Dann probier's mal damit - ich lese 4 Kanäle mit DMA auf einem
STM32F407VG (Disco)aus und schreibe sie in eine Struktur.
* @file ADC/ADC1_DMA/main.c
* @author DD4DA
* @version V1.0
* @date 17.06.2013
* @brief Main program body
* @attention
* The Program demonstrate how the ADC works with DMA on a
STM32F407Discovery
* using ADC1. The used CMSIS Lib is version 1.0.
* The ADC1 is configured to use Regular Groups by using DMA2,Stream0.
* <h2><center>DD4DA</center></h2>
#include <stdio.h>
#include "stm32f4xx.h"
#include "adc1.h"
#define ADC1_DR_Address ((uint32_t) 0x4001204C ) // ADC1 @
$4001:2000 + register offset $4C == $4001244C <-- ADC1 Data Register
ADC_InitTypeDef ADC_InitStructure;
ADC_CommonInitTypeDef ADC_CommonInitStructure;
DMA_InitTypeDef DMA_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
double Temperature,Voltage;
// Variables for calculating Temperatur and Voltage
#define V25 0.760
#define AVG_SLOPE 25.0
#define Num_used_ADC_Channels 5
// The number of ADC channels that will be used.
volatile uint16_t ADCBuffer[Num_used_ADC_Channels + 1] = { 0 , 0 , 0 , 0
, 0, 0xAA }; // DMA Buffers - one halfword used by every ADC-Channel.
enum _ADC_CHAN_BUFF_ORDER_ { CH0 = 1, CH1 = 2 , TEMP = 3 , VREF = 4,
VBAT =5 };
void Init_ADC ( void )
// ############## ADC
// ---------- Configure PB0 and PB1 (ADC Channel1 and ADC Channel2 )
as analog input ------------------
// GPIOB function block clock enable
RCC_APB2PeriphClockCmd ( RCC_APB2Periph_ADC1, ENABLE );
RCC_AHB1PeriphClockCmd ( RCC_AHB1Periph_GPIOB, ENABLE );
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1; //
Init Pin 8 and A1
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
GPIO_Init ( GPIOB, &GPIO_InitStructure ); // Init
GPIO-PORTA as Analog input
// DMA2 Stream0 configuration
// Enable DMA2 clock
RCC_AHB1PeriphClockCmd ( RCC_AHB1Periph_DMA2, ENABLE );
DMA_DeInit ( DMA2_Stream0 );
DMA_InitStructure.DMA_Channel = DMA_Channel_0;
DMA_InitStructure.DMA_PeripheralBaseAddr =
(uint32_t)ADC1_DR_Address;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADCBuffer;
DMA_InitStructure.DMA_DIR =
DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = Num_used_ADC_Channels;
DMA_InitStructure.DMA_PeripheralInc =
DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize =
DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize =
DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStructure.DMA_FIFOThreshold =
DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst =
DMA_PeripheralBurst_Single;
DMA_Init ( DMA2_Stream0, &DMA_InitStructure );
DMA_Cmd ( DMA2_Stream0, ENABLE );
// ------------------ ADC1 configuration
ADC_DeInit();
ADC_CommonInitStructure.ADC_Mode =
ADC_Mode_Independent;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
ADC_CommonInitStructure.ADC_DMAAccessMode =
ADC_DMAAccessMode_Disabled;
ADC_CommonInitStructure.ADC_TwoSamplingDelay =
ADC_TwoSamplingDelay_20Cycles;
ADC_CommonInit(&ADC_CommonInitStructure);
// ########################### ADC1 Init
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge =
ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_ExternalTrigConv = 0;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfConversion =
ADC_Init(ADC1, &ADC_InitStructure);
ADC_DMACmd ( ADC1, ENABLE ); /* Enable ADC1 DMA */
// ######### ADC1 regular conversation mode configuration
// ADC , CHANNEL, DMA
MemoryOrder, SampleTime
ADC_RegularChannelConfig(ADC1, ADC_Channel_8, CH0,
ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_9, CH1,
ADC_RegularChannelConfig(ADC1, ADC_Channel_Vbat, VBAT,
ADC_RegularChannelConfig(ADC1, ADC_Channel_TempSensor, TEMP,
ADC_RegularChannelConfig(ADC1, ADC_Channel_Vrefint, VREF,
ADC_VBATCmd ( ENABLE ); // Enable VBAT
at channel 18
ADC_TempSensorVrefintCmd ( ENABLE ); // Enable
TempSensor and Vrefint at channels 16 and 17
ADC_DMARequestAfterLastTransferCmd ( ADC1, ENABLE ); // Enable DMA
request after last transfer (Single-ADC mode)
ADC_Cmd ( ADC1, ENABLE ); // Enable ADC1
ADC_SoftwareStartConv ( ADC1 ); // Start ADC1
Software Conversion
return;
