1 | ' (c) 1995-2009, MCS VERSION 2 of the BOOTLOADER. The waiting for the NAK is
2 | ' stretched.further a bug was resolved for the M64/128 that have a big page size
3 | '-------------------------------------------------------------------------------
4 | $crystal = 16000000
5 | $baud = 9600
6 |
7 |
8 | $regfile = "M328def.dat"
9 | Const Loaderchip = 328
10 |
11 |
12 | $prog &HFF , &H7F , &HD8 , &H00 ' generated. Take care that the chip supports all fuse bytes.
13 |
14 | #if Loaderchip = 328 ' Mega32
15 | $loader = $3c00 ' 1024 words
16 | Const Maxwordbit = 6 'Z6 is maximum bit '
17 | Config Com1 = Dummy , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
18 | #endif
19 |
20 |
21 | Const Maxword =(2 ^ Maxwordbit) * 2 '128
22 | Const Maxwordshift = Maxwordbit + 1
23 |
24 | 'Dim the used variables
25 | Dim Bstatus As Byte , Bretries As Byte , Bblock As Byte , Bblocklocal As Byte
26 | Dim Bcsum1 As Byte , Bcsum2 As Byte , Buf(128) As Byte , Csum As Byte
27 | Dim J As Byte , Spmcrval As Byte ' self program command byte value
28 |
29 | Dim Z As Long 'this is the Z pointer word
30 | Dim Vl As Byte , Vh As Byte ' these bytes are used for the data values
31 | Dim Wrd As Word , Page As Word 'these vars contain the page and word address
32 | Dim Bkind As Byte , Bstarted As Byte
33 | 'Mega 88 : 32 words, 128 pages
34 |
35 | Disable Interrupts 'we do not use ints
36 |
37 | 'Waitms 100 'wait 100 msec sec
38 | 'We start with receiving a file. The PC must send this binary file
39 |
40 | 'some constants used in serial com
41 | Const Nak = &H15
42 | Const Ack = &H06
43 | Const Can = &H18
44 |
45 | $timeout = 400000 'we use a timeout
46 | 'When you get LOADER errors during the upload, increase the timeout value
47 | 'for example at 16 Mhz, use 200000
48 |
49 | Bretries = 5 'we try 5 times
50 | Testfor123:
51 |
52 | Bstatus = Waitkey() ' wait for the loader to send a byte
53 |
54 | Print Chr(bstatus); ' got - return value
55 |
56 | If Bstatus = 123 Then 'did we received value 123 ?
57 | Bkind = 0 'normal flash loader
58 | Goto Loader
59 | Elseif Bstatus = 124 Then ' EEPROM
60 | Bkind = 1 ' EEPROM loader
61 | Goto Loader
62 | Elseif Bstatus <> 0 Then
63 | Decr Bretries
64 | If Bretries <> 0 Then Goto Testfor123 'we test again
65 | End If
66 |
67 | 'For J = 1 To 10 'this is a simple indication that we start the normal reset vector
68 | ' Toggle Portb.2 : Waitms 100
69 | 'Next
70 |
71 | Goto _reset 'goto the normal reset vector at address 0
72 |
73 | '---[this is the loader routine. It is a Xmodem-checksum reception routine]-----
74 | Loader:
75 | Do 'Clear buffer
76 | Bstatus = Waitkey()
77 | Loop Until Bstatus = 0
78 |
79 | ' For J = 1 To 3 'this is a simple indication that we start the normal reset vector
80 | ' Toggle Portb.2 : Waitms 50
81 | ' Next
82 |
83 | If Bkind = 0 Then
84 | Spmcrval = 3 : Gosub Do_spm ' erase the first page
85 | Spmcrval = 17 : Gosub Do_spm ' re-enable page
86 | End If
87 |
88 | Bretries = 10 'number of retries
89 |
90 | 'Blockaufbau:
91 | '------------
92 | ' Das ASCII-Zeichen Start Of Header (SOH, hex01) (1 Byte),
93 | ' Blocknummer (1 Byte), 0...255
94 | ' Daten (128 Byte),
95 | ' Prüfsumme (1 Byte) die Prüfsumme ist hier die arithmetische Summe der Datenbytes modulo 256 und deshalb fehleranfällig
96 |
97 | 'Protokoll:
98 | '----------
99 | ' Die Übertragung wird durch den Empfänger angestoßen, indem er ein NAK sendet.
100 | 'Eine fehlerfrei empfangene Checksumme wird mit Acknowledgement (ACK, hex06) bestätigt.
101 | ' Bei einer Checksumme ungleich der berechneten Checksumme ist ein Fehler aufgetreten.
102 | ' Der Block wird mit Negative Acknowledgement (NAK, hex15) abgelehnt und dann bis zu zehnmal neu versendet.
