1 | using System;
2 | using System.Collections.Generic;
3 | using System.ComponentModel;
4 | using System.Data;
5 | using System.Linq;
6 | using System.Text;
7 | using System.IO.Ports;
8 |
9 | namespace ConsoleApplication1
10 | {
11 | public delegate void MenuFnct();
12 | public struct MenuEntry
13 | {
14 | public String Text;
15 | public MenuFnct Function;
16 | }
17 | class Program
18 | {
19 | static void Main(string[] args)
20 | {
21 | //RS232 Initialisierung
22 | SerialPort serialport = new SerialPort();
23 | serialport.BaudRate = 19200;
24 | serialport.Parity = Parity.None;
25 | serialport.DataBits = 8;
26 | serialport.StopBits = StopBits.One;
27 | serialport.RtsEnable = false;
28 | serialport.ReadTimeout = 1000;
29 | serialport.WriteTimeout = 1000;
30 | serialport.PortName = "COM4";
31 | serialport.Open();
32 | //Ende RS232
33 |
34 | int len = 0;
35 | // Variable vom Typ des Delegaten
36 | MenuEntry[] MainMenu = new MenuEntry[4];
37 | MainMenu[0].Text = "Datei";
38 | MainMenu[1].Text = "Bearbeiten";
39 | MainMenu[2].Text = "Ansicht";
40 | MainMenu[3].Text = "Beenden";
41 | MainMenu[0].Function = Menu0.DateiMenu;
42 | MainMenu[1].Function = Menu0.BearbeitenMenu;
43 | MainMenu[2].Function = Menu0.AnsichtMenu;
44 | MainMenu[3].Function = Menu0.Ende;
45 | for (int i = 0; i < MainMenu.Length; i++)
46 | len += System.Runtime.InteropServices.Marshal.SizeOf(MainMenu[i]);
47 | len /= System.Runtime.InteropServices.Marshal.SizeOf(typeof(MenuEntry));
48 | HandleMenu("Hauptmenue", ref MainMenu, len);
49 | }
50 |
51 | static void HandleMenu(String MenuTitle, ref MenuEntry[] Menu, int MenuSize)
52 | {
53 | int i;
54 | int Auswahl=0;
55 | MenuFnct sel;
56 |
57 | do
58 | {
59 |
60 | // Eingabe der Operation
61 |
62 | Console.Clear();
63 | Console.WriteLine(MenuTitle);
64 | Console.WriteLine("Bitte waehlen:");
65 | for (i = 0; i < MenuSize; i++)
66 | {
67 | Console.WriteLine(i+1 + " " + Menu[i].Text);
68 | }
69 | Auswahl = Convert.ToInt16(Console.ReadLine().ToUpper());
70 | // In Abhängigkeit von der Wahl des Anwenders wird die Variable 'sel'
71 | // mit einem Zeiger auf die auszuführende Methode initialisiert
72 | if (Auswahl < 1 || Auswahl > MenuSize)
73 | {
74 | do
75 | {
76 | Console.WriteLine("Ungültige Eingabe");
77 | Console.WriteLine("Bitte waehlen:");
78 | Auswahl = Convert.ToInt16(Console.ReadLine().ToUpper());
79 | } while (Auswahl < 1 || Auswahl > MenuSize);
80 | }
81 | else
82 | {
83 | Auswahl--;
84 | Console.Clear();
85 | sel = new MenuFnct(Menu[Auswahl].Function);
86 |
87 | sel();
88 | Console.WriteLine("----------------------------------");
89 | Console.WriteLine("Zum Beenden F12 drücken, Weiter: beliebige Taste druecken");
90 | }
91 | } while (Console.ReadKey(true).Key != ConsoleKey.F12);
92 |
93 | }
94 | class Menu0
95 | {
96 | public static void DateiMenu()
97 | {
98 | int len = 0;
99 | // Variable vom Typ des Delegaten
100 | MenuEntry[] DateiMenu = new MenuEntry[4];
101 | DateiMenu[0].Text = "Neu";
102 | DateiMenu[1].Text = "Oeffnen";
103 | DateiMenu[2].Text = "Speichern";
104 | DateiMenu[3].Text = "Zurueck";
105 | DateiMenu[0].Function = Menu1.New;
106 | DateiMenu[1].Function = Menu1.Open;
107 | DateiMenu[2].Function = Menu1.Save;
108 | DateiMenu[3].Function = Menu1.Back; //"0" geht hier nicht
109 | for (int i = 0; i < DateiMenu.Length; i++)
110 | len += System.Runtime.InteropServices.Marshal.SizeOf(DateiMenu[i]);
111 | len /= System.Runtime.InteropServices.Marshal.SizeOf(typeof(MenuEntry));
112 | HandleMenu("Hauptmenue", ref DateiMenu, len);
113 | }
114 | public static void BearbeitenMenu()
115 | {
116 | int len = 0;
117 | // Variable vom Typ des Delegaten
118 | MenuEntry[] BearbeitenMenu = new MenuEntry[4];
119 | BearbeitenMenu[0].Text = "Ausschneiden";
120 | BearbeitenMenu[1].Text = "Kopieren";
121 | BearbeitenMenu[2].Text = "Einsetzen";
122 | BearbeitenMenu[3].Text = "Zurueck";
123 | BearbeitenMenu[0].Function = Menu2.Cut;
124 | BearbeitenMenu[1].Function = Menu2.Copy;
125 | BearbeitenMenu[2].Function = Menu2.Paste;
126 | BearbeitenMenu[3].Function = Menu2.Back; //"0" geht hier nicht
127 | for (int i = 0; i < BearbeitenMenu.Length; i++)
128 | len += System.Runtime.InteropServices.Marshal.SizeOf(BearbeitenMenu[i]);
129 | len /= System.Runtime.InteropServices.Marshal.SizeOf(typeof(MenuEntry));
130 | HandleMenu("Hauptmenue", ref BearbeitenMenu, len);
131 | }
132 | public static void AnsichtMenu()
133 | {
134 |
135 | }
136 | public static void Ende()
137 | {
138 |
139 | }
140 | }
141 | class Menu1
142 | {
143 | public static void New()
144 | {
145 | Console.WriteLine("Funktion 'Neu' ausgewaehlt");
146 | }
147 | public static void Open()
148 | {
149 | Console.WriteLine("Funktion 'Oeffnen' ausgewaehlt");
150 | }
151 | public static void Save()
152 | {
153 | Console.WriteLine("Funktion 'Speichern' ausgewaehlt");
154 | }
155 | public static void Back()
156 | {
157 | Console.WriteLine("Funktion 'Zurueck' ausgewaehlt");
158 |
159 | }
160 | }
161 |
162 | class Menu2
163 | {
164 | public static void Cut()
165 | {
166 | Console.WriteLine("Funktion 'Ausschneiden' ausgewaehlt");
167 | }
168 | public static void Copy()
169 | {
170 | Console.WriteLine("Funktion 'Kopieren' ausgewaehlt");
171 | }
172 | public static void Paste()
173 | {
174 | Console.WriteLine("Funktion 'Einfuegen' ausgewaehlt");
175 | }
176 | public static void Back()
177 | {
178 | Console.WriteLine("Funktion 'Zurueck' ausgewaehlt");
179 |
180 | }
181 | }
182 |
183 | }
184 | }
