1 | /*
2 | *********************************************************
3 | Filename: SRF05.h
4 | Version: 1.0
5 | Date: 01.11.2012
6 | Author: Jascha Breithaupt
7 | Website: www.jaybe-stuff.de
8 | *********************************************************
9 | Description:
10 | ------------
11 | This library is to use one Devantech SRF04/05 (or similar) by simply
12 | including this header to your program.
13 | See data sheet (ger/eng):
14 | http://www.robotikhardware.de/download/srf05doku.pdf
15 | *********************************************************
16 | Features:
17 | ---------
18 | Mode 1: - is fully compatible with SRF04/US-020/HC-SR04
19 | - uses 2 pins (echo/trigger)
20 | Mode 2: - uses 1 pin (e.g. PD2/INT0)
21 | Output: - measured time (µs)
22 | - distance in cm
23 | - distance in inch
24 | *********************************************************
25 | How to use:
26 | -----------
27 | 1. Include "SRF05.h" in your code
28 | 2. Check settings:
29 | choose mode [1/2]
30 | configure pins (e.g. PORTD/DDRD/PD2)
31 | define ISRs (e.g. INT0_vect/TIMER0_COMP_vect)
32 | define CPU-clock (e.g. 16000000UL -> UL: UnsignedLong)
33 | 3. Initialize the sensor in your code:
34 | SRF05_INIT();
35 | 4. Now you can get the data from your SRF05:
36 | value/time in µs: SRF05_VALUE();
37 | distance in cm: SRF05_CM();
38 | distance in inch: SRF05_INCH();
39 |
40 | *********************************************************
41 | Code Example:
42 | -------------
43 | #define F_CPU 16000000UL
44 |
45 | #include <avr/io.h>
46 | #include <avr/interrupt.h>
47 | #include <util/delay.h>
48 | #include "SRF05.h"
49 |
50 | int main(void)
51 | {
52 | SRF05_INIT();
53 | uint16_t distance = 0;
54 |
55 | while(1)
56 | {
57 | distance = SRF05_VALUE();
58 | distance = SRF05_CM();
59 | distance = SRF05_INCH();
60 | }
61 | }
62 | *********************************************************
63 | Notes:
64 | ------
65 | - Tested with Atmel ATMEGA32 @ 16MHz and Atmel Studio 6 SP1
66 | - To use another INT or TIMER you have to fit registers!
67 | *********************************************************
68 | */
69 |
70 | /* ***************************************************** */
71 | /* S E T T I N G S */
72 | /* ***************************************************** */
73 | // CHOOSE MODE
74 | const uint8_t SRF05_MODE = 2;
75 | /* ***************************************************** */
76 | // CONFIGURE THESE FOR MODE 1
77 | #define SRF05_TPORT PORTD //
78 | #define SRF05_TREGISTER DDRD // TRIGGER
79 | #define SRF05_TPIN PD6 //
80 |
81 | #define SRF05_EPORT PORTD //
82 | #define SRF05_EREGISTER DDRD // ECHO
83 | #define SRF05_EPIN PD2 //
84 | /* ***************************************************** */
85 | // CONFIGURE THESE FOR MODE 2
86 | #define SRF05_TEPORT PORTD //
87 | #define SRF05_TEREGISTER DDRD // TRIGGER/ECHO
88 | #define SRF05_TE PD2 //
89 | /* ***************************************************** */
90 | // DEFINE INTERRUPT/TIMER ISR
91 | #define SRF05_INT INT0_vect
92 | #define SRF05_TIMER TIMER0_COMP_vect
93 | /* ***************************************************** */
94 | // DEFINE CPU
95 | #ifndef F_CPU
96 | #define F_CPU 16000000UL
97 | #endif
98 | #ifndef XTAL
99 | #define XTAL 16000000UL
100 | #endif
101 | /* ***************************************************** */
102 | /* E N D S E T T I N G S */
103 | /* ***************************************************** */
104 | #pragma once // MS-compiler
105 | #include <util/delay.h>
106 | #pragma once
107 | #include <avr/interrupt.h>
108 |
