2x werden die Daten 128-254 ausgegeben vom SRAM statt 0-254, woran liegt das bitte ?
Gast #3950734
Hallo, guten Tag.
Hier habe ich mal einen anderen Weg genommen für das Beschreiben und
Lesen vom SRAM DE1.
Bei der Ausgabe werden 2x die Byte 128-254 gesendet und nicht 0-254?
Woran liegt das bitte. Die Daten wurden richtig gesendet.
Liegt es am Beschreiben des SRAM oder liegt es am Lesen vom SRAM ?
Danke.
Gruss
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity sram_rx_tx is
  port( clk        : in    std_logic;
        ledr       : out   std_logic_vector (7 downto 0);
        sw         : in    std_logic_vector (2 downto 0);
        sram_adr   : out   std_logic_vector (17 downto 0);
        sram_io    : inout std_logic_vector (15 downto 0);
        ub     : out  std_logic;
        lb     : out  std_logic;
        oe     : out  std_logic;
        ce     : out  std_logic;
        we     : out  std_logic;
        rxd    : in  std_logic;
        txd    : out  std_logic
end sram_rx_tx;
architecture behavioral of sram_rx_tx is
23
24
signal zustand    : std_logic_vector (2 downto 0)  := "000";
25
signal data_read  : std_logic_vector (15 downto 0) := "0000000000000000";
26
signal data_write : std_logic_vector (15 downto 0) := "0000000000000000";
27
signal read_write : std_logic := '0';  --(read = '1', write ='0')
28
29
signal sr_adr  : std_logic_vector (17 downto 0) := "000000000000000000";
30
signal data_w  : std_logic_vector (7 downto 0) := "00000000";
31
signal data_r  : std_logic_vector (7 downto 0) := "00000000";
32
33
signal rx_en   : std_logic;
34
signal rx_data : std_logic_vector (7 downto 0);
35
36
signal tx_start : std_logic;
37
signal tx_data  : std_logic_vector (7 downto 0);
38
39
signal cnt  : integer range 0 to 50000000;
40
signal test : std_logic;
41
42
component rs232_rx port(
43
  clk     : in  std_logic;
44
  rxd     : in  std_logic;
45
  rx_en   : out std_logic;
46
  rx_data : out std_logic_vector (7 downto 0)
47
48
end component;
49
50
component rs232_tx port(
51
  clk      : in  std_logic;
52
  txd      : out  std_logic;
53
  tx_start : in std_logic;
54
  tx_data  : in std_logic_vector (7 downto 0)
55
56
end component;
57
58
begin
59
rx: rs232_rx
60
port map(
61
  clk     => clk,
62
  rxd     => rxd,
63
  rx_en   => rx_en,
64
  rx_data => rx_data
65
66
67
tx: rs232_tx
68
port map(
69
  clk      => clk,
70
  txd      => txd,
71
  tx_start => tx_start,
72
  tx_data  => tx_data
73
74
75
sram_io   <= data_write when read_write='0' else (others=>'Z');
76
data_read <= sram_io;
77
78
ub <= '0';
79
lb <= '0';
80
81
process (clk)
82
begin
83
  if rising_edge (clk) then
84
    if (zustand = "001") then
85
      sram_adr   <= sr_adr;
86
      oe         <= '0';
87
      ce         <= '1';
88
      we         <= '1';
89
90
      read_write <= '0';
91
      data_write <= "00000000" & data_w;
92
      zustand    <= "010";
93
    elsif (zustand = "010") then
94
      sram_adr   <= sr_adr;
95
      oe         <= '0';
96
      ce         <= '0';
97
      we         <= '0';
98
99
      read_write <= '0';
100
101
      zustand    <= "000";
102
    end if;
103
104
    if (zustand = "011") then
105
      sram_adr   <= sr_adr;
106
      oe         <= '0';
107
      ce         <= '0';
108
      we         <= '1';
109
110
      read_write <= '1';
111
      zustand    <= "100";
112
    elsif (zustand = "100") then
113
      sram_adr   <= sr_adr;
114
      oe         <= '0';
115
      ce         <= '1';
116
      we         <= '1';
117
118
      read_write <= '0';
119
      data_r     <= data_read(7 downto 0);
120
      zustand    <= "000";
121
    end if;
122
123
     if rx_en='1' then
124
      sr_adr  <= sr_adr + 1;
125
      data_w  <= rx_data;
126
      ledr    <= rx_data;
127
      zustand <= "001";
128
    end if;
129
130
    if sw(0) = '1' then
131
      sram_io  <= (others => 'Z');
132
      sram_adr <= (others => '0');
133
      we       <= '1';
134
      ce       <= '1';
135
      oe       <= '1';
136
    end if;
137
138
    if sw(1) = '1' then
139
      sr_adr  <= (others => '0');
140
      data_w  <= (others => '0');
141
      data_r  <= (others => '0');
142
    end if;
143
144
     if sw(2)='1' and test='1' and  sr_adr < 255 then
145
      tx_start <= '1';
146
      zustand  <= "011";
147
      sr_adr   <= sr_adr+1;
148
      tx_data  <= data_r;
149
      test     <= '0';
150
    else
151
      tx_start<='0';
152
    end if;
153
154
     if (cnt > 1000000)  then
155
      cnt  <= 0;
156
      test <= '1';
157
    else
158
      cnt  <= cnt + 1;
159
    end if;
160
161
  end if;
162
end process;
163
end behavioral;
Gast #3950931
Glaskugel anwerf:
* stimmen die Pin-Assignments/-Contraints?
* welcher SRAM ist auf deinem Board (IS61WV25616EDBLL)?
* wie hoch ist clk?
* wie sehen deine Timing Constraints aus?
* was sagt die Simulation (vorzugsweise mit einem SRAM-Modell)?
Falls auf deinem Board ein IS61WV25616EDBLL ist solltest du das hier
lesen:
http://www.minimig.net/viewtopic.php?f=9&t=609
Bitte das hier mal lesen:
http://www.mikrocontroller.net/articles/Rechnen_in_VHDL
