1 | //#################################################################################
2 | //#################################################################################
3 | //#################################################################################
4 | /* Library to use ds18x20 with ATMEL Atmega family.
5 | For short ds18x20 wires there is no need for an external pullup resistor.
6 | If the wire length exceeds one meter you should use a 4.7k pullup resistor
7 | on the data line. This library does not work for parasite power.
8 | You can just use one ds18x20 per Atmega Pin.
9 |
10 | Copyright (C) 2010 Stefan Sicklinger
11 |
12 | For support check out http://www.sicklinger.com
13 |
14 | This library is free software: you can redistribute it and/or modify
15 | it under the terms of the GNU General Public License as published by
16 | the Free Software Foundation, either version 3 of the License, or
17 | (at your option) any later version.
18 |
19 | This program is distributed in the hope that it will be useful,
20 | but WITHOUT ANY WARRANTY; without even the implied warranty of
21 | MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
22 | GNU General Public License for more details.
23 |
24 | You should have received a copy of the GNU General Public License
25 | along with this program. If not, see <http://www.gnu.org/licenses/>.*/
26 | //#################################################################################
27 | //#################################################################################
28 | //#################################################################################
29 |
30 | #include "ds18x20lib.h"
31 |
32 |
33 | //----------------------------------------
34 | // Reset DS18S20
35 | //----------------------------------------
36 | uint8_t ds1820_reset(uint8_t used_pin)
37 | {
38 | uint8_t err=100;
39 | DS1820_DDR |= 1<<used_pin; // define as ouput
40 | DS1820_PORT &= ~(1<<used_pin); //Pull low
41 | delay_us(480); ; // 480 us
42 | DS1820_DDR &= ~(1<<used_pin); // define as input
43 | DS1820_PORT |= 1<<used_pin; //Pullup on
44 | delay_us(66); // 66 us
45 | err = (DS1820_PIN & (1<<used_pin)) >> used_pin; // no presence detect --> err=1 otherwise err=0
46 | delay_us(240); // 240 us
47 | if( (DS1820_PIN & (1<<used_pin)) == 0 ){ // short circuit --> err=2
48 | err = 2;
49 | }
50 | return err;
51 | }
52 | //-----------------------------------------
53 | // Write one bit to DS18S20
54 | //-----------------------------------------
55 | void ds1820_wr_bit(uint8_t wrbit,uint8_t used_pin)
56 | {
57 | if (wrbit ==0) {
58 | DS1820_DDR |= 1<<used_pin; // define as ouput
59 | DS1820_PORT &= ~(1<<used_pin); //Pull low
60 | delay_us(60);
61 | DS1820_DDR &= ~(1<<used_pin); // define as input
62 | DS1820_PORT |= 1<<used_pin; //Pullup on
63 | delay_us(4);
64 | }
65 | if (wrbit ==1) {
66 | DS1820_DDR |= 1<<used_pin; // define as ouput
67 | DS1820_PORT &= ~(1<<used_pin); //Pull low
68 | delay_us(10);
69 | DS1820_DDR &= ~(1<<used_pin); // define as input
70 | DS1820_PORT |= 1<<used_pin; //Pullup on
71 | delay_us(54);
72 | }
73 | }
74 | //-----------------------------------------
75 | // Read one bit from DS18S20
76 | //-----------------------------------------
77 | uint8_t ds1820_re_bit(uint8_t used_pin)
78 | {
79 | uint8_t rebit;
80 | DS1820_DDR |= 1<<used_pin; // define as ouput
81 | DS1820_PORT &= ~(1<<used_pin); //Pull low
82 | delay_us(1);
83 | DS1820_DDR &= ~(1<<used_pin); // define as input
