STM32F4 Timer PWM + Complementary
Gast #4034653
Hi, folgendes sollte meiner Ansicht nach eine PWM an PE9 und invertiert
an PE8 erzeugen. Macht es aber irgendwie doch nicht, mag mir jemand
sagen warum, wo liegt mein Fehler?
void pwm_init(void)
   //Enable PE and TIM1
   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
   //PE 8,9 Output
   GPIO_InitTypeDef GPIO_InitStructure;
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9;
     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
     GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
     GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
     GPIO_Init(GPIOE, &GPIO_InitStructure);
   GPIO_PinAFConfig(GPIOE, GPIO_PinSource8, GPIO_AF_TIM1);
     GPIO_PinAFConfig(GPIOE, GPIO_PinSource9, GPIO_AF_TIM1);
   //TIM1 PWM
   TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
     TIM_OCInitTypeDef  TIM_OCInitStructure;
23
24
   TIM_TimeBaseStructure.TIM_Period = 0xFFFF;    // Auto-Reload Value
25
     TIM_TimeBaseStructure.TIM_Prescaler = 0xFFFF; // 0xFFFF ~1.28kHz 0x07FF ~41kHz 0x1FFF ~ 20 kHz
26
     TIM_TimeBaseStructure.TIM_ClockDivision = 0;
27
     TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
28
29
     TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
30
31
     /* PWM1 Mode configuration: Channel1 */
32
     TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
33
     TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
34
   TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
35
     TIM_OCInitStructure.TIM_Pulse = 0xEFFF;                         //Duty-Cycle, TIM1_CCR1
36
     TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
37
   TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;    // High: OCN = ~OC
38
   TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;      // Rotor bypass high-side
39
   TIM_OCInitStructure.TIM_CCNIdleState = TIM_OCNIdleState_Set;
40
41
     TIM_OC1Init(TIM1, &TIM_OCInitStructure);
42
43
     TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
44
45
   TIM_ARRPreloadConfig(TIM1, ENABLE);
46
47
   TIM_Cmd(TIM1, ENABLE);
48
49
Aktuelles verhalten ist, dass PE8 u. PE9 auf Low bleiben.
#4034685
Für die PWM muss nicht nur der Timer eingeschaltet werden (TIM_CR1_CEN),
sondern auch die Capture&Compare channels aktiviert werden
(TIM_CCER_CCxE, TIM_CCER_CCxNE) und der "Main Output" (TIM_BDTR_MOE)
gesetzt sein.
Im Normalfall gibt es in den Libs eigene Funktion, die alle nötigen Bits
setzen, damit man sich nicht selbst den Kopf zerbrechen muss.
Gast #4034773
Okay, danke erstmal. Zu den Libs hab ich leider keine anständige Doku
gefunden, und auch im Referenz Manual steht jetzt (jedenfalls fuer mich)
nicht so klar welche Bits gesetzt sein muessen damit das Teil tut.
Naja, sieht aus als wuerde mir der TIM_BDTR_MOE fehlen, werd den mal
versuchen.
Danke.
Gast #4034794
Ja, das wars, hab das ergaenzt:
   TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
   TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
   TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
Vielen Dank nochmals!
Gast #4035004
Doch nicht, das hat zwar irgend was gemacht - aber keine PWM. Der
TIM_BDTR Kram kann also wieder raus.
Und dann einfach einschalten:
    TIM_CtrlPWMOutputs(TIM1, ENABLE);
(Und falls das jemand copy-pasted, so wie ich: Im TIM_TimeBaseInit
gehoert der TIM korrigiert...)
