1 | ;-----------------------------------------------------------------------------
2 | ;* Switcher for ATtiny10 and Bluetooth loop
3 | ;*
4 | ;* PB0 = Button
5 | ;* PB1 = ADC connected to 1.8V Pin12 XS3868 (reference for ADC is Vcc = Vbatt of LiIon)
6 | ;* < 3,0V should be a ADC value > 154. Use 150 for security
7 | ;* PB2 = Gate mosfet, 0 = switch on the BT and amplifier!
8 | ;* PB3 = Status LED + Tx to bluetooth module
9 | ;*
10 | ;* off= 8uA, on 0.97mA 5V
11 | ;* off= 5uA, on 0.60mA 3V3
12 | ;-----------------------------------------------------------------------------
13 |
14 | .include "tn10def.inc"
15 |
16 | .org 0
17 | rjmp RESET ; Reset Handler
18 | rjmp INT0 ; IRQ0 Handler
19 | rjmp PCINT0 ; PCINT0 Handler
20 | rjmp TIM0_CAPT ; Timer0 Capture Handler
21 | rjmp TIM0_OVF ; Timer0 Overflow Handler
22 | rjmp TIM0_COMPA ; Timer0 Compare A Handler
23 | rjmp TIM0_COMPB ; Timer0 Compare B Handler
24 | rjmp ANA_COMP ; Analog Comparator Handler
25 | rjmp WDT ; Watchdog Interrupt Handler
26 | rjmp VLM ; Voltage Level Monitor Handler
27 | rjmp ADCCH ; ADC Conversion Handle
28 |
29 |
30 | ; defines + equ
31 | ;-----------------------------------------------------------------------------
32 | .def save_sreg = r16
33 | .def iwr0 = r17
34 | .def iwr1 = r18
35 |
36 | .def key_old = r19
37 | .def key_state = r20
38 | .def key_press = r21
39 |
40 | .def rTEMP = r22
41 | .def adc_value = r23
42 |
43 | ; IRQs
44 | ;-----------------------------------------------------------------------------
45 |
46 | TIM0_COMPA: ; IRQ Timer0 compare match A
47 | in save_sreg, SREG
48 |
49 | ; Timer-Verfahren (nach Peter Dannegger): http://www.mikrocontroller.net/articles/Entprellung
50 | get8key: ;/old state iwr1 iwr0
51 | mov iwr0, key_old ;00110011 10101010 00110011
52 | in key_old, PINB ;11110000
53 | eor iwr0, key_old ; 11000011
54 | com key_old ;00001111
55 | mov iwr1, key_state ; 10101010
56 | or key_state, iwr0 ; 11101011
57 | and iwr0, key_old ; 00000011
58 | eor key_state, iwr0 ; 11101000
59 | and iwr1, iwr0 ; 00000010
60 | or key_press, iwr1 ;store key press detect
61 | out SREG, save_sreg
62 | reti
63 |
64 | ADCCH:
65 | in adc_value, ADCL
66 | reti
67 |
68 |
69 | ; not used IRQs
70 | TIM0_CAPT:
71 | TIM0_OVF:
72 | TIM0_COMPB:
73 | ANA_COMP:
74 | reti
75 |
76 | ;-----------------------------------------------------------------------------
77 |
78 | ; Start, Power On, Reset
79 | RESET:
80 | WDT:
81 | VLM:
82 | ; initialize SP
83 | ldi rTEMP, HIGH(RAMEND)
84 | out SPH, rTEMP
85 | ldi rTEMP, LOW(RAMEND)
86 | out SPL, rTEMP
87 |
88 | rcall SetLowClock
89 |
90 | sbi ACSR, ACD ; disable AC
91 |
92 | ; set ADC clock dividier to 8, irq on, auto trigger, free running in ADCSRB is default
93 | ldi rTemp, 1<<ADPS0 | 1<<ADPS1 | ADIE | ADATE
94 | out ADCSRA, rTemp
95 | sbi DIDR0, ADC1D ; deactivate digital input PB1 (1V8)
96 | sbi ADMUX, MUX0 ; set AD mux to PB1 (1V8)
