Hallo, Kann jemand mir sagen, warum werden die LEDs nicht ON gehen, wenn der User-Button gedruckt wird. Ich experementiere mit STM32F4-Descovery Board und hier ist mein Code: #include "stm32f4xx.h" #include "stm32f4xx_rcc.h" #include "stm32f4xx_gpio.h" int main (void) { GPIO_InitTypeDef GPIO_InitDef; /*LED section*/ /*1)To be able to work with pin, I have to enable pin clock RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE); /*2) I have to set the options of the pins, which I use*/ //A) determine the affected Pins GPIO_InitDef.GPIO_Pin= GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14 | GPIO_Pin_15; //B) select the Mode of Pins Operation.( Output Mode) GPIO_InitDef.GPIO_Mode= GPIO_Mode_OUT; //C) I specialize the Output Mode for Push-Pull output type GPIO_InitDef.GPIO_OType= GPIO_OType_PP; //D) Output Mode without Pull resistor GPIO_InitDef.GPIO_PuPd= GPIO_PuPd_NOPULL; //E) I have to determine the Speed of the Pins GPIO_InitDef.GPIO_Speed= GPIO_Speed_50MHz; //At the Ende comes the Initialization on the Port D GPIO_Init(GPIOD, &GPIO_InitDef); /*3) I turn ON the LEDs by setting the Pins HIGH GPIO_SetBits(GPIOD, GPIO_Pin_13 | GPIO_Pin_14); Bis hier hat das Code funktioniert, Nach kompilieren und Laden auf das µC waren die LED tatsächlich ON um die Leds über den User-Button leuchten zu lassen, habe ich das Code so ergänzt: /*********************************************************************** */ /*User Button sections*/ /*1)To be able to work with pin, I have enabled pin clock RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); /*2) Now I set the options of the PA0 as following:*/ //A) determine the affected Pin GPIO_InitDef.GPIO_Pin= GPIO_Pin_0; //B) I initialize the pin for input Mode GPIO_InitDef.GPIO_Mode= GPIO_Mode_IN; //C) I specialize the Input Mode GPIO_InitDef.GPIO_OType= GPIO_OType_PP; //D) with Pull down Resistor GPIO_InitDef.GPIO_PuPd= GPIO_PuPd_DOWN; //E) I have to determine the Speed of the Pins GPIO_InitDef.GPIO_Speed= GPIO_Speed_50MHz; //At the Ende comes the Initialization on the Port A GPIO_Init(GPIOA, &GPIO_InitDef); /*3) To read the Value on PA0: returns pin state (1 for High, 0 for Low)*/ if (GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_0)) { GPIO_SetBits(GPIOD, GPIO_Pin_13 | GPIO_Pin_14); } } Nach dem Ich den Teil von User_button mitkompiliert, zwar das Code Fehlerfrei kopmiliert wurde, aber wenn ich den Button drucke leuchten die Leds nicht. Mit Osci habe ich das Signal geprüft, und ich sah, wie Buttonsignal auf High ging, wenn ich den Button gedruckt habe. Aber die Leds leuchten nicht. Für Feedback wäre ich sehr bedankbar.
