1 | '************************************************* ***** Konfiguration Controller
2 | $regfile = "m8def.DAT" 'ATMega8
3 | $crystal = 8000000 '8MHz
4 | '************************************************* ******************************
5 |
6 | 'Algemeine Konfiguration ************************************************** *****
7 | Dim I As Byte
8 | Declare Sub Zeichen
9 | Dim Wert_string As String * 12 '6 Zeichen und 6 Punkte
10 | Dim Wert_laenge_byte As Byte 'Byte
11 |
12 | '************************************************* ******************************
13 |
14 | 'Konfiguration MAX7219 ************************************************** *******
15 | Dim Led_digit As Byte 'MAX9219
16 | Dim Led_data As Byte 'MAX9219
17 | Dim Ein_zeichen As String * 5
18 | Dim Bin_led_data As Byte
19 | Dim Displaystelle(6) As String * 1 'Array für Displaystellen
20 | Config Portc = Output 'Port C als Ausgang
21 | Led_din Alias Portc.5 'DIN Pin von MAX7219
22 | Led_clk Alias Portc.4 'CLK Pin von MAX7219
23 | Led_load Alias Portc.3 'LOAD Pin von MAX7219
24 | '************************************************* ******************************
25 |
26 | 'Konfiguration DCF77 ************************************************** *********
27 | Config Dcf77 = Pinb.2 , Timer = 1 , Timer1sec = 1 , Debug = 1 , Update = 0 , Inverted = 1 , Gosub = Sectic
28 | ' Config Date = Dmy , Separator = .
29 | ' Date$ = "00.00:00"
30 | Time$ = "00:00:00" 'Startzeit setzen
31 | Enable Interrupts
32 | '************************************************* ******************************
33 |
34 | 'Programmvorbereitung ************************************************** ********
35 | Gosub Init_max7219 'Init des MAX7219
36 |
37 | ' komplettes LED-Array leeren
38 | For I = 1 To 6 'Anzahl der Stellen
39 | Led_digit = I
40 | Led_data = 0
41 | Gosub Led_write 'Schickt Daten von LED_digit und LED_data an MAX7219
42 | Next I
43 |
44 | Gosub Clear_display 'Display löschen
45 | '************************************************* ******************************
46 |
47 | 'Programmstart ************************************************** ***************
48 | 'Time$ = "12:45:59"
49 | Do 'Hauptschleife
50 |
51 | Gosub Datum_uhrzeit
52 | Loop
53 |
54 | '************************************************* ******************************
55 |
56 | Datum_uhrzeit:
57 |
58 | ' Time$ = Time(dcf_sec)
59 | ' Ein_zeichen = " " : Call Zeichen : Led_digit = 1 : Led_data = Bin_led_data : Gosub Led_write 'Led_Data muss als Byte sein dann geht auch nicht decode
60 | ' Ein_zeichen = Mid(time$ , 1 , 1) : Call Zeichen : Led_digit = 2 : Led_data = Bin_led_data : Gosub Led_write
61 | ' Ein_zeichen = Mid(time$ , 2 , 1) : Call Zeichen : Led_digit = 3 : Led_data = Bin_led_data : Led_data.7 = 1 : Gosub Led_write
62 | ' Ein_zeichen = Mid(time$ , 4 , 1) : Call Zeichen : Led_digit = 4 : Led_data = Bin_led_data : Led_data.7 = 1 : Gosub Led_write
63 | ' Ein_zeichen = Mid(time$ , 5 , 1) : Call Zeichen : Led_digit = 5 : Led_data = Bin_led_data : Gosub Led_write
64 | ' Ein_zeichen = " " : Call Zeichen : Led_digit = 6 : Led_data = Bin_led_data : Gosub Led_write
65 |
66 |
67 | ' 12:30:59
68 | ' ||||||||
69 | ' 12345678
70 | Ein_zeichen = Mid(time$ , 1 , 1) : Call Zeichen : Led_digit = 1 : Led_data = Bin_led_data : Gosub Led_write 'Led_Data muss als Byte sein dann geht auch nicht decode
71 | Ein_zeichen = Mid(time$ , 2 , 1) : Call Zeichen : Led_digit = 2 : Led_data = Bin_led_data : Gosub Led_write
72 | Ein_zeichen = Mid(time$ , 4 , 1) : Call Zeichen : Led_digit = 3 : Led_data = Bin_led_data : Gosub Led_write
73 | Ein_zeichen = Mid(time$ , 5 , 1) : Call Zeichen : Led_digit = 4 : Led_data = Bin_led_data : Gosub Led_write
74 | Ein_zeichen = Mid(time$ , 7 , 1) : Call Zeichen : Led_digit = 5 : Led_data = Bin_led_data : Gosub Led_write
75 | Ein_zeichen = Mid(time$ , 8 , 1) : Call Zeichen : Led_digit = 6 : Led_data = Bin_led_data : Gosub Led_write
76 | Return
77 | '************************************************* ******************************
78 |
