1 | #include <ESP8266WiFi.h>
2 | #include "EEPROM.h"
3 |
4 | //////////////////////
5 | // WiFi Definitions //
6 | //////////////////////
7 | const char WiFiAPPSK[] = "sparkfun";
8 |
9 | /////////////////////
10 | // Pin Definitions //
11 | /////////////////////
12 | const int LED_PIN = 5; // Thing's onboard, green LED
13 | const int ANALOG_PIN = A0; // The only analog pin on the Thing
14 | const int DIGITAL_PIN = 12; // Digital pin to be read
15 | String NewRvalue;
16 |
17 | WiFiServer server(80);
18 |
19 | void setup()
20 | {
21 | initHardware();
22 | setupWiFi();
23 | server.begin();
24 | }
25 |
26 | void loop()
27 | {
28 | // Check if a client has connected
29 | WiFiClient client = server.available();
30 | if (!client) {
31 | return;
32 | }
33 |
34 | // Read the first line of the request
35 | String req = client.readStringUntil('\r');
36 | Serial.println(req);
37 | //neu2
38 | int IndexBeginRValue = req.indexOf('=') + 1;
39 | int IndexEndRValue = req.indexOf('&');
40 | //Serial.println(IndexBeginRValue);
41 | //Serial.println(IndexEndRValue);
42 | if (req.startsWith("R0", 6)) {
43 | NewRvalue = req.substring(IndexBeginRValue,IndexEndRValue);
44 | Serial.println(NewRvalue);
45 | }
46 |
47 | String TestString = "<input type=\"range\" name=\"R0\" min=\"0\" max=\"255\" value=\""+NewRvalue+"\" style=\"width:95%\" />";
48 | Serial.println(TestString);
49 |
50 | client.flush();
51 |
52 | //neu2
53 | /*
54 | client.flush();
55 |
56 | // Match the request
57 | int val = -1; // We'll use 'val' to keep track of both the
58 | // request type (read/set) and value if set.
59 | if (req.indexOf("/led/0") != -1)
60 | val = 0; // Will write LED low
61 | else if (req.indexOf("/led/1") != -1)
62 | val = 1; // Will write LED high
63 | else if (req.indexOf("/read") != -1)
64 | val = -2; // Will print pin reads
65 | // Otherwise request will be invalid. We'll say as much in HTML
66 |
67 | // Set GPIO5 according to the request
68 | if (val >= 0)
69 | digitalWrite(LED_PIN, val);
70 |
71 | client.flush();
72 | */
73 |
74 |
75 | // Prepare the response. Start with the common header:
76 | String s = "HTTP/1.1 200 OK\r\n";
77 | s += "Content-Type: text/html\r\n\r\n";
78 | s += "<!DOCTYPE HTML>\r\n<html>\r\n";
79 | //neu
80 | s += "<form method=\"get\">";
81 | s += "Headlight Control";
82 | //neu
83 | /*
84 | // If we're setting the LED, print out a message saying we did
85 | if (val >= 0)
86 | {
87 | s += "LED is now ";
88 | s += (val)?"on":"off";
89 | }
90 | */
91 | // else //if (val == -2)
92 | //{ // If we're reading pins, print out those values:
93 | s += "Analog Pin = ";
94 | s += String(analogRead(ANALOG_PIN));
95 | s += "<br>"; // Go to the next line.
96 | s += "Digital Pin 12 = ";
97 | s += String(digitalRead(DIGITAL_PIN));
98 | s += "<input type=\"range\" name=\"R0\" min=\"0\" max=\"255\" value=\""+NewRvalue+"\" style=\"width:95%\" />";
99 | s += "<br><br>"; // Go to the next line.
100 | s += "<input type=\"range\" name=\"G0\" min=\"0\" max=\"255\" value=\"128\" style=\"width:95%\" />";
101 | s += "<br><br>"; // Go to the next line.
102 | s += "<input type=\"range\" name=\"G0\" min=\"0\" max=\"255\" value=\"128\" style=\"width:95%\" />";
103 | s += "<br><br>"; // Go to the next line.
104 | s += "<input type=\"range\" name=\"W0\" min=\"0\" max=\"255\" value=\"128\" style=\"width:95%\" />";
105 | s += "<br><br>"; // Go to the next line.
106 | s += "<p> <input type=\"submit\"> </p>";
107 | s += "</form>";
108 |
109 | // }
110 |
111 | /*
112 | else
113 | {
114 | s += "Invalid Request.<br> Try /led/1, /led/0, or /read.";
115 | }
116 | */
117 | s += "</html>\n";
118 |
119 | // Send the response to the client
120 | client.print(s);
121 | delay(1);
122 | //Serial.println("Client disonnected");
123 |
124 | // The client will actually be disconnected
125 | // when the function returns and 'client' object is detroyed
126 | }
127 |
128 | void setupWiFi()
129 | {
130 | WiFi.mode(WIFI_AP);
131 |
132 | // Do a little work to get a unique-ish name. Append the
133 | // last two bytes of the MAC (HEX'd) to "Thing-":
134 | uint8_t mac[WL_MAC_ADDR_LENGTH];
135 | WiFi.softAPmacAddress(mac);
136 | String macID = String(mac[WL_MAC_ADDR_LENGTH - 2], HEX) +
137 | String(mac[WL_MAC_ADDR_LENGTH - 1], HEX);
138 | macID.toUpperCase();
139 | String AP_NameString = "ESP_RGBW_TEST";
140 |
141 | char AP_NameChar[AP_NameString.length() + 1];
142 | memset(AP_NameChar, 0, AP_NameString.length() + 1);
143 |
144 | for (int i=0; i<AP_NameString.length(); i++)
145 | AP_NameChar[i] = AP_NameString.charAt(i);
146 |
147 | WiFi.softAP(AP_NameChar, WiFiAPPSK);
148 | }
149 |
150 | void initHardware()
151 | {
152 | Serial.begin(115200);
153 | pinMode(DIGITAL_PIN, INPUT_PULLUP);
154 | pinMode(LED_PIN, OUTPUT);
155 | digitalWrite(LED_PIN, LOW);
156 | // Don't need to set ANALOG_PIN as input,
157 | // that's all it can be.
158 | }
