1 | /*******************************************************************************
2 |
3 | MCU: PIC18F66K80
4 | Oscillator: HS, 18.0000 MHz
5 | ******************************************************************************/
6 |
7 |
8 | char SJW, BRP, Phase_Seg1, Phase_Seg2, Prop_Seg;
9 | unsigned char Can_Init_Flags, Can_Send_Flags, Can_Rcv_Flags; // can flags
10 | unsigned short init_flag, send_flag, dt, len, read_flag;
11 | unsigned char Rx_Data_Len; // received data length in bytes
12 | char RxTx_Data[8]; // can rx/tx data buffer
13 | char Msg_Rcvd; // reception flag
14 | const long ID_1st = 1365, ID_2nd = 170; // node IDs
15 | long Rx_ID, mask;
16 |
17 | void main() {
18 | TRISD = 0;
19 | TRISE = 16; // RE4 as input, RE5 as output
20 | PORTC = 0; // clear PORTC
21 | TRISC = 0; // set PORTC as output
22 |
23 | Can_Init_Flags = 0; //
24 | Can_Send_Flags = 0; // clear flags
25 | Can_Rcv_Flags = 0; //
26 |
27 | Can_Send_Flags = _CAN_TX_PRIORITY_0 & // form value to be used
28 | _CAN_TX_XTD_FRAME & // with CANWrite
29 | _CAN_TX_NO_RTR_FRAME;
30 |
31 | Can_Init_Flags = _CAN_CONFIG_SAMPLE_THRICE & // form value to be used
32 | _CAN_CONFIG_PHSEG2_PRG_ON & // with CANInit
33 | _CAN_CONFIG_XTD_MSG &
34 | _CAN_CONFIG_DBL_BUFFER_ON &
35 | _CAN_CONFIG_VALID_XTD_MSG;
36 |
37 | SJW = 1;
38 | BRP = 3;
39 | Phase_Seg1 = 7;
40 | Phase_Seg2 = 8;
41 | Prop_Seg = 7;
42 |
43 | init_flag = _CAN_CONFIG_SAMPLE_THRICE &
44 | _CAN_CONFIG_PHSEG2_PRG_ON &
45 | _CAN_CONFIG_STD_MSG &
46 | _CAN_CONFIG_DBL_BUFFER_ON &
47 | _CAN_CONFIG_VALID_STD_MSG &
48 | _CAN_CONFIG_LINE_FILTER_OFF;
49 |
50 | send_flag = _CAN_TX_PRIORITY_0 &
51 | _CAN_TX_STD_FRAME &
52 | _CAN_TX_NO_RTR_FRAME;
53 |
54 | read_flag = 0;
55 |
56 | //
57 | // Initialise CAN module
58 | //
59 | CANInitialize(SJW, BRP, Phase_Seg1, Phase_Seg2, Prop_Seg, init_flag);
60 | //
61 | // Set CAN CONFIG mode
62 | //
63 | CANSetOperationMode(_CAN_MODE_CONFIG, 0xFF);
64 |
65 | mask = -1;
66 | //
67 | // Set all MASK1 bits to 1's
68 | //
69 | CANSetMask(_CAN_MASK_B1, mask, _CAN_CONFIG_STD_MSG);
70 |
71 | //
72 | // Set all MASK2 bits to 1's
73 | //
74 | CANSetMask(_CAN_MASK_B2, mask, _CAN_CONFIG_STD_MSG);
75 | // mask
76 | // Set id of filter B1_F1 to 3
77 | //
78 | CANSetFilter(_CAN_FILTER_B1_F1, 0x3,_CAN_CONFIG_STD_MSG); // receive messages with identifier = 3
79 | CANSetFilter(_CAN_FILTER_B1_F2, 0x4,_CAN_CONFIG_STD_MSG); // receive messages with identifier = 4
80 | CANSetFilter(_CAN_FILTER_B2_F1, 0x5,_CAN_CONFIG_STD_MSG); // receive messages with identifier = 5
81 | CANSetFilter(_CAN_FILTER_B2_F2, 0x6,_CAN_CONFIG_STD_MSG); // receive messages with identifier = 6
82 | CANSetFilter(_CAN_FILTER_B2_F3, 0x7,_CAN_CONFIG_STD_MSG); // receive messages with identifier = 7
83 | CANSetFilter(_CAN_FILTER_B2_F4, 0x8,_CAN_CONFIG_STD_MSG); // receive messages with identifier = 8
84 | //
85 | // Set CAN module to NORMAL mode
86 | //
87 | CANSetOperationMode(_CAN_MODE_NORMAL, 0xFF);
88 | RxTx_Data[0] = 9;
89 | PORTC = 0x2;
90 | //CANWrite(Rx_ID, RxTx_Data, 1, send_flag);
91 | for(;;) // Endless loop
92 | {
93 | //
94 | // Wait until a request is received
95 | //
96 | dt = 0;
97 | while(!dt) dt = CANRead(&Rx_ID, RxTx_Data, &len, &read_flag);
98 | if(Rx_ID == 507)
99 | {
100 | PORTC = 0xFF;
101 | }
102 | else
103 | {PORTC = 0x1;}
104 | }
105 | }