97 | cbi ADCSRA, ADEN ; disable ACD
98 | ldi rTEMP, 1<<PRADC
99 | out PRR, rTEMP ; shut down ACD
100 |
101 | ldi rTEMP, 1<<PB2
102 | out DDRB, rTEMP ; Out -> Mosfet (-> BT)
103 |
104 | sbi PUEB, PUEB0 ; Pullup an PB0 (Button)
105 |
106 | ldi rTEMP, 1<<OCIE0A ; enable timer compare A interrupt
107 | out TIMSK0, rTEMP
108 |
109 | clr key_old
110 | clr key_state
111 | clr key_press
112 |
113 | sbi PORTB, PB2 ; switch BT off
114 |
115 |
116 | mainloop:
117 | cli
118 | sbis PORTB, PB2
119 | rjmp status_on
120 |
121 | status_off:
122 | rjmp check_key
123 |
124 | status_on:
125 | mov rTEMP, adc_value ; check battery
126 | sbci rTEMP, 150
127 | brcc switch_to_off ; low battery
128 |
129 | check_key:
130 | sbrs key_press, PB0 ; skip the next if key 0 is pressed
131 | rjmp endloop
132 |
133 | clr key_press ; clear, if key press action done
134 | sei
135 | sbis PORTB, PB2
136 | rjmp switch_to_off
137 |
138 | switch_to_on: ; actual status is off
139 | cbi PORTB, PB2 ; switch BT on (out is GND)
140 | rcall SetHighClock
141 |
142 | ldi rTemp, 0
143 | out PRR, rTemp ; power on ACD (+ Timer/Counter)
144 | sbi ADCSRA, ADEN ; enable ACD
145 | sbi ADCSRA, ADSC ; start first ADC conversion
146 |
147 | rjmp endloop
148 |
149 | switch_to_off: ; actual status is on
150 | sbi PORTB, PB2 ; switch BT off (out is Vcc)
151 | rcall SetLowClock
152 |
153 | cbi ADCSRA, ADEN ; disable ACD
154 | ldi rTemp, 1<<PRADC
155 | out PRR, rTemp ; shut down ACD
156 |
157 | endloop:
158 | clr key_press ; clear, if key press action done
159 | sei
160 | sleep
161 | rjmp mainloop
162 |
163 | ; set clock to 500Hz
164 | SetLowClock:
165 | ldi rTEMP, 0xD8
166 | out CCP, rTEMP ; Configuration Change Protection Register
167 | ldi rTEMP, 0x01 ; Clock source 128kHz
168 | out CLKMSR, rTEMP
169 |
170 | ; Clock dividier 256
171 | ldi rTEMP, 0xD8
172 | out CCP, rTEMP ; Configuration Change Protection Register
173 | ldi rTEMP, 1<<CLKPS3 ; Clk / 256 -> Clock 500Hz
174 | out CLKPSR, rTEMP
175 |
176 | ldi rTEMP, 1<<CS00 | 1<<WGM02 ; clock divide by 1 + CTC mode A
177 | out TCCR0B, rTEMP
178 |
179 | ldi rTEMP, 0x00
180 | out OCR0AH, rTEMP
181 | ldi rTEMP, 0x80
182 | out OCR0AL, rTEMP ; load timer with 0x80FF
183 | ret
184 |
185 | ;Set clock to 1MHz
186 | SetHighClock:
187 | ldi rTEMP, 0xD8
188 | out CCP, rTEMP ; Configuration Change Protection Register
189 | ldi rTEMP, 0x00 ; Clock source 8MHz
190 | out CLKMSR, rTEMP
191 |
192 | ; Clock dividier 8
193 | ldi rTEMP, 0xD8
194 | out CCP, rTEMP ; Configuration Change Protection Register
195 | ldi rTEMP, 1<<CLKPS0 | 1<<CLKPS1 ; Clk / 8 -> Clock 1 MHz
196 | out CLKPSR, rTEMP
197 |
198 | ldi rTEMP, 1<<CS00 | 1<<CS02 | 1<<WGM02 ; clock divide by 1024 + CTC mode A
199 | out TCCR0B, rTEMP
200 |
201 | ldi rTEMP, 0x01
202 | out OCR0AH, rTEMP
203 | ldi rTEMP, 0x00
204 | out OCR0AL, rTEMP ; load timer with 0x100FF (for 1MHz / 1024)
205 | ret