84 | DS1820_PORT |= 1<<used_pin; //Pullup on
85 | delay_us(10);
86 | rebit = (DS1820_PIN & (1<<used_pin)) >> used_pin; //Read bit
87 | delay_us(50);
88 | return rebit;
89 | }
90 | //-----------------------------------------
91 | // Read 1 byte from DS18S20
92 | //-----------------------------------------
93 | uint8_t ds1820_re_byte(uint8_t used_pin)
94 | {
95 | uint8_t rebyte =0x00;
96 | uint8_t rebit;
97 | uint8_t i;
98 |
99 | for (i=0;i<8;i++)
100 | {
101 | rebit=ds1820_re_bit(used_pin);
102 | //delay_us(2); //be on the save side
103 | if (rebit==1){
104 | rebyte|=(1<<i);
105 | }
106 | }
107 | return(rebyte);
108 | }
109 | //-----------------------------------------
110 | // Write 1 byte to DS18S20
111 | //-----------------------------------------
112 | void ds1820_wr_byte(uint8_t wrbyte,uint8_t used_pin)
113 | {
114 | uint8_t i;
115 | for (i=0; i<8; i++) // writes byte, one bit at a time
116 | {
117 | ds1820_wr_bit((wrbyte & 0b00000001),used_pin);
118 | wrbyte = wrbyte >> 1;
119 | }
120 | delay_us(5);
121 | }
122 | //-----------------------------------------
123 | // Read temperature
124 | //-----------------------------------------
125 | float ds1820_read_temp(uint8_t used_pin)
126 | {
127 | uint8_t error,i;
128 | uint16_t j=0;
129 | uint8_t scratchpad[9];
130 | float temp=0;
131 | scratchpad[0]=0;
132 | scratchpad[1]=0;
133 | scratchpad[2]=0;
134 | scratchpad[3]=0;
135 | scratchpad[4]=0;
136 | scratchpad[5]=0;
137 | scratchpad[6]=0;
138 | scratchpad[7]=0;
139 | scratchpad[8]=0;
140 | error=ds1820_reset(used_pin); //1. Reset
141 | if (error==0){
142 | ds1820_wr_byte(0xCC,used_pin); //2. skip ROM
143 | ds1820_wr_byte(0x44,used_pin); //3. ask for temperature conversion
144 | while (ds1820_re_byte(used_pin)==0xFF && j<1000){ //4. wait until conversion is finished
145 | _delay_us(1);
146 | j++;
147 | }
148 | error=ds1820_reset(used_pin); //5. Reset
149 | ds1820_wr_byte(0xCC,used_pin); //6. skip ROM
150 | ds1820_wr_byte(0xBE,used_pin); //7. Read entire scratchpad 9 bytes
151 |
152 | for (i=0; i<9; i++) //8. Get scratchpad byte by byte
153 | {
154 | scratchpad[i]=ds1820_re_byte(used_pin); //9. read one DS18S20 byte
155 | }
156 | }
157 | if(scratchpad[1]==0x00 && scratchpad[7]!=0){ //Value pos.
158 | scratchpad[0]=scratchpad[0] >> 1;
159 | temp=(scratchpad[0]-0.25f+(((float)scratchpad[7]-(float)scratchpad[6])/(float)scratchpad[7]));
160 | temp = (floor(temp*10.0+0.5)/10); //Round value .x
161 |
162 | }
163 | if(scratchpad[1]!=0x00){ //Value negative
164 | uint8_t tmp;
165 | tmp =scratchpad[0]; //Save Kommabit
166 | tmp= ~ tmp;
167 | tmp= tmp >> 1;
168 | temp = (-1)*(tmp+1);
169 | if ((scratchpad[0]&0b00000001)==1){
170 | temp=temp+0.5;
171 | }
172 |
173 | }
174 |
175 | return temp;
176 | }
177 | //-----------------------------------------
178 | // Initialize DS18S20
179 | //-----------------------------------------
180 | void ds1820_init(uint8_t used_pin)
181 | {
182 | uint8_t error;
183 | uint16_t i =0;
184 | error=ds1820_reset(used_pin); //1. Reset
185 | if (error==0){
186 | ds1820_wr_byte(0xCC,used_pin); //2. skip ROM
187 | ds1820_wr_byte(0x44,used_pin); //3. ask for temperature conversion
188 | while (ds1820_re_byte(used_pin)==0xFF && i<1000){ //4. wait until conversion is finished
189 | _delay_us(1);
190 | i++;
191 | }
192 | error=ds1820_reset(used_pin); //5. Reset
193 | ds1820_wr_byte(0xCC,used_pin); //6. skip ROM
194 | ds1820_wr_byte(0xBE,used_pin); //7. Read entire scratchpad 9 bytes
195 | }
196 |
197 |
198 | }
