1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.STD_LOGIC_ARITH.ALL;
4 | use IEEE.STD_LOGIC_UNSIGNED.ALL;
5 |
6 | entity sram_rx is
7 | port ( clk50 : in std_logic;
8 | sw : in std_logic_vector ( 2 downto 0);
9 | ledg : out std_logic_vector ( 7 downto 0);
10 | ledr : out std_logic_vector ( 7 downto 0);
11 |
12 | raddr : out std_logic_vector (17 downto 0);
13 | rdata : inout std_logic_vector (7 downto 0);
14 |
15 | ce : out std_logic;
16 | we : out std_logic;
17 | oe : out std_logic;
18 | lb : out std_logic;
19 | ub : out std_logic;
20 | rxd : in std_logic
21 | );
22 | end sram_rx;
23 |
24 | architecture behavioral of sram_rx is
25 |
26 | signal addr : std_logic_vector ( 17 downto 0);
27 | signal data_sw : std_logic_vector ( 7 downto 0);
28 | signal state : std_logic_vector ( 2 downto 0);
29 |
30 | signal rx_en : std_logic;
31 | signal rx_data : std_logic_vector (7 downto 0);
32 |
33 | signal cnt : integer range 0 to 25000000;
34 |
35 | component rs232_rx port(
36 | clk50 : in std_logic;
37 | rxd : in std_logic;
38 | rx_en : out std_logic;
39 | rx_data : out std_logic_vector (7 downto 0)
40 | );
41 | end component;
42 |
43 | begin
44 |
45 | rx: rs232_rx
46 | port map(
47 | clk50 => clk50,
48 | rxd => rxd,
49 | rx_en => rx_en,
50 | rx_data => rx_data
51 | );
52 |
53 | process (clk50)
54 | begin
55 | if rising_edge(clk50) then
56 | case state is
57 | --- idle state
58 | when "000" => rdata <= (others => 'Z');
59 |
60 | --- write state
61 | when "001" => raddr <= addr;
62 | rdata <= data_sw;
63 | ce <= '0';
64 | oe <= '1';
65 | we <= '1';
66 | lb <= '0';
67 | ub <= '0';
68 | state <= "010";
69 |
70 | when "010" => ce <= '1';
71 | we <= '0';
72 | state <= "011";
73 |
74 | when "011" => ce <= '0';
75 | rdata <= data_sw;
76 | state <= "000";
77 |
78 | --- read state
79 | when "100" => raddr <= addr;
80 | rdata <= (others => 'Z');
81 | ce <= '0';
82 | oe <= '0';
83 | we <= '1';
84 | lb <= '0';
85 | ub <= '0';
86 | state <= "101";
87 |
88 | when "101" => ce <= '1';
89 | we <= '1';
90 | state <= "110";
91 |
92 | when "110" => ce <= '0';
93 | oe <= '1';
94 | ledg <= rdata;
95 | state <= "000";
96 |
97 | when others => state <= "000";
98 | end case;
99 |
100 | if rx_en='1' then
101 | addr <= addr+1;
102 | data_sw <= rx_data;
103 | ledr <= rx_data;
104 | state <= "001";
105 | end if;
106 |
107 | if sw(0) = '1' then
108 | rdata <= (others => 'Z');
109 | raddr <= (others => '0');
110 | we <= '1';
111 | ce <= '1';
112 | oe <= '1';
113 | end if;
114 |
115 | if sw(1) = '1' then
116 | addr <= (others => '0');
117 | data_sw <= (others => '0');
118 | ledr <= (others => '0');
119 | ledg <= (others => '0');
120 | end if;
121 |
122 | if sw(2) = '1' and addr < 255 then
123 | if (cnt<2000000) then
124 | cnt <= cnt+1;
125 | else
126 | cnt <= 0;
127 | state <= "100";
128 | addr <=addr+1;
129 | end if;
130 | end if;
131 |
132 | end if;
133 | end process;
134 |
135 | end behavioral;
136 |
137 | ------------------------------------------------------
138 | library ieee;
139 | use ieee.std_logic_1164.all;
140 | use ieee.numeric_std.all;
141 |
142 | entity rs232_rx is
143 | generic(
144 | quarz_taktfrequenz : integer := 50000000;
145 | baudrate : integer := 19200
146 | );
147 |
148 | port(
149 | clk50 : in std_logic;
150 | rxd : in std_logic;
151 | rx_en : out std_logic;
152 | rx_data : out std_logic_vector (7 downto 0)
153 | );
154 | end rs232_rx;
155 |
156 | architecture behavioral of rs232_rx is
157 |
158 | type rx_state_t is (idle, busy, ready);
159 | signal rx_state : rx_state_t := idle;
160 |
161 | signal rxd_sr : std_logic_vector (3 downto 0) := "1111";
162 | signal rxsr : std_logic_vector (7 downto 0) := "00000000";
163 | signal rxbitcnt : integer range 0 to 9 := 9;
164 | signal rxcnt : integer range 0 to (quarz_taktfrequenz/baudrate)-1;
165 |
166 | begin
167 |
168 | process begin
169 | wait until rising_edge(clk50);
170 | rxd_sr <= rxd_sr(rxd_sr'left-1 downto 0) & rxd;
171 | rx_en <= '0';
172 |
173 | case rx_state is
174 | when idle => -- warten auf startbit
175 | if (rxd_sr(3 downto 2) = "10") then
176 | rxcnt <= ((quarz_taktfrequenz/baudrate)-1)/2;
177 | rxbitcnt <= 0;
178 | rx_state <= busy;
179 | end if;
180 |
181 | when busy =>
182 | if (rxbitcnt<9) then
183 | if(rxcnt<(quarz_taktfrequenz/baudrate)-1) then
184 | rxcnt <= rxcnt+1;
185 | else
186 | rxcnt <= 0;
187 | rxbitcnt <= rxbitcnt+1;
188 | rxsr <= rxd_sr(rxd_sr'left-1) & rxsr(rxsr'left downto 1);
189 | end if;
190 | else
191 | rx_state <= ready;
192 | end if;
193 |
194 | when ready =>
195 | rx_data <= rxsr;
196 | rx_state <= idle;
197 | rx_en <= '1';
198 | end case;
199 | end process;
200 |
201 | end behavioral;
