Falls jemand Interesse an der Antwort hat:
Die Clock kann man ändern indem man die entsprechende ASF "SYSTEM-Clock
Management for SAMD10" dazu nimmt und dann unter config/conf_clocks.h
von flase zu true ändert.
1 | # define CONF_CLOCK_DFLL_ENABLE true
2 | # define CONF_CLOCK_OSC32K_ENABLE true
3 | # define CONF_CLOCK_GCLK_1_ENABLE true
Außerdem muss noch die Funktion aufgerufen werden:
1 | void configure_clock(void)
2 | {
3 | struct system_clock_source_dfll_config config_dfll;
4 | system_clock_source_dfll_get_config_defaults(&config_dfll);
5 | system_clock_source_dfll_set_config(&config_dfll);
6 |
7 | /* Enable the DFLL oscillator */
8 | enum status_code dfll_status = system_clock_source_enable(SYSTEM_CLOCK_SOURCE_DFLL);
9 |
10 | if (dfll_status != STATUS_OK)
11 | {
12 | configure_clock(); /* Error enabling the clock source */
13 | }
14 |
15 | /* Configure flash wait states before switching to high frequency clock */
16 | system_flash_set_waitstates(2);
17 |
18 | /* Change system clock to DFLL */
19 | struct system_gclk_gen_config config_gclock_gen;
20 | system_gclk_gen_get_config_defaults(&config_gclock_gen);
21 | config_gclock_gen.source_clock = SYSTEM_CLOCK_SOURCE_DFLL;
22 | config_gclock_gen.division_factor = 1;
23 | system_gclk_gen_set_config(GCLK_GENERATOR_0, &config_gclock_gen);
24 | }
Das WEX Problem war ärgerlich denn ich hab einfach nur die Reinfolge
vertauscht hier eine laufende Version
1 | // Globale Variablen
2 | struct tcc_module tcc_instance;
3 |
4 | static void configure_tcc(void)
5 | {
6 | struct tcc_config config_tcc;
7 | tcc_get_config_defaults(&config_tcc, TCC0);
8 |
9 | config_tcc.counter.period = PERIODE;
10 |
11 | config_tcc.compare.wave_generation = TCC_WAVE_GENERATION_SINGLE_SLOPE_PWM;
12 |
13 | config_tcc.pins.enable_wave_out_pin[1] = true;
14 | config_tcc.pins.enable_wave_out_pin[5] = true;
15 |
16 | config_tcc.pins.wave_out_pin[1] = PIN_PA05F_TCC0_WO1;
17 | config_tcc.pins.wave_out_pin[5] = PIN_PA09F_TCC0_WO5;
18 |
19 | config_tcc.pins.wave_out_pin_mux[1] = MUX_PA05F_TCC0_WO1;
20 | config_tcc.pins.wave_out_pin_mux[5] = MUX_PA09F_TCC0_WO5;
21 |
22 | config_tcc.compare.match[1] = PERIODE/2;
23 |
24 | /* Invert the Waveform output[1] channel to view the DTI effect */
25 | //config_tcc.wave_ext.invert[1] = true;
26 |
27 | tcc_init(&tcc_instance, TCC0, &config_tcc);
28 |
29 | /* Enable the Dead Time Insertion Generator for the channel 1 (CC1) */
30 | TCC0->WEXCTRL.reg |= TCC_WEXCTRL_DTIEN1;
31 |
32 | /* Define the High s->e time and Low side time for Dead Time generation */
33 | TCC0->WEXCTRL.reg |= TCC_WEXCTRL_DTLS(0x20) | TCC_WEXCTRL_DTHS(0x20);
34 |
35 | tcc_enable(&tcc_instance);
36 | }
In der main kann man dann mit
1 | tcc_set_compare_value(&tcc_instance, 1, neuerWert);
den Compare Wert änder (die PWM)
Falls sich noch jemand mit dem Board beschäftigt bin ich immer offen für
Anregungen.
