| 1 | #define F_CPU 16000000UL  // Angabe der Quarzfrequenz, wichtig für die Zeit
| 2 | #include <avr/io.h>      // Einbindung Datein
| 3 | #include <avr/interrupt.h>
| 4 | #include <stdint.h>
| 5 | #include <util/delay.h>
| 6 | #include <stdbool.h>
| 7 | #include <avr/pgmspace.h>
| 8 | #include "main.h"
| 9 | #include "i2clcd.h"
| 10 | #include "i2cmaster.h"
| 11 | #include <stdlib.h>
| 12 |
| 13 | #define PCF8591w   0x90
| 14 | #define PCF8591r   0x91
| 15 |
| 16 | volatile int16_t led1=0;
| 17 | volatile int8_t lauf=0;
| 18 | volatile int8_t anz=123;
| 19 | char Buffer[20];
| 20 | ///////////////////////////////////////////////////////
| 21 | volatile int8_t wait;
| 22 | volatile int8_t flag_1ms;
| 23 | volatile uint8_t key_state;
| 24 | volatile uint8_t key_press;
| 25 | volatile uint8_t key_rpt;
| 26 | //////////////////////////////////////////////////////
| 27 | #define KEY_DDR    DDRA                         // Datenrichtung A
| 28 | #define KEY_PORT   PORTA                        // Angabe Port A
| 29 | #define KEY_PIN    PINA                         // Angabe PIN A
| 30 | #define KEY_1       3                           // PA 3
| 31 | #define KEY_2       5                           // PA 5
| 32 | #define KEY_3       7                           // PA 7
| 33 | #define ALL_KEYS (1<<KEY_1|1<<KEY_2|1<<KEY_3)
| 34 | #define REPEAT_MASK (1<<KEY_1|1<<KEY_2)
| 35 | #define REPEAT_START 50                          // after 500ms
| 36 | #define REPEAT_NEXT 20                           // every 200ms
| 37 | ///////////////////////////////////////////////////
| 38 | void startanzeige()            // Titelbild
| 39 |   {
| 40 |   lcd_command(LCD_CLEAR);
| 41 |   _delay_ms(2);
| 42 |   lcd_printlc(1,2,"Versuch1n-I2C");
| 43 |   lcd_printlc(2,2,"P30 + P64 + D2");
| 44 |   lcd_printlc(3,2,"AT1284 und LCD");
| 45 |   lcd_printlc(4,4,"bei achim S");
| 46 |   //_delay_ms(2000);
| 47 |   }
| 48 | //////////////////////////////////////////////////
| 49 |
| 50 |
| 51 | /////////////////////////////////////////////////////
| 52 | ISR (TIMER0_COMPA_vect)                // wait1=1ms,
| 53 |   {
| 54 |   static uint8_t ct0,ct1,rpt;
| 55 |   uint8_t i;
| 56 |   //if (flag_1ms)
| 57 |     //{
| 58 |     // Laufzeit der Tasks >2ms, Fehlersignalisierung auf PA6, Programm stoppen
| 59 |     //PORTA &= ~(1<<PA6);        // Schaltet Pin
| 60 |     //while(1);        // Endlosschleife, stoppt Programm
| 61 |     //}
| 62 |   flag_1ms=1;
| 63 |   if(wait<=9)                                // bei 9 sind es 10ms
| 64 |     {
| 65 |     wait++;
| 66 |     }                      // erhöht
| 67 |   else                    // wenn dann ...
