Xmega mit AVR1318 Controller fehlerhafte AES Decryption
OP (Firma: - -) #4299690
seit gestern Experimentiere und recherchiere die ganze zeit warum die
Entschlüsselung von eine Verschlüsselte Variable nicht ordentlich
funktioniert.
Verfahren         : AES 128
C Entschlüsselung : AVR1318
Microcontroller   : ATxmega128A4U
Ich Verschlüssel einen String in C# mit "RijndaelManaged" habe auch das
selbe mit "AesManaged" probiert ob der Fehler eventuell auf der PC seite
liegt.
Der Code der die Variable Verschlüsselt.
#                  VERSCHLUESSELUNG  C#     #
public static byte[] encrypt(string input)
            byte[] encrypted;
            using (RijndaelManaged myRijndael  = new RijndaelManaged())
                myRijndael.KeySize = 128;   // 16 byte
                myRijndael.BlockSize = 128; // 16 byte
                myRijndael.Mode = CipherMode.CBC;
                myRijndael.Key = new byte[16] { 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39, 0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36 }; //key;
                myRijndael.IV = new byte[16] { 0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77, 0x88, 0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77, 0x88 };
                ICryptoTransform encryptor = myRijndael.CreateEncryptor(myRijndael.Key, myRijndael.IV);
                using(MemoryStream ms_encrypt  =  new MemoryStream())
                    using (CryptoStream cs = new CryptoStream(ms_encrypt, encryptor, CryptoStreamMode.Write))
                        using (StreamWriter sw = new StreamWriter(cs))
                            sw.Write(input);
                        encrypted = ms_encrypt.ToArray();
24
25
26
27
            return encrypted;
28
#                  ENTSCHLUESSELUNG   C     #
#include "AES_driver.h"
#define BLOCK_LENGTH 16
#define BLOCK_COUNT 2
uint8_t  lastsubkey[BLOCK_LENGTH];
/* Key used when AES encryption is done operations. */
uint8_t key[BLOCK_LENGTH]  = {0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39, 0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36};
uint8_t init[BLOCK_LENGTH]  = {0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77, 0x88,0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77, 0x88};
/* Variable used to check if decrypted answer is equal original data. */
bool success;
    success = true;
  /* Before using the AES it is recommended to do an AES software reset to put
   * the module in known state, in case other parts of your code has accessed
   * the AES module. */
  AES_software_reset();
  uint8_t hebele[32];
  success = AES_lastsubkey_generate(key, lastsubkey);
23
  if(!success)
24
25
    lcd_gotoxy_8(0,3);
26
    lcd_putc('X');
27
    return;
28
29
  /* Do AES Cipher Block Chaining encryption and decryption on three blocks. */
30
  uint8_t lenni[32] = {0x4c,0x65,0x6e,0x6e,0x69,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20};
31
  //success = AES_CBC_encrypt(lenni, hebele, key,init,2);
32
  success = AES_CBC_decrypt(card.content.data.client_name, hebele, lastsubkey,init,2);
33
  /* Check if decrypted answer is equal to plaintext. */
34
  if(success)
35
  {  for(uint8_t i = 0; i < BLOCK_LENGTH * BLOCK_COUNT ; i++ ){
36
      lcd_gotoxy_8(0+i,2);
37
      if(i>=16)
38
        lcd_gotoxy_8(0+i-16,3);
39
        lcd_putc(hebele[i]);
40
41
42
  return;
# ENDE CODE      #
Ich habe es auch mit den Originellen "Key" anstatt mit dem "lastsubkey"
versucht aber ledier auch ohne erfolg.
die Variable Lenni habe ich zu Probe verschlüsselt und entschlüsselt
alles i.O.
Vielen Dank voraus.
Grüße,
Kemal
OP (Firma: - -) #4299887
Ich bin komischerweise nicht auf die Idee gekommen da ich bisher alles
normal (byte weise) auf die Chipkarte geschrieben habe und alles kam
über die Chipkarte mittels Kartenleser an den Controller richtig an.
Jetzt habe ich direkt die Bytes verschlüsselt die ich auch bei dem
Micro-Controller verschlüsselt und entschlüsselt habe. Dennoch werden
die nicht richtig verschlüsselt.
OP (Firma: - -) #4299969
Update : Problem gelöst.
Ich habe dieses Projekt von einem übernommen irgend wo tief im Code
wurden die uint8 Werte die nachher einen text darstellen sollen
kontrolliert bzw. gefiltert. Die 32 ist die kleinste Zahl die ein
Zeichen darstellt. Alle Zeichen  die Kleiner als 32 waren, wurden auf 32
gesetzt. Also wurde quasi die Verschlüsselter Text manipuliert.
Der Code hat also vom Anfang an funktioniert. :FacePalm
Für den Fall jemand irgendwann einen Ähnlichen Fehler macht lösche ich
diesen Thread nicht.