109 | volatile uint16_t usec = 0; // save pulse length in µs
110 | volatile uint8_t intocc = 0; // indicate if interrupt has occurred
111 | volatile uint8_t meascomp = 0; // indicate that measurement is complete
112 | /* ***************************************************** */
113 | /* ***************************************************** */
114 |
115 |
116 | // INITIALIZE SRF05
117 | void SRF05_INIT()
118 | {
119 | // SETUP TIMER
120 | TCCR0 = (1 << WGM01); // mode 2: CTC of Timer0
121 | OCR0 = ((F_CPU/8)/100000)-1; // ((16000000 / 8 ) / 100000) -1 = 19 -> 155 steps = interrupt every 10µs
122 | TIMSK |= (1 << OCIE0); // Enable Compare Match interrupt
123 | TCNT0 = 0; // set timer to 0
124 |
125 | // SETUP INTERRUPT
126 | GICR |= (1 << INT0); // external interrupt mask register INT0
127 | MCUCR = (1 << ISC01) | (1 << ISC00); // trigger on rising edge
128 |
129 | // SETUP PINS
130 | if(SRF05_MODE == 1)
131 | {
132 | SRF05_TREGISTER |= (1 << SRF05_TPIN); // set trigger pin to output
133 | SRF05_EREGISTER &= ~(1 << SRF05_EPIN); // set echo pin/INT0 as input
134 | }
135 | if(SRF05_MODE == 2) // might be deleted
136 | {
137 | SRF05_TEREGISTER |= (1 << SRF05_TE); // set pin to output
138 | }
139 | }
140 |
141 | // GET DISTANCE VALUE (µs)
142 | uint16_t SRF05_VALUE()
143 | {
144 | usec = 0; // reset microseconds counter variable
145 | TCNT0 = 0; // set timer to 0
146 |
147 | // TRIGGER MEASUREMENT
148 | if(SRF05_MODE == 1)
149 | {
150 | SRF05_TPORT |= (1 << SRF05_TPIN); // set trigger pin to 1
151 | _delay_us(10); // minimum 10µs trigger signal
152 | SRF05_TPORT &= ~(1 << SRF05_TPIN); // set trigger pin to 0
153 | }
154 | if(SRF05_MODE == 2)
155 | {
156 | _delay_ms(50); // ensure the ultrasonic "beep" has faded away
157 | SRF05_TEREGISTER |= (1 << SRF05_TE); // set pin to output
158 | SRF05_TEPORT |= (1 << SRF05_TE); // set pin to 1
159 | _delay_us(10);
160 | SRF05_TEPORT &= ~(1 << SRF05_TE); // set pin to 0
161 | SRF05_TEREGISTER &= ~(1 << SRF05_TE); // set pin to input
162 | _delay_us(800); // wait for SRF to change from trigger to echo
163 | }
164 |
165 | // TRIGGER INT0 ON RISING EDGE
166 | MCUCR = (1 << ISC01) | (1 << ISC00);
167 |
168 | // ENABLE INTERRUPTS
169 | sei();
170 |
171 | // WAIT UNTIL MEASUREMENT IS COMPLETE
172 | while(meascomp != 1){}
173 |
174 | // DISABLE INTERRUPTS
175 | cli();
176 |
177 | meascomp = 0; // reset
178 |
179 | return usec; // value;
180 | }
181 |
182 | // GET DISTANCE IN CM
183 | uint16_t SRF05_CM()
184 | {
185 | if(SRF05_MODE == 1){return SRF05_VALUE() / 58;}
186 | if(SRF05_MODE == 2){return SRF05_VALUE() / 58;} // 29? -> data sheet
187 | }
188 |
189 | // GET DISTANCE IN INCH
190 | uint16_t SRF05_INCH()
191 | {
192 | if(SRF05_MODE == 1){return SRF05_VALUE() / 148;}
193 | if(SRF05_MODE == 2){return SRF05_VALUE() / 148;} // 74? -> data sheet
194 | }
195 |
196 | // EXTERNAL INTERRUPT
197 | ISR(SRF05_INT)
198 | {
199 |
200 | if(intocc == 0)
201 | { // INTERRUPT ON RISING EDGE
202 | TCCR0 |= (1 << CS01); // start Timer0 with prescaler 8
203 |
204 | // TRIGGER INT0 ON FALLING EDGE
205 | MCUCR = (1 << ISC01) | (0 << ISC00); // EICRA = External Interrupt Control Register A
206 |
207 | intocc = 1; // to indicate, that an interrupt has already occurred
208 | }
209 | else
210 | { // INTERRUPT ON FALLING EDGE
211 | TCCR0 &= ~(1<<CS01); // stop Timer0
212 |
213 | intocc = 0; // reset variable
214 | meascomp = 1; // variable to indicate end of measurement
215 | }
216 | }
217 |
218 | //INTERRUPT EVERY 10µS
219 | ISR(SRF05_TIMER)
220 | {
221 | usec += 10;
222 | }
