Hallo beste Community,
seit Tagen versuche ich mein adfruit ili9341 zu initialisieren aber es
tut sich einfach gar nichts. erklärt sich jemand bereit einen kurzen
blick drüber zu werfen, ob denn evtl. ein grober schnitzer zu erkennen
ist?
vielen dank im voraus
void UTFT::InitLCD(void)
// DDRF |= (1<<PF0);
// PORTF |= (1<<PF0);
TCCR2A = (1 << COM2A1) | (1 << WGM20);
TCCR2A = (1 << CS21); // clock source = CLK/8, start PWM
setBrightness(255);
//Reset Pin 4 (Mega Board: Port G, Pin 5)
// Data Direction = output;
//DDRG |= 0x20;
//CS Pin 5 -- (Mega Borad: port E , pin 3)
DDRB |= (1<<PB0);
// DC Pin 6 -- (Port H, Pin 3)
DDRA |= (1<<PA0);
SPI.SPI_init();
CS_TFT_HIGH;
DC_TFT_HIGH;
_delay_ms(1); //alter Wert 100
LCD_Write_COM(0xCB); //power control A
LCD_Write_DATA(0x39);
LCD_Write_DATA(0x2C);
LCD_Write_DATA(0x00);
LCD_Write_DATA(0x34);
LCD_Write_DATA(0x02);
LCD_Write_COM(0xCF); //power control B
LCD_Write_DATA(0XC1);
LCD_Write_DATA(0X30);
LCD_Write_COM(0xE8);
LCD_Write_DATA(0x85);
LCD_Write_DATA(0x78);
LCD_Write_COM(0xEA);
LCD_Write_COM(0xED);
LCD_Write_DATA(0x64);
LCD_Write_DATA(0x03);
LCD_Write_DATA(0X12);
LCD_Write_DATA(0X81);
LCD_Write_COM(0xF7);
LCD_Write_DATA(0x20);
LCD_Write_COM(0xC0); //Power control
LCD_Write_DATA(0x23); //VRH[5:0]
LCD_Write_COM(0xC1); //Power control
LCD_Write_DATA(0x10); //SAP[2:0];BT[3:0]
LCD_Write_COM(0xC5); //VCM control
LCD_Write_DATA(0x3e); //Contrast
LCD_Write_DATA(0x28);
LCD_Write_COM(0xC7); //VCM control2
LCD_Write_DATA(0x86); //--
// Memory Access Control
// [MY] [MX] [MV] [ML] [BGR] [MH] 0 0
// 0 1 0 0 1 0 0 0 = 48
// 0 1 0 1 1 0 0 0 = 58
LCD_Write_COM(0x36);
LCD_Write_DATA(0x48);
//writeData(0x58);
LCD_Write_COM(0x3A);
LCD_Write_DATA(0x55);
LCD_Write_COM(0xB1);
LCD_Write_DATA(0x18);// 79Hz
//writeData(0x13); //100 hz
LCD_Write_COM(0xB6); // Display Function Control
LCD_Write_DATA(0x08);
LCD_Write_DATA(0x82);
LCD_Write_DATA(0x27);
LCD_Write_COM(0xF2); // 3Gamma Function Disable
LCD_Write_COM(0x26); //Gamma curve selected
LCD_Write_DATA(0x01);
LCD_Write_COM(0xE0); //Set Gamma
LCD_Write_DATA(0x0F);
LCD_Write_DATA(0x31);
LCD_Write_DATA(0x2B);
LCD_Write_DATA(0x0C);
LCD_Write_DATA(0x0E);
LCD_Write_DATA(0x4E);
LCD_Write_DATA(0xF1);
LCD_Write_DATA(0x37);
LCD_Write_DATA(0x07);
LCD_Write_DATA(0x09);
LCD_Write_COM(0xE1); //Set Gamma
LCD_Write_DATA(0x14);
LCD_Write_DATA(0x11);
LCD_Write_DATA(0xC1);
LCD_Write_DATA(0x36);
LCD_Write_COM(0x11); //Exit Sleep
_delay_ms(120);
LCD_Write_COM(0x29); //Display on
LCD_Write_COM(0x2c);
Schau doch in die Adafruit Library wo der Unterschied in der Initialisierung liegt ;) EDIT: https://github.com/adafruit/Adafruit_ILI9341/blob/master/Adafruit_ILI9341.cpp
Hallo, ich hatte mir mal nen "Treiber" für nen STM32 mit dem besagten IlI9341 Chip geschrieben. Bei mir sind es die billigen Ali Express LCDs die damit angesteuert werden. Mag sein das der nicht mega sauber programmiert ist, aber was mir in Erinnerung geblieben ist, ist das ich an bestimmten Stellen noch ein paar takte warten musste (delays einfügen musste) bevor es weiter ging. Ich hänge dir mal meinen Code an. Vielleicht kannste was damit anfangen. Viele Grüße, Willem.
