1 | using System;
2 | using System.Collections.Generic;
3 | using System.ComponentModel;
4 | using System.Data;
5 | using System.Drawing;
6 | using System.Linq;
7 | using System.Text;
8 | using System.Threading.Tasks;
9 | using System.Windows.Forms;
10 | using Excel = Microsoft.Office.Interop.Excel;
11 | using Microsoft.Office.Core;
12 |
13 | namespace Messwert
14 | {
15 | public partial class Form1 : Form
16 | {
17 | private Excel.Application ExcelObj = null;
18 | public Form1()
19 | {
20 | InitializeComponent();
21 | ExcelObj = new Excel.Application();
22 | Open();
23 | }
24 |
25 | private void Open()
26 | {
27 | if(ExcelObj == null)
28 | {
29 | MessageBox.Show("ERROR");
30 | System.Windows.Forms.Application.Exit();
31 |
32 | }else{
33 |
34 | ExcelObj.Visible = true;
35 |
36 | }
37 |
38 | }
39 |
40 | private void Form1_Load(object sender, EventArgs e)
41 | {
42 |
43 | }
44 |
45 | string[] ConvertToStringArray(System.Array values)
46 | {
47 | // create a new string array
48 | string[] theArray = new string[values.Length];
49 | // loop through the 2-D System.Array and populate the 1-D String Array
50 | for (int i = 1; i <= values.Length; i++)
51 | {
52 | if (values.GetValue(1, i) == null)
53 | theArray[i - 1] = "";
54 | else
55 | theArray[i - 1] = (string)values.GetValue(1, i).ToString();
56 | }
57 | return theArray;
58 |
59 |
60 | }
61 |
62 | private void button1_Click(object sender, EventArgs e)
63 | {
64 | OpenFileDialog openFileDialog1 = new OpenFileDialog();
65 | //ListView listView1 = new ListView();
66 |
67 | // prepare open file dialog to only search for excel files (had trouble setting this in design view)
68 | openFileDialog1.FileName = "*.xls"; if (openFileDialog1.ShowDialog() == DialogResult.OK)
69 | {
70 | // Here is the call to Open a Workbook in Excel
71 | // It uses most of the default values (except for the read-only which we set to true)
72 | Excel.Workbook theWorkbook = ExcelObj.Workbooks.Open(openFileDialog1.FileName, 0, true, 5,
73 | "", "", true, Excel.XlPlatform.xlWindows, "\t", false, false, 0, true);
74 | // get the collection of sheets in the workbook
75 | Excel.Sheets sheets = theWorkbook.Worksheets;
76 | // get the first and only worksheet from the collection of worksheets
77 | Excel.Worksheet worksheet = (Excel.Worksheet)sheets.get_Item(1);
78 | // loop through 10 rows of the spreadsheet and place each row in the list view
79 | for (int i = 1; i <= 20; i++)
80 | {
81 |
82 | //Excel.Range range = worksheet.get_Range("A" + i.ToString(), "J" + i.ToString());
83 | //Excel.Range range = worksheet.get_Range(i.ToString(), i.ToString());
84 |
85 | Excel.Range range = worksheet.get_Range("A" + i.ToString(), "J" + i.ToString());
86 | System.Array myvalues = (System.Array)range.Cells.Value;
87 | string[] strArray = ConvertToStringArray(myvalues);
88 | listView1.Items.Add(new ListViewItem(strArray));
89 | }
90 | }
91 |
92 |
93 |
94 |
95 |
96 | }
97 |
98 |
99 |
100 | private void listView1_SelectedIndexChanged(object sender, EventArgs e)
101 | {
102 |
103 | }
104 | }
105 | }
