Guten Abend,
ich habe nun schon einige Projekte auf dem MSP430G2553 realisiert und
wollte mich nun mal mit I2C befassen. Dazu habe ich die Beispielcodes
von TI ausprobiert, unter anderem den hier:
1 | #include <msp430.h>
2 |
3 | unsigned char TXData;
4 | unsigned char TXByteCtr;
5 |
6 | int main(void)
7 | {
8 | WDTCTL = WDTPW + WDTHOLD; // Stop WDT
9 | P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0
10 | P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0
11 | UCB0CTL1 |= UCSWRST; // Enable SW reset
12 | UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
13 | UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
14 | UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz
15 | UCB0BR1 = 0;
16 | UCB0I2CSA = 0x48; // Slave Address is 048h
17 | UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
18 | IE2 |= UCB0TXIE; // Enable TX interrupt
19 |
20 | TXData = 0x00; // Holds TX data
21 |
22 | while (1)
23 | {
24 | TXByteCtr = 1; // Load TX byte counter
25 | while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
26 | UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition
27 | __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts
28 | // Remain in LPM0 until all data
29 | // is TX'd
30 | TXData++; // Increment data byte
31 | }
32 | }
33 |
34 | //------------------------------------------------------------------------------
35 | // The USCIAB0TX_ISR is structured such that it can be used to transmit any
36 | // number of bytes by pre-loading TXByteCtr with the byte count.
37 | //------------------------------------------------------------------------------
38 | #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
39 | #pragma vector = USCIAB0TX_VECTOR
40 | __interrupt void USCIAB0TX_ISR(void)
41 | #elif defined(__GNUC__)
42 | void __attribute__ ((interrupt(USCIAB0TX_VECTOR))) USCIAB0TX_ISR (void)
43 | #else
44 | #error Compiler not supported!
45 | #endif
46 | {
47 | if (TXByteCtr) // Check TX byte counter
48 | {
49 | UCB0TXBUF = TXData; // Load TX buffer
50 | TXByteCtr--; // Decrement TX byte counter
51 | }
52 | else
53 | {
54 | UCB0CTL1 |= UCTXSTP; // I2C stop condition
55 | IFG2 &= ~UCB0TXIFG; // Clear USCI_B0 TX int flag
56 | __bic_SR_register_on_exit(CPUOFF); // Exit LPM0
57 | }
58 | }
Die SDA und SCL Leitungen (P1.6 und P1.7) habe ich mir auf einem
Oszilloskop angeguckt und festgestellt das lediglich ununterbrochen die
Slave Addresse (0x48) gesendet wird, aber nicht das zu sendende Byte
(0x00 ++).
Interpretiere ich da etwas falsch oder muss ich den TI Sourcecode noch
abändern?
Beste Grüße,
Michael
