1 | /*** Include and Header files ******************************************************************************/
2 |
3 | #include <xc.h> //by Microchip
4 | #include <p18f87K22.h> //by Microchip
5 |
6 | /*** Configuration PIC *********************************************************************************/
7 |
8 | // PIC18F87K22 Configuration Bit Settings
9 | // Use project enums instead of #define for ON and OFF.
10 |
11 |
12 | // PIC18F87K22 Configuration Bit Settings
13 |
14 | // 'C' source line config statements
15 |
16 | // #pragma config statements should precede project file includes.
17 | // Use project enums instead of #define for ON and OFF.
18 |
19 | // CONFIG1L
20 | #pragma config RETEN = OFF // VREG Sleep Enable bit (Disabled - Controlled by SRETEN bit)
21 | #pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
22 | #pragma config SOSCSEL = HIGH // SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
23 | #pragma config XINST = OFF // Extended Instruction Set (Disabled)
24 |
25 | // CONFIG1H
26 | #pragma config FOSC = INTIO2 // Oscillator (Internal RC oscillator)
27 | #pragma config PLLCFG = ON // PLL x4 Enable bit (Enabled)
28 | #pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
29 | #pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
30 |
31 | // CONFIG2L
32 | #pragma config PWRTEN = OFF // Power Up Timer (Disabled)
33 | #pragma config BOREN = SBORDIS // Brown Out Detect (Enabled in hardware, SBOREN disabled)
34 | #pragma config BORV = 3 // Brown-out Reset Voltage bits (1.8V)
35 | #pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
36 |
37 | // CONFIG2H
38 | #pragma config WDTEN = SWDTDIS // Watchdog Timer (WDT enabled in hardware; SWDTEN bit disabled)
39 | #pragma config WDTPS = 1048576 // Watchdog Postscaler (1:1048576)
40 |
41 | // CONFIG3L
42 | #pragma config RTCOSC = 0 // RTCC Clock Select (RTCC uses SOSC)
43 | #pragma config EASHFT = ON // External Address Shift bit (Address Shifting enabled)
44 | #pragma config ABW = MM // Address Bus Width Select bits (8-bit address bus)
45 | #pragma config BW = 16 // Data Bus Width (16-bit external bus mode)
46 | #pragma config WAIT = OFF // External Bus Wait (Disabled)
47 |
48 | // CONFIG3H
49 | #pragma config CCP2MX = PORTC // CCP2 Mux (RC1)
50 | #pragma config ECCPMX = PORTE // ECCP Mux (Enhanced CCP1/3 [P1B/P1C/P3B/P3C] muxed with RE6/RE5/RE4/RE3)
51 | #pragma config MSSPMSK = MSK7 // MSSP address masking (7 Bit address masking mode)
52 | #pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RG5 Disabled)
53 |
54 | // CONFIG4L
55 | #pragma config STVREN = ON // Stack Overflow Reset (Enabled)
56 | #pragma config BBSIZ = BB2K // Boot Block Size (2K word Boot Block size)
57 |
58 | // CONFIG5L
59 | #pragma config CP0 = OFF // Code Protect 00800-03FFF (Disabled)
60 | #pragma config CP1 = OFF // Code Protect 04000-07FFF (Disabled)
61 | #pragma config CP2 = OFF // Code Protect 08000-0BFFF (Disabled)
62 | #pragma config CP3 = OFF // Code Protect 0C000-0FFFF (Disabled)
63 | #pragma config CP4 = OFF // Code Protect 10000-13FFF (Disabled)
64 | #pragma config CP5 = OFF // Code Protect 14000-17FFF (Disabled)
65 | #pragma config CP6 = OFF // Code Protect 18000-1BFFF (Disabled)
66 | #pragma config CP7 = OFF // Code Protect 1C000-1FFFF (Disabled)
67 |
68 | // CONFIG5H
69 | #pragma config CPB = OFF // Code Protect Boot (Disabled)
70 | #pragma config CPD = OFF // Data EE Read Protect (Disabled)
71 |
72 | // CONFIG6L
73 | #pragma config WRT0 = OFF // Table Write Protect 00800-03FFF (Disabled)
74 | #pragma config WRT1 = OFF // Table Write Protect 04000-07FFF (Disabled)
75 | #pragma config WRT2 = OFF // Table Write Protect 08000-0BFFF (Disabled)
76 | #pragma config WRT3 = OFF // Table Write Protect 0C000-0FFFF (Disabled)
77 | #pragma config WRT4 = OFF // Table Write Protect 10000-13FFF (Disabled)
78 | #pragma config WRT5 = OFF // Table Write Protect 14000-17FFF (Disabled)
79 | #pragma config WRT6 = OFF // Table Write Protect 18000-1BFFF (Disabled)