103 | ' Das Ende einer Übertragung wird vom Sender mit End Of Transmission (EOT, hex04) angezeigt.
104 | ' Auch dieses muss mit einem ACK bestätigt werden.
105 |
106 | Do
107 | Bstarted = 0 ' we were not started yet
108 | Csum = 0 'checksum is 0 when we start
109 | Print Chr(nak); ' first time send a nack
110 | Do
111 |
112 | Bstatus = Waitkey() 'wait for status byte
113 |
114 | Select Case Bstatus
115 | Case 1: ' start of heading, PC is ready to send (hex01)
116 | Incr Bblocklocal ' increase local block count
117 |
118 | Csum = 1 ' checksum is 1
119 |
120 | Bblock = Waitkey() : Csum = Csum + Bblock 'get block-number
121 |
122 | Bcsum1 = Waitkey() : Csum = Csum + Bcsum1 'get checksum first-byte
123 |
124 | For J = 1 To 128 'get 128 bytes (Data)
125 | Buf(j) = Waitkey() : Csum = Csum + Buf(j)
126 | Next
127 |
128 | Bcsum2 = Waitkey() 'get second checksum byte
129 |
130 | If Bblocklocal = Bblock Then 'are the blocks the same?
131 | If Bcsum2 = Csum Then 'is the checksum the same?
132 | Gosub Writepage 'yes go write the page
133 | Print Chr(ack); 'acknowledge
134 | Else 'no match so send nak
135 | Print Chr(nak);
136 | End If
137 | Else
138 | Print Chr(nak); 'blocks do not match
139 | End If
140 | Case 4: ' end of transmission , file is transmitted
141 | If Wrd > 0 And Bkind = 0 Then ' if there was something left in the page
142 | Wrd = 0 'Z pointer needs wrd to be 0
143 | Spmcrval = 5 : Gosub Do_spm 'write page
144 | Spmcrval = 17 : Gosub Do_spm ' re-enable page
145 | End If
146 | Print Chr(ack); ' send ack and ready
147 |
148 | ' Portb.3 = 0 ' simple indication that we are finished and ok
149 | Waitms 20
150 | Goto _reset ' start new program
151 | Case &H18: ' PC aborts transmission
152 | Goto _reset ' ready
153 | Case 123 : Exit Do 'was probably still in the buffer
154 | Case 124 : Exit Do
155 | Case Else
156 | Exit Do ' no valid data
157 | End Select
158 | Loop
159 |
160 | If Bretries > 0 Then 'attempte left?
161 | Waitms 1000
162 | Decr Bretries 'decrease attempts
163 | Else
164 | Goto _reset 'reset chip
165 | End If
166 |
167 | Loop
168 |
169 | '---[write one or more pages]---------------------------------------------------
170 | Writepage:
171 | If Bkind = 0 Then
172 | For J = 1 To 128 Step 2 'we write 2 bytes into a page
173 | Vl = Buf(j) : Vh = Buf(j + 1) 'get Low and High bytes
174 | lds r0, {vl} 'store them into r0 and r1 registers
175 | lds r1, {vh}
176 | Spmcrval = 1 : Gosub Do_spm 'write value into page at word address
177 | Wrd = Wrd + 2 ' word address increases with 2 because LS bit of Z is not used
178 | If Wrd = Maxword Then ' page is full
179 | Wrd = 0 'Z pointer needs wrd to be 0
180 | Spmcrval = 5 : Gosub Do_spm 'write page
181 | Spmcrval = 17 : Gosub Do_spm ' re-enable page
182 |
183 | Page = Page + 1 'next page
184 | Spmcrval = 3 : Gosub Do_spm ' erase next page
185 | Spmcrval = 17 : Gosub Do_spm ' re-enable page
186 | End If
187 | Next
188 |
189 | Else 'eeprom
190 | For J = 1 To 128
191 | Writeeeprom Buf(j) , Wrd
192 | Wrd = Wrd + 1
193 | Next
194 | End If
195 | Return
196 |
197 | Do_spm:
198 | Bitwait Spmcsr.0 , Reset ' check for previous SPM complete
199 | Bitwait Eecr.1 , Reset 'wait for eeprom
200 |
201 | Z = Page 'make equal to page
202 | Shift Z , Left , Maxwordshift 'shift to proper place
203 | Z = Z + Wrd 'add word
204 | lds r30,{Z}
205 | lds r31,{Z+1}
206 |
207 | #if _romsize > 65536
208 | lds r24,{Z+2}
209 | sts rampz,r24 ' we need to set rampz also for the M128
210 | #endif
211 |
212 | Spmcsr = Spmcrval 'assign register
213 | spm 'this is an asm instruction
214 | nop
215 | nop
216 | Return
