fd_ob,(struct sockaddr *)&server_address_ob, sizeof(struct sockaddr)) == -1)
100 | {
101 | error("bind()");
102 | }
103 |
104 | if (bind(socket_fd_hm,(struct sockaddr *)&server_address_hm, sizeof(struct sockaddr)) == -1)
105 | {
106 | error("bind()");
107 | }
108 |
109 | address_length = sizeof(struct sockaddr);
110 | address_length2 = sizeof(struct sockaddr);
111 |
112 | printf("\nMain server waiting for client to respond...\n");
113 | fflush(stdout);
114 |
115 | while (1)
116 | {
117 | readfds = original_socket;
118 | writefds = original_stdin;//problem
119 | int recieve = select(numfd, &readfds, &writefds,/*NULL,*/ NULL, &tv);
120 | int sent = select(numfd2, &readfds, &writefds,/*NULL,*/ NULL, &tv);
121 |
122 | if (recieve == -1 || sent == -1)
123 | {
124 | perror("select"); // error occurred in select()
125 | }
126 | else if (recieve == 0 || sent == 0)
127 | {
128 | printf("Timeout occurred! No data after 1.5 seconds.\n");
129 | }
130 | else
131 | {
132 | // one or both of the descriptors have data
133 | if (FD_ISSET(socket_fd_ob, &readfds)) //if set to read
134 | {
135 | FD_CLR(socket_fd_ob, &readfds);
136 | bytes_read = recvfrom(socket_fd_ob,recieve_data,MAX_LENGTH,0,(struct sockaddr *)&server_address_hm, &address_length);
137 |
138 | for (z = 0; z < bytes_read; ++z) {
139 | FD_ISSET(socket_fd_hm, &writefds);
140 | FD_CLR(socket_fd_hm, &writefds);
141 | //recvfrom speech recognition client and decide what to send to HM accordingly..
142 | send_data[bytes_read] = recieve_data[bytes_read];
143 | //block call, will wait till client enters something, before proceeding
144 | //send the corresponding to HM
145 | bytes_sent = sendto(socket_fd_hm,send_data,strlen(send_data)+1,0,(struct sockaddr *)&server_address_hm, &address_length2);
146 | fflush(stdout);
147 | }
148 | recieve_data[bytes_read] = '\0'; //add null to the end of the buffer
149 | send_data[bytes_read] = '\0'; //add null to the end of the buffer
150 |
151 | printf("\n(%s , %d) rcvd: %02x\n",inet_ntoa(server_address_hm.sin_addr),ntohs(server_address_hm.sin_port),recieve_data);
152 | printf("\n(%s , %d) sent: %02x\n",inet_ntoa(server_address_hm.sin_addr),ntohs(server_address_hm.sin_port),send_data);
153 | }
154 |
155 |
156 |
157 |
158 | } //end else
159 | }//end while
160 |
161 | close (socket_fd_ob);
162 | return 0;
163 | }
