1 | #include <msp430.h>
2 |
3 | #define NUM_BYTES_TX 1 // How many bytes?
4 | #define NUM_BYTES_RX 2
5 |
6 | int RXByteCtr, RPT_Flag = 0; // enables repeated start when 1
7 | volatile unsigned char RxBuffer[128]; // Allocate 128 byte of RAM
8 | unsigned char *PTxData; // Pointer to TX data
9 | unsigned char *PRxData; // Pointer to RX data
10 | unsigned char TXByteCtr, RX = 0, UX = 0;
11 | unsigned char MSData = 0x00;
12 |
13 | void setupUART(void);
14 | void Setup_TX(void);
15 | void Setup_RX(void);
16 | void Transmit(void);
17 | void Receive(void);
18 |
19 | int main(void)
20 | {
21 | WDTCTL = WDTPW + WDTHOLD; // Stop WDT
22 | P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0
23 | P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0
24 |
25 | while(1){
26 |
27 | setupUART();
28 | UX = 0;
29 | RX = 0;
30 | //Transmit process
31 | Setup_TX();
32 | RPT_Flag = 1;
33 | Transmit();
34 | while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
35 |
36 | //Receive process
37 | Setup_RX();
38 | Receive();
39 | while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
40 | }
41 | }
42 |
43 | //---------------------------------------------------------------------------------------
44 |
45 | #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
46 | #pragma vector = USCIAB0RX_VECTOR
47 | __interrupt void USCIAB0RX_ISR(void)
48 | #elif defined(__GNUC__)
49 | void __attribute__ ((interrupt(USCIAB0TX_VECTOR))) USCIAB0TX_ISR (void)
50 | #else
51 | #error Compiler not supported!
52 | #endif
53 | {
54 | if((UX==1) && (RX == 1) && (UCA0RXBUF == 'u'))
55 | {
56 | UX=0;
57 | IE2 &= ~UCA0RXIE;
58 | //IFG2 &=~(UCA0TXIFG + UCA0RXIFG);
59 | IFG2 &=~(UCA0TXIFG);
60 | __bic_SR_register_on_exit(CPUOFF);
61 | }
62 | }
63 |
64 | //-------------------------------------------------------------------------------
65 | // The USCI_B0 data ISR is used to move received data from the I2C slave
66 | // to the MSP430 memory. It is structured such that it can be used to receive
67 | // any 2+ number of bytes by pre-loading RXByteCtr with the byte count.
68 | //-------------------------------------------------------------------------------
69 | #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
70 | #pragma vector = USCIAB0TX_VECTOR
71 | __interrupt void USCIAB0TX_ISR(void)
72 | #elif defined(__GNUC__)
73 | void __attribute__ ((interrupt(USCIAB0TX_VECTOR))) USCIAB0TX_ISR (void)
74 | #else
75 | #error Compiler not supported!
76 | #endif
77 | {
78 | if(RX == 1){ // Master Recieve?
79 | RXByteCtr--; // Decrement RX byte counter
80 | if (RXByteCtr)
81 | {
82 | *PRxData++ = UCB0RXBUF; // Move RX data to address PRxData
83 | UCA0TXBUF = RxBuffer[0];
84 | }
85 | else
86 | {
87 | if(RPT_Flag == 0)
88 | UCB0CTL1 |= UCTXSTP; // No Repeated Start: stop condition
89 | if(RPT_Flag == 1){ // if Repeated Start: do nothing
90 | RPT_Flag = 0;
91 | }
92 | *PRxData = UCB0RXBUF; // Move final RX data to PRxData
93 | UCA0TXBUF = RxBuffer[1];
94 | __bic_SR_register_on_exit(CPUOFF); // Exit LPM0
95 | }}
96 |
97 | else{ // Master Transmit
98 | if (TXByteCtr) // Check TX byte counter
99 | {
100 | UCB0TXBUF = MSData; // Load TX buffer
101 | TXByteCtr--; // Decrement TX byte counter
102 | }
103 | else
104 | {
105 | if(RPT_Flag == 1){
106 | RPT_Flag = 0;
107 | PTxData = &MSData; // TX array start address
108 | TXByteCtr = NUM_BYTES_TX; // Load TX byte counter
109 | __bic_SR_register_on_exit(CPUOFF);
110 | }
111 | else{
112 | UCB0CTL1 |= UCTXSTP; // I2C stop condition
113 | IFG2 &= ~UCB0TXIFG; // Clear USCI_B0 TX int flag
114 | __bic_SR_register_on_exit(CPUOFF); // Exit LPM0
115 | }
116 | }
117 | }
118 |
119 | }
120 |
121 | void Setup_TX(void){
122 | __disable_interrupt();
123 | RX = 0;
124 | IE2 &= ~UCB0RXIE;
125 | while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent// Disable RX interrupt
126 | UCB0CTL1 |= UCSWRST; // Enable SW reset
127 | UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
128 | UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
129 | UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz
130 | UCB0BR1 = 0;
131 | UCB0I2CSA = 0x20; // Slave Address is 048h
132 | UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
133 | IE2 |= UCB0TXIE; // Enable TX interrupt
134 | }
135 | void Setup_RX(void){
136 | __disable_interrupt();
137 | RX = 1;
138 | IE2 &= ~UCB0TXIE;
139 | UCB0CTL1 |= UCSWRST; // Enable SW reset
140 | UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
141 | UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
142 | UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz
143 | UCB0BR1 = 0;
144 | UCB0I2CSA = 0x20; // Slave Address is 048h
145 | UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
146 | IE2 |= UCB0RXIE; // Enable RX interrupt
147 | }
148 | void Transmit(void){
149 | PTxData = &MSData; // TX array start address
150 | TXByteCtr = NUM_BYTES_TX; // Load TX byte counter
151 | while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
152 | UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition
153 | __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts
154 | }
155 | void Receive(void){
156 | PRxData = (unsigned char *)RxBuffer; // Start of RX buffer
157 | RXByteCtr = NUM_BYTES_RX-1; // Load RX byte counter
158 | while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent
159 | UCB0CTL1 |= UCTXSTT; // I2C start condition
160 | __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts
161 | }
162 |
163 | void setupUART(){
164 | IE2 &= ~UCA0RXIE;
165 | IE2 &= ~UCB0RXIE;
166 | IE2 &= ~UCA0TXIE;
167 | IE2 &= ~UCB0TXIE;
168 | UX = 1;
169 | RX = 1;
170 | DCOCTL = 0; // Select lowest DCOx and MODx settings
171 | BCSCTL1 = CALBC1_1MHZ; // Set DCO
172 | DCOCTL = CALDCO_1MHZ;
173 | P1SEL = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
174 | P1SEL2 = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
175 | UCA0CTL1 |= UCSSEL_2; // SMCLK
176 | UCA0BR0 = 104; // 1MHz 9600
177 | UCA0BR1 = 0; // 1MHz 9600
178 | UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
179 | UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
180 | IE2 |= UCA0RXIE; // Enable USCI_A0 RX interrupt
181 |
182 | __bis_SR_register(CPUOFF + GIE); // Enter LPM0, interrupts enabled
183 | }
