1 | #include <errno.h>
2 | #include <sys/stat.h>
3 | #include <sys/times.h>
4 | #include <sys/unistd.h>
5 | #include <stdint.h>
6 |
7 | #include <stm32f4xx_usart.h>
8 |
9 | #ifndef UNUSED
10 | #define UNUSED(x) (void)x
11 | #endif
12 |
13 | #ifndef STDOUT_USART
14 | #define STDOUT_USART 1
15 | #endif
16 |
17 | #ifndef STDERR_USART
18 | #define STDERR_USART 2
19 | #endif
20 |
21 | #ifndef STDIN_USART
22 | #define STDIN_USART 1
23 | #endif
24 |
25 | #undef errno
26 | extern int errno;
27 |
28 | /*
29 | * A pointer to a list of environment variables and their values.
30 | * For a minimal environment, this empty list is adequate.
31 | */
32 | char *__env[1] = { 0 };
33 | char **environ = __env;
34 |
35 | int _write(int file, char *ptr, int len);
36 |
37 | void _exit(int status) {
38 | UNUSED(status);
39 |
40 | _write(1, "exit", 4);
41 | while (1) {
42 | ;
43 | }
44 | }
45 |
46 | int _close(int file) {
47 | UNUSED(file);
48 |
49 | return -1;
50 | }
51 |
52 | /*
53 | * Transfer control to a new process. Minimal implementation (for a system
54 | * without processes)
55 | */
56 | int _execve(char *name, char **argv, char **env) {
57 | UNUSED(name);
58 | UNUSED(argv);
59 | UNUSED(env);
60 |
61 | errno = ENOMEM;
62 | return -1;
63 | }
64 |
65 | /*
66 | * Create a new process. Minimal implementation (for a system without processes)
67 | */
68 | int _fork() {
69 | errno = EAGAIN;
70 | return -1;
71 | }
72 | /*
73 | * Status of an open file. Minimal implementation.
74 | */
75 | int _fstat(int file, struct stat *st) {
76 | UNUSED(file);
77 |
78 | st->st_mode = S_IFCHR;
79 | return 0;
80 | }
81 |
82 | /*
83 | * Process-ID; this is sometimes used to generate strings unlikely to conflict
84 | * with other processes. Minimal implementation, for a system without processes.
85 | */
86 | int _getpid() {
87 | return 1;
88 | }
89 |
90 | /*
91 | * Query whether output stream is a terminal. For consistency with the other
92 | * minimal implementation.
93 | */
94 | int _isatty(int file) {
95 | UNUSED(file);
96 |
97 | switch (file) {
98 | case STDOUT_FILENO:
99 | case STDERR_FILENO:
100 | case STDIN_FILENO:
101 | return 1;
102 | default:
103 | //errno = ENOTTY;
104 | errno = EBADF;
105 | return 0;
106 | }
107 | }
108 |
109 | /*
110 | * Send a signal. Minimal implementation.
111 | */
112 | int _kill(int pid, int sig) {
113 | UNUSED(pid);
114 | UNUSED(sig);
115 |
116 | errno = EINVAL;
117 | return (-1);
118 | }
119 |
120 | /*
121 | * Establish a new name for an existing file. Minimal implementation.
122 | */
123 | int _link(char *old, char *new) {
124 | UNUSED(old);
125 | UNUSED(new);
126 |
127 | errno = EMLINK;
128 | return -1;
129 | }
130 |
131 | /*
132 | * Set position in a file. Minimal implementation.
133 | */
134 | int _lseek(int file, int ptr, int dir) {
135 | UNUSED(file);
136 | UNUSED(ptr);
137 | UNUSED(dir);
138 |
139 | return 0;
140 | }
141 |
142 | /*
143 | * Increase program data space. Malloc and related functions depend on this.
