Hallo Community! Ich habe Olimex JTAG TINY Adapter mit Verlängerungskabel und Verpackung anzubieten. Wie neu! 24€, plus Porto (Brief/Paket) oder Abholung in Berlin. Grüße Jakub Beschreibung des Herstellers: Programs all MSP430Fxxx flash microcontrollers Ultra fast programming 14KB/s faster several times than TI-USB-FET (1.4 KB/s with spy-bi-wire) Uses TI standard 2x7 pin JTAG connector Spy-By-Wire support for the newest TI MSP430 devices Can supply the target with 3.3V fixed voltage 50mA maximum current, no short circuit protection(!) MSP430.dll makes it compatible with all existing software which works with TI-USB-FET (emulates TI-USB-FET) Compatible with IAR Kickstart software for programming, real time emulation, debugging, step by step program execution, breakpoints, memory dump etc everything all high priced emulators do With IAR Kickstart you can write in assembler unlimited code size and to write in C with 2K limit for all MSP430 microcontrollers Works with free GCC C compiler and Insight MSP430 toolchain and debugger For MAC-OS users: reported to work with PS X 10.4 and current Parallels Dimensions 50x40 mm (2x1.6") + 20 cm (8") cable