80 | #pragma config WRT7 = OFF // Table Write Protect 1C000-1FFFF (Disabled)
81 |
82 | // CONFIG6H
83 | #pragma config WRTC = OFF // Config. Write Protect (Disabled)
84 | #pragma config WRTB = OFF // Table Write Protect Boot (Disabled)
85 | #pragma config WRTD = OFF // Data EE Write Protect (Disabled)
86 |
87 | // CONFIG7L
88 | #pragma config EBRT0 = OFF // Table Read Protect 00800-03FFF (Disabled)
89 | #pragma config EBRT1 = OFF // Table Read Protect 04000-07FFF (Disabled)
90 | #pragma config EBRT2 = OFF // Table Read Protect 08000-0BFFF (Disabled)
91 | #pragma config EBRT3 = OFF // Table Read Protect 0C000-0FFFF (Disabled)
92 | #pragma config EBRT4 = OFF // Table Read Protect 10000-13FFF (Disabled)
93 | #pragma config EBRT5 = OFF // Table Read Protect 14000-17FFF (Disabled)
94 | #pragma config EBRT6 = OFF // Table Read Protect 18000-1BFFF (Disabled)
95 | #pragma config EBRT7 = OFF // Table Read Protect 1C000-1FFFF (Disabled)
96 |
97 | // CONFIG7H
98 | #pragma config EBRTB = OFF // Table Read Protect Boot (Disabled)
99 |
100 | /*** VARIABLES *********************************************************************************/
101 |
102 | #define _XTAL_FREQ 4000000 //Fosc frequency for _delay() library (4MHz)
103 |
104 | /*** PRIVATE PROTOTYPES ***********************************************************************/
105 |
106 | void Init(void); //Aufruf der Initialisierung vor Ausführung des main()
107 |
108 | //******************************************************************************
109 | // MAIN PROGRAM
110 | //******************************************************************************
111 | void main(void)
112 | {
113 | Init(); //Initialisierung
114 |
115 | while(1) //Endlosschleife
116 | {
117 | }
118 | }//end main();
119 |
120 | //*********************************************************************************************
121 | // INITIALISIERUNG PIC
122 | //*********************************************************************************************
123 |
124 | void Init(void)
125 | {
126 |
127 | /*** SET VALUES OF VARIABLES ***********************************************************/
128 |
129 | /*** Set Inputs, Outputs ***************************************************************/
130 | //*// All PINs with an * are free usable I/O PINs //*//
131 |
132 | //PORTA A0-A5
133 | TRISAbits.TRISA0 = 1; //set RA0 as INPUT used for Taster 1
134 | TRISAbits.TRISA1 = 1; //set RA1 as INPUT used for Taster 2
135 | TRISAbits.TRISA2 = 1; //set RA2 as INPUT used for Taster 3
136 | TRISAbits.TRISA3 = 1; //set RA3 as INPUT used for Taster 4
137 | TRISAbits.TRISA4 = 1; //set RA4 as INPUT used for Taster 5
138 | TRISAbits.TRISA5 = 1; //set RA5 as INPUT used for Schalter 1
139 | //RA6 see the OSC2/CLKO/RA6 pin.
140 | //RA7 see the OSC1/CLKI/RA7 pin.
141 |
142 |
143 | //PORTB B0-B7
144 | TRISBbits.TRISB0 = 0; //set RB0 as OUTPUT used as BT-mode
145 | TRISBbits.TRISB6 = 1; //set RB6 as INPUT used as PGC
146 | TRISBbits.TRISB7 = 1; //set RB7 as INPUT used as PGD
147 |
148 | //PORTC C0-C7
149 | TRISCbits.TRISC6 = 0; //set RC6 as OUTPUT used as BT-UART TX
150 | TRISCbits.TRISC7 = 1; //set RC7 as INPUT used as BT-UART RX
151 |
152 | //PORTG G0-G4
153 | TRISGbits.TRISG4 = 0; //set RG4 as OUTPUT used for RTCC Pin
154 | //RG5 used as MCLR
155 |
156 |
157 |
158 | RTCWREN = 1; //RTCC Value Registers Write Enable bit
159 | //RTCVALH and RTCVALL registers can be written to by the user
160 | RTCEN = 1; //RTCC module is enabled
161 | RTCOE = 1; //RTCC clock output is enabled
162 |
163 | AMASK3 = 0; //Alarm Mask Configuration bits
164 | AMASK2 = 0; //set to: Every 10 seconds
165 | AMASK1 = 1;
166 | AMASK0 = 0;
167 |
168 | ARPT7 = 0; // ALARM REPEAT REGISTER
169 | ARPT6 = 0;
170 | ARPT5 = 0;
171 | ARPT4 = 1;
172 | ARPT3 = 1;
173 | ARPT2 = 1;
174 | ARPT1 = 1;
175 | ARPT0 = 1;
176 |
177 | }//end Initialization();
178 | /*** end of file *********************************************************************************************/