79 | 'Initialisieren des MAX7219 ************************************************** **
80 | Init_max7219:
81 | Led_digit = &H0C : Led_data = 0 ' Shutdown On
82 | Gosub Led_write
83 | 'Dezimal
84 | ' Led_digit = 9 : Led_data = &B1111_1111 ' Decode "B" für alle Digits
85 | 'Binär
86 | Led_digit = 9 : Led_data = &B0000_0000 ' kein Decode "B" für alle Digits
87 | Gosub Led_write
88 | Led_digit = &H0A : Led_data = &H0F ' Helligkeit voll (0123456789ABCDEF)
89 | Gosub Led_write
90 | Led_digit = &H0B : Led_data = 5 ' Anzahl Stellen 0-7
91 | Gosub Led_write
92 | Led_digit = &H0F : Led_data = 1 ' Test On
93 | Gosub Led_write
94 | Wait 1
95 | Led_digit = &H0F : Led_data = 0 ' Test Off
96 | Gosub Led_write
97 | Led_digit = &H0C : Led_data = 1 ' Shutdown Off
98 | Gosub Led_write
99 | Return
100 | '************************************************* ******************************
101 |
102 | 'Display leeren ************************************************** **************
103 | Clear_display:
104 | Ein_zeichen = " " : Call Zeichen : Led_digit = 1 : Led_data = Bin_led_data : Gosub Led_write 'Led_Data muss als Byte sein dann geht auch nicht decode
105 | Ein_zeichen = " " : Call Zeichen : Led_digit = 2 : Led_data = Bin_led_data : Gosub Led_write
106 | Ein_zeichen = " " : Call Zeichen : Led_digit = 3 : Led_data = Bin_led_data : Gosub Led_write
107 | Ein_zeichen = " " : Call Zeichen : Led_digit = 4 : Led_data = Bin_led_data : Gosub Led_write
108 | Ein_zeichen = " " : Call Zeichen : Led_digit = 5 : Led_data = Bin_led_data : Gosub Led_write
109 | Ein_zeichen = " " : Call Zeichen : Led_digit = 6 : Led_data = Bin_led_data : Gosub Led_write
110 | Return
111 | '************************************************* ******************************
112 |
113 |
114 | 'Daten zum MAX7219 senden ************************************************** ****
115 | Led_write:
116 | Reset Led_din
117 | Reset Led_clk
118 | Reset Led_load
119 | Shiftout Led_din , Led_clk , Led_digit , 1
120 | Shiftout Led_din , Led_clk , Led_data , 1
121 | Set Led_load
122 | Print I 'gibt Zahl an Terminal aus
123 | Return
124 |
125 | '************************************************* ******************************
126 |
127 | End
128 |
129 | Zeichen:
130 | If Ein_zeichen = "0" Then Bin_led_data = &B01111110 '0
131 | If Ein_zeichen = "1" Then Bin_led_data = &B00110000 '1
132 | If Ein_zeichen = "2" Then Bin_led_data = &B01101101 '2
133 | If Ein_zeichen = "3" Then Bin_led_data = &B01111001 '3
134 | If Ein_zeichen = "4" Then Bin_led_data = &B00110011 '4
135 | If Ein_zeichen = "5" Then Bin_led_data = &B01011011 '5
136 | If Ein_zeichen = "6" Then Bin_led_data = &B01011111 '6
137 | If Ein_zeichen = "7" Then Bin_led_data = &B01110000 '7
138 | If Ein_zeichen = "8" Then Bin_led_data = &B01111111 '8
139 | If Ein_zeichen = "9" Then Bin_led_data = &B01111011 '9
140 |
141 | If Ein_zeichen = "A" Then Bin_led_data = &B01110111 'A
142 | If Ein_zeichen = "C" Then Bin_led_data = &B01001110 'C
143 | If Ein_zeichen = "E" Then Bin_led_data = &B01001111 'E
144 | If Ein_zeichen = "F" Then Bin_led_data = &B01000111 'F
145 | If Ein_zeichen = "H" Then Bin_led_data = &B00110111 'H
146 | If Ein_zeichen = "L" Then Bin_led_data = &B00001110 'L
147 | If Ein_zeichen = "O" Then Bin_led_data = &B01111110 'O
148 | If Ein_zeichen = "P" Then Bin_led_data = &B01100111 'P
149 | If Ein_zeichen = "S" Then Bin_led_data = &B01011011 'S
150 | If Ein_zeichen = "Y" Then Bin_led_data = &B00111011 'Y
151 |
152 | If Ein_zeichen = "h" Then Bin_led_data = &B00010111 'h
153 | If Ein_zeichen = "r" Then Bin_led_data = &B00000101 'r
154 | If Ein_zeichen = "t" Then Bin_led_data = &B00001111 't
155 |
156 | If Ein_zeichen = " " Then Bin_led_data = &B00000000 'leer
157 | If Ein_zeichen = "" Then Bin_led_data = &B00000000 'leer
158 | If Ein_zeichen = "-" Then Bin_led_data = &B00000001 '-
159 | If Ein_zeichen = "°" Then Bin_led_data = &B01100011 '°
160 | If Ein_zeichen = "," Then Bin_led_data = &B10000000 ',
161 | Return
162 |
163 | Sectic:
164 |
165 | Return
