1 | /* Includes ------------------------------------------------------------------*/
2 | #include "stm32f0xx_hal.h"
3 |
4 | /* USER CODE BEGIN Includes */
5 | #include "stdbool.h"
6 | #include "states.h"
7 | /* USER CODE END Includes */
8 |
9 | /* Private variables ---------------------------------------------------------*/
10 | ADC_HandleTypeDef hadc;
11 | DMA_HandleTypeDef hdma_adc;
12 | TIM_HandleTypeDef htim1;
13 | TIM_HandleTypeDef htim3;
14 |
15 | /* USER CODE BEGIN PV */
16 |
17 | // ADC Buffer which the DMA writes into
18 | volatile uint16_t ADCBuffer[]={0x0000, 0x0000, 0x0000, 0x0000, 0xAAAA};
19 |
20 | /* USER CODE END PV */
21 |
22 | /* Private function prototypes -----------------------------------------------*/
23 | void SystemClock_Config(void);
24 | static void MX_GPIO_Init(void);
25 | static void MX_DMA_Init(void);
26 | static void MX_ADC_Init(void);
27 | static void MX_TIM1_Init(void);
28 | static void MX_TIM3_Init(void);
29 |
30 | /* USER CODE BEGIN PFP */
31 |
32 | /* USER CODE END PFP */
33 |
34 | /* USER CODE BEGIN 0 */
35 |
36 | /* USER CODE END 0 */
37 |
38 | int main(void)
39 | {
40 |
41 | /* USER CODE BEGIN 1 */
42 |
43 | /* USER CODE END 1 */
44 |
45 | /* MCU Configuration----------------------------------------------------------*/
46 |
47 | /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
48 | HAL_Init();
49 |
50 | /* Configure the system clock */
51 | SystemClock_Config();
52 |
53 | /* Initialize all configured peripherals */
54 | MX_GPIO_Init();
55 | MX_DMA_Init();
56 | MX_ADC_Init();
57 | MX_TIM1_Init();
58 | MX_TIM3_Init();
59 |
60 | /* USER CODE BEGIN 2 */
61 |
62 | // switch on clock (pwm) for charge pump
63 | HAL_TIM_PWM_MspInit(&htim3);
64 | HAL_TIM_PWM_Init(&htim3);
65 | HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_3);
66 |
67 | // switch on pwm for MOSFET
68 | HAL_TIM_PWM_MspInit(&htim1);
69 | HAL_TIM_PWM_Init(&htim1);
70 | HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1);
71 |
72 | // switch on LED
73 | HAL_GPIO_WritePin(GPIOB,GPIO_PIN_6,GPIO_PIN_SET);
74 |
75 | // switch on DMA
76 | HAL_DMA_Init(&hdma_adc);
77 | HAL_ADC_Start_DMA(&hadc,(uint32_t*)ADCBuffer, 4);
78 |
79 |
80 | // switch on ADC
81 | HAL_ADC_MspInit(&hadc); // Init ADC and DMA
82 | HAL_ADC_Start(&hadc);
83 |
84 |
85 |
86 | /* USER CODE END 2 */
87 |
88 | /* Infinite loop */
89 | /* USER CODE BEGIN WHILE */
90 | while (1)
91 | {
92 | /* USER CODE END WHILE */
93 |
94 | /* USER CODE BEGIN 3 */
95 |
96 |
97 | if(HAL_GPIO_ReadPin(GPIOB, GPIO_PIN_3)==GPIO_PIN_SET)){
98 | HAL_GPIO_WritePin(GPIOB,GPIO_PIN_6,GPIO_PIN_SET); // channel LED green on
99 | HAL_GPIO_WritePin(GPIOB,GPIO_PIN_7,GPIO_PIN_RESET); // channel LED red off
100 | HAL_GPIO_WritePin(GPIOA, GPIO_PIN_15, GPIO_PIN_SET); // activates driver stage
101 | HAL_Delay(1000);
102 | }
103 |
104 |
105 |
106 | if(HAL_GPIO_ReadPin(GPIOB, GPIO_PIN_3)==GPIO_PIN_SET)){
107 | HAL_GPIO_WritePin(GPIOB,GPIO_PIN_6,GPIO_PIN_RESET); // channel LED green off
108 | HAL_GPIO_WritePin(GPIOB,GPIO_PIN_7,GPIO_PIN_SET); // channel LED red on
109 | HAL_GPIO_WritePin(GPIOA, GPIO_PIN_15, GPIO_PIN_RESET); // deactivates driver stage
110 | HAL_Delay(1000);
111 | }
112 |
113 | if( ADCBuffer[3] > 100){
114 | HAL_GPIO_WritePin(GPIOB,GPIO_PIN_5,GPIO_PIN_SET);
115 | } else {
116 | HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, GPIO_PIN_RESET);
117 | }
118 |
119 | if(ADCBuffer[3] > 300){
120 | HAL_GPIO_WritePin(GPIOA,GPIO_PIN_12,GPIO_PIN_SET);
121 | } else {
122 | HAL_GPIO_WritePin(GPIOA, GPIO_PIN_12, GPIO_PIN_RESET);
123 | }
124 |
125 |
126 | }
127 | /* USER CODE END 3 */
128 |
129 | }
130 |
131 | /** System Clock Configuration
132 | */
133 |
134 |
135 | /* ADC init function */
136 | void MX_ADC_Init(void)
137 | {
138 |
139 | ADC_ChannelConfTypeDef sConfig;
140 |
141 | /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
142 | */
143 | hadc.Instance = ADC1;
144 | hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC;
145 | hadc.Init.Resolution = ADC_RESOLUTION12b;
146 | hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
147 | hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
148 | hadc.Init.EOCSelection = EOC_SEQ_CONV;
149 | hadc.Init.LowPowerAutoWait = DISABLE;
150 | hadc.Init.LowPowerAutoPowerOff = DISABLE;
151 | hadc.Init.ContinuousConvMode = ENABLE;
152 | hadc.Init.DiscontinuousConvMode = DISABLE;
153 | hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
154 | hadc.Init.DMAContinuousRequests = ENABLE;
155 | hadc.Init.Overrun = OVR_DATA_OVERWRITTEN;
156 | HAL_ADC_Init(&hadc);
157 |
158 | /**Configure for the selected ADC regular channel to be converted.
159 | */
160 | sConfig.Channel = ADC_CHANNEL_0;
161 | sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
162 | sConfig.SamplingTime = ADC_SAMPLETIME_7CYCLES_5;
163 | HAL_ADC_ConfigChannel(&hadc, &sConfig);
164 |
165 | /**Configure for the selected ADC regular channel to be converted.
166 | */
167 | sConfig.Channel = ADC_CHANNEL_1;
168 | HAL_ADC_ConfigChannel(&hadc, &sConfig);
169 |
170 | /**Configure for the selected ADC regular channel to be converted.
171 | */
172 | sConfig.Channel = ADC_CHANNEL_2;
173 | HAL_ADC_ConfigChannel(&hadc, &sConfig);
174 |
175 | /**Configure for the selected ADC regular channel to be converted.
176 | */
177 | sConfig.Channel = ADC_CHANNEL_3;
178 | HAL_ADC_ConfigChannel(&hadc, &sConfig);
179 |
180 | }
181 |
182 | /**
183 | * Enable DMA controller clock
184 | */
185 | void MX_DMA_Init(void)
186 | {
187 | /* DMA controller clock enable */
188 | __DMA1_CLK_ENABLE();
189 |
190 | /* DMA interrupt init */
191 | HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 2, 0);
192 | HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
193 |
194 | }
