1 | #include <msp430.h>
2 | #include "init.h"
3 |
4 | unsigned char *pTXData = 0x0; // Pointer to TX data
5 | unsigned char TXByteCounter = 0;
6 | unsigned char *pRXData = 0x0; // Pointer to RX data
7 | unsigned char RXByteCounter = 0;
8 | volatile unsigned int TEMP = 0;
9 | volatile float celsius = 0;
10 |
11 | void receive();
12 | void transmit();
13 | void i2c_master_receiver();
14 | void i2c_master_transmitter()
15 |
16 | int main(void)
17 | {
18 | msp430fr5729_ports();
19 | msp430fr5729_clock();
20 |
21 | //Transmit
22 | i2c_master_transmitter();
23 | __enable_interrupt();
24 | transmit();
25 |
26 | //Receive
27 | __disable_interrupt();
28 | i2c_master_receiver();
29 | __enable_interrupt();
30 |
31 |
32 |
33 | while(1)
34 | {
35 | receive();
36 | }
37 |
38 | }
39 |
40 |
41 | //===================================================================================//
42 | // ISR2: USCIB0_ISR
43 | //===================================================================================//
44 | #pragma vector = USCI_B0_VECTOR
45 | __interrupt void USCIB0_ISR(void)
46 | {
47 | switch(__even_in_range(UCB0IV,12))
48 | {
49 | case 0x04:
50 | UCB0CTLW0 |= UCTXSTT; // Resend start if NACK
51 | break; // Vector 4: NACKIFG break;
52 | case 0x16:
53 | RXByteCounter--; // Decrement RX byte counter
54 |
55 | if (RXByteCounter)
56 | {
57 | *pRXData++= UCB0RXBUF; // Multiple bytes left to receive
58 | }
59 | else
60 | {
61 | *pRXData= UCB0RXBUF; // Last byte to be received
62 | __bic_SR_register_on_exit(LPM0_bits); // Exit LPM0
63 | RXFlag = FLAG_SUCCESS; // Set Data Received RX Flag to success
64 | }
65 |
66 | if(RXByteCounter == 1) // Only one byte left?
67 | UCB0CTL1 |= UCTXSTP; // Generate I2C stop condition
68 | // If reading only 1 byte, stop condition
69 | // should have already been sent
70 | // Receive and calculate temperature
71 | slave_temperature = i2c_Data_From_Slave[1] << 8 | i2c_Data_From_Slave[0];
72 | celsius = ((slave_temperature-2730)/10);
73 | break; // Vector 24: RXIFG0 break;
74 |
75 | case 0x18:
76 | if (TXByteCounter) // If there's something to transmit
77 | {
78 | UCB0TXBUF = 0x08;*pTXData++; // Load TX buffer
79 | TXByteCounter--; // Decrement TX byte counter
80 | TXFlag = FLAG_SUCCESS;
81 | }
82 | else
83 | {
84 | UCB0CTL1 |= UCTXSTP; // I2C stop condition
85 | UCB0IFG &= ~UCTXIFG; // Clear USCI_B0 TX int flag
86 | __bic_SR_register_on_exit(LPM0_bits); // Exit LPM0
87 | TXFlag = FLAG_SUCCESS;
88 | }
89 |
90 | break; // Vector 26: TXIFG0 break;
91 | default: break;
92 | }
93 | }
94 |
95 |
96 | //===================================================================================//
97 | // FUNCTION: i2c_MASTER_TRANSMITTER
98 | //===================================================================================//
99 | void i2c_master_transmitter()
100 | {
101 | UCB0CTL1 |= UCSWRST; // Enable SW reset
102 | UCB0CTLW0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
103 | UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
104 | UCB0BR0 = 0; // fSCL = SMCLK/256 ~ 100kHz
105 | UCB0BR1 = 1; // Buad Rate Prescalar = UCB1BR1 * 256 + UCB1BR0
106 | UCB0I2CSA = i2c_BATTERY_ADDRESS; // Assign Slave Address
107 | UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
108 | UCB0IE |= UCTXIE + UCRXIE + UCNACKIE; // Enable TX, RX, NACK interrupt
109 | }
110 |
111 | //===================================================================================//
112 | // FUNCTION: TRANSMIT
113 | //===================================================================================//
114 | void transmit()
115 | {
116 | __delay_cycles(1000); // Delay between transmissions
117 | TXByteCounter = 1; // Load TX byte counter
118 | while (UCB0CTLW0 & UCTXSTP); // Ensure stop condition got sent
119 | UCB0CTLW0 |= UCTR + UCTXSTT; // I2C TX, start condition
120 |
121 | __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts
122 | }
123 |
124 |
125 | //===================================================================================//
126 | // FUNCTION: i2c_MASTER_TRANSMITTER
127 | //===================================================================================//
128 | void i2c_master_receiver()
129 | {
130 | UCB0CTLW0 |= UCSWRST; // Software reset enabled
131 | UCB0CTLW0 |= UCMODE_3 + UCMST + UCSYNC; // I2C mode, Master mode, sync
132 | UCB0CTLW1 |= UCASTP_2; // Automatic stop generated
133 | // After UCB0TBCNT is reached
134 | UCB0BR0 = 0; // fSCL = SMCLK/256 ~ 100kHz
135 | UCB0BR1 = 1; // Buad Rate Prescalar = UCB1BR1 * 256 + UCB1BR0
136 | UCB0I2CSA = i2c_BATTERY_ADDRESS; // Slave address
137 | UCB0CTL1 &=~UCSWRST;
138 | UCB0IE |= UCRXIE+UCNACKIE+UCBCNTIE;
139 | }
140 |
141 |
142 | //===================================================================================//
143 | // FUNCTION: RECEIVE
144 | //===================================================================================//
145 | void receive()
146 | {
147 | __delay_cycles(2000);
148 | pRXData = (unsigned char *) i2c_Data_From_Slave;
149 | RXByteCounter = 2; // Load RX byte counter
150 | while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
151 | UCB0CTL1 |= UCTXSTT; // I2C start condition
152 |
153 | __bis_SR_register(CPUOFF+GIE); // Enter LPM0 w/ interrupt
154 | }