144 | */
145 | caddr_t _sbrk(int incr) {
146 |
147 | extern char _ebss; // Defined by the linker
148 | static char *heap_end;
149 | char *prev_heap_end;
150 |
151 | if (heap_end == 0) {
152 | heap_end = &_ebss;
153 | }
154 | prev_heap_end = heap_end;
155 |
156 | /** FIX **/
157 | char * stack = (char*) __get_MSP();
158 | if (heap_end + incr > stack){
159 | _write (STDERR_FILENO, "Heap and stack collision\n", 25);
160 | errno = ENOMEM;
161 | return (caddr_t) - 1;
162 | //abort ();
163 | }
164 |
165 | heap_end += incr;
166 | return (caddr_t) prev_heap_end;
167 |
168 | }
169 |
170 | /*
171 | * Read a character to a file. `libc' subroutines will use this system routine
172 | * for input from all files, including stdin.
173 | * Returns -1 on error or blocks until the number of characters have been read.
174 | */
175 | int _read(int file, char *ptr, int len) {
176 | int n;
177 | int num = 0;
178 | switch (file) {
179 | case STDIN_FILENO:
180 | for (n = 0; n < len; n++) {
181 | #if STDIN_USART == 1
182 | while ((USART1->SR & USART_FLAG_RXNE) == (uint16_t)RESET) {}
183 | char c = (char)(USART1->DR & (uint16_t)0x01FF);
184 | #elif STDIN_USART == 2
185 | // while ((USART2->ISR & USART_FLAG_RXNE) == (uint16_t) RESET) {}
186 | // char c = (char) (USART2->TDR & (uint16_t) 0x01FF);
187 | #elif STDIN_USART == 3
188 | // while ((USART3->ISR & USART_FLAG_RXNE) == (uint16_t)RESET) {}
189 | // char c = (char)(USART3->TDR & (uint16_t)0x01FF);
190 | #endif
191 | *ptr++ = c;
192 | num++;
193 | }
194 | break;
195 | default:
196 | errno = EBADF;
197 | return -1;
198 | }
199 | return num;
200 | }
201 |
202 | /*
203 | * Status of a file (by name). Minimal implementation.
204 | * int _EXFUN(stat,( const char *__path, struct stat *__sbuf ));
205 | */
206 | int _stat(const char *filepath, struct stat *st) {
207 | UNUSED(filepath);
208 |
209 | st->st_mode = S_IFCHR;
210 | return 0;
211 | }
212 |
213 | /*
214 | * Timing information for current process. Minimal implementation.
215 | */
216 | clock_t _times(struct tms *buf) {
217 | UNUSED(buf);
218 |
219 | return -1;
220 | }
221 |
222 | /*
223 | * Remove a file's directory entry. Minimal implementation.
224 | */
225 | int _unlink(char *name) {
226 | UNUSED(name);
227 |
228 | errno = ENOENT;
229 | return -1;
230 | }
231 |
232 | /*
233 | * Wait for a child process. Minimal implementation.
234 | */
235 | int _wait(int *status) {
236 | UNUSED(status);
237 |
238 | errno = ECHILD;
239 | return -1;
240 | }
241 |
242 | /*
243 | * Write a character to a file. `libc' subroutines will use this system routine
244 | * for output to all files, including stdout.
245 | * Returns -1 on error or number of bytes sent.
246 | */
247 | int _write(int file, char *ptr, int len) {
248 | int n;
249 |
250 | switch (file) {
251 | case STDOUT_FILENO: /*stdout*/
252 | for (n = 0; n < len; n++) {
253 | while ((USART1->SR & USART_FLAG_TXE) == (uint16_t)RESET) {
254 | //USART1->DR = (*ptr++ & (uint16_t)0x01FF);
255 | }
256 | USART1->DR = (*ptr++ & (uint16_t)0x01FF);
257 | }
258 | break;
259 | case STDERR_FILENO: /* stderr */
260 | for (n = 0; n < len; n++) {
261 |
262 | }
263 | break;
264 | default:
265 | errno = EBADF;
266 | return -1;
267 | }
268 | return len;
269 | }