| 68 |     {
| 69 |     wait=0;                  // setzt wait auf 0
| 70 |     i=key_state ^~KEY_PIN;
| 71 |     ct0=~(ct0&i);
| 72 |     ct1=ct0^(ct1&i);
| 73 |     i&=ct0&ct1;
| 74 |     key_state^=i;
| 75 |     key_press|=key_state&i;
| 76 |     if((key_state & REPEAT_MASK)==0)
| 77 |     rpt=REPEAT_START;
| 78 |     if(--rpt==0)
| 79 |       {
| 80 |       rpt=REPEAT_NEXT;
| 81 |       key_rpt|=key_state & REPEAT_MASK;
| 82 |       }
| 83 |     }
| 84 |   }
| 85 | //////////////////////////////////////////////////////
| 86 | uint8_t get_key_press(uint8_t key_mask)
| 87 |   {
| 88 |   cli();
| 89 |   key_mask &=key_press;
| 90 |   key_press^=key_mask;
| 91 |   sei();
| 92 |   return key_mask;
| 93 |   }
| 94 | /////////////////////////////////////////
| 95 | uint8_t get_key_rpt(uint8_t key_mask)
| 96 |   {
| 97 |   cli();
| 98 |   key_mask &=key_rpt;
| 99 |   key_rpt^=key_mask;
| 100 |   sei();
| 101 |   return key_mask;
| 102 |   }
| 103 | ///////////////////////////////////////////////////////
| 104 | uint8_t get_key_short(uint8_t key_mask)
| 105 |   {
| 106 |   cli();
| 107 |   return get_key_press(~key_state & key_mask);
| 108 |   }
| 109 | ///////////////////////////////////////////////////////
| 110 | uint8_t get_key_long(uint8_t key_mask)
| 111 |   {
| 112 |   return get_key_press(get_key_rpt(key_mask));
| 113 |   }
| 114 | //////////////////////////////////////////////////////
| 115 | void led_blinken1()
| 116 |   {
| 117 |   led1++;
| 118 |   if(led1==500)
| 119 |     {
| 120 |     PORTA &= ~(1<<PA2);        // Schaltet Pin
| 121 |     }
| 122 |   else
| 123 |     {
| 124 |     if(led1==1000)
| 125 |       {
| 126 |       PORTA |= (1<<PA2);      // Schaltet Pin
| 127 |       led1=0;
| 128 |       }
| 129 |     }
| 130 |   }
| 131 |
| 132 | //////////////////////////////////////////////////////
| 133 | void anzeige()
| 134 |   {
| 135 |     lauf++;
| 136 |   if(lauf==50)
| 137 |     {
| 138 |
| 139 |       itoa( anz, Buffer, 10 );    // Zeile 1
| 140 |       lcd_printlc(3,1,"Wert ");
| 141 |       lcd_printlc(3,9,Buffer);
| 142 |
| 143 |       lauf=0;
| 144 |
| 145 |     }
| 146 |
| 147 | /////////////////////////////////////////////////////
| 148 | void timer_init()
| 149 |   {                        // Timer 0 konfigurieren
| 150 |   TCCR0A = 0;                  // CTC Modus
| 151 |   TCCR0B = (1<<WGM01)|(1<<CS01)|(1<<CS00);  // Prescaler 64
| 152 |   TCNT0=1;
| 153 |   OCR0A=249;
| 154 |   TIMSK0|=(1<<OCIE0A);            // Interrupt erlauben
| 155 |   }
| 156 | ////////////////////////////////////////////////////
| 157 | int main(void)
| 158 |   {
| 159 |   timer_init();
| 160 |
| 161 |   DDRA=0b00000100;              // Port A 1x auf Ausgang schalten
| 162 |   DDRC=0b01100000;              // Port C 2x auf Ausgang schalten
| 163 |
| 164 |   KEY_DDR&=~ALL_KEYS;
| 165 |   KEY_PORT|=ALL_KEYS;
| 166 |
| 167 |   PORTC |= (1<<PC5);              // Port A beim einschalten Ausgänge aus
| 168 |   PORTC |= (1<<PC6);
| 169 |
| 170 |   //char Buffer[20];
| 171 |   i2c_init();                          // Starte I2C Bus
| 172 |   lcd_init();                          // Starte I2CLCD
| 173 |   lcd_light(0);                // 0=Licht an, 1=Licht aus
| 174 |   // Display Befehle
| 175 |   lcd_command(LCD_DISPLAYON | LCD_CURSOROFF | LCD_BLINKINGOFF);
| 176 |   // Display ON/OFF / Cursor ON/OFF / Blinken ON/OFF
| 177 |   startanzeige();
| 178 |
| 179 |   _delay_ms(5000);
| 180 |
| 181 |
| 182 |   lcd_command(LCD_CLEAR);            // Leere Display
| 183 |   _delay_ms(2);              // warte 2ms
| 184 |
| 185 |   sei();
| 186 |
| 187 |
| 188 |   while(1)              // Programmschleife
| 189 |     {
| 190 |     if(flag_1ms)
| 191 |       {
| 192 |       flag_1ms=0;
| 193 |       led_blinken1();        // Aufruf Unterprogramm
| 194 |       }
| 195 |     ////////////////////////////// Test mit delay
| 196 |     // _delay_ms(2);
| 197 |     //////////////////////////////
| 198 |
| 199 |     if(get_key_press(1<<KEY_2))    // nur Taste press
| 200 |     {                // LED an
| 201 |       PORTC &= ~(1<<PC5);
| 202 |     }
| 203 |
| 204 |     if(get_key_press(1<<KEY_3))    // nur Taste press
| 205 |     {                // LED aus
| 206 |       PORTC |= (1<<PC5);
| 207 |     }
| 208 |
| 209 |     if(get_key_short(1<<KEY_1))    // kurz schalten immer zusammen mit long
| 210 |     {
| 211 |       PORTC &= ~(1<<PC6);          // LED an
| 212 |     }
| 213 |
| 214 |     if(get_key_long(1<<KEY_1))    // Lang schalten immer mit short
| 215 |     {
| 216 |       PORTC |= (1<<PC6);      // LED aus
| 217 |     }
| 218 |
| 219 |     anzeige();
| 220 |
| 221 |     _delay_ms(1);
| 222 |
| 223 |   }
| 224 | }
