1 | DMA_HandleTypeDef hdma_sai2_Input;
2 | DMA_HandleTypeDef hdma_sai2_Output;
3 | static uint32_t SAI2_client =0;
4 |
5 | void HAL_SAI_MspInit(SAI_HandleTypeDef* hsai)
6 | {
7 | GPIO_InitTypeDef GPIO_InitStruct;
8 | /* SAI2 */
9 | if(hsai->Instance==SAI2_Block_A)
10 | {
11 | /* Peripheral clock enable */
12 | if (SAI2_client == 0)
13 | {
14 | __HAL_RCC_SAI2_CLK_ENABLE();
15 | }
16 | SAI2_client ++;
17 |
18 | /**SAI2_A_Block_A GPIO Configuration
19 | PD11 ------> SAI2_SD_A
20 | */
21 | GPIO_InitStruct.Pin = GPIO_PIN_11;
22 | GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
23 | GPIO_InitStruct.Pull = GPIO_NOPULL;
24 | GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
25 | GPIO_InitStruct.Alternate = GPIO_AF10_SAI2;
26 | HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
27 |
28 | /* Peripheral DMA init*/
29 | hdma_sai2_Input.Instance = DMA2_Stream4;
30 | hdma_sai2_Input.Init.Channel = DMA_CHANNEL_3;
31 | hdma_sai2_Input.Init.Direction = DMA_PERIPH_TO_MEMORY;
32 | hdma_sai2_Input.Init.PeriphInc = DMA_PINC_DISABLE;
33 | hdma_sai2_Input.Init.MemInc = DMA_MINC_ENABLE;
34 | hdma_sai2_Input.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
35 | hdma_sai2_Input.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
36 | hdma_sai2_Input.Init.Mode = DMA_CIRCULAR;
37 | hdma_sai2_Input.Init.Priority = DMA_PRIORITY_HIGH;
38 | hdma_sai2_Input.Init.FIFOMode = DMA_FIFOMODE_ENABLE;
39 | hdma_sai2_Input.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_HALFFULL;
40 | hdma_sai2_Input.Init.MemBurst = DMA_MBURST_SINGLE;
41 | hdma_sai2_Input.Init.PeriphBurst = DMA_PBURST_SINGLE;
42 |
43 | if (HAL_DMA_Init(&hdma_sai2_Input) != HAL_OK)
44 | {
45 | Error_Handler();
46 | }
47 |
48 | /* Several peripheral DMA handle pointers point to the same DMA handle.
49 | Be aware that there is only one stream to perform all the requested DMAs. */
50 | __HAL_LINKDMA(hsai,hdmarx,hdma_sai2_Input);
51 | __HAL_LINKDMA(hsai,hdmatx,hdma_sai2_Input);
52 |
53 | }
54 | if(hsai->Instance==SAI2_Block_B)
55 | {
56 | /* Peripheral clock enable */
57 | if (SAI2_client == 0)
58 | {
59 | __HAL_RCC_SAI2_CLK_ENABLE();
60 | }
61 | SAI2_client ++;
62 |
63 | /**SAI2_B_Block_B GPIO Configuration
64 | PC0 ------> SAI2_FS_B
65 | PA0/WKUP ------> SAI2_SD_B
66 | PE12 ------> SAI2_SCK_B
67 | PE14 ------> SAI2_MCLK_B
68 | */
69 | GPIO_InitStruct.Pin = GPIO_PIN_0;
70 | GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
71 | GPIO_InitStruct.Pull = GPIO_NOPULL;
72 | GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
73 | GPIO_InitStruct.Alternate = GPIO_AF8_SAI2;
74 | HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
75 |
76 | GPIO_InitStruct.Pin = GPIO_PIN_0;
77 | GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
78 | GPIO_InitStruct.Pull = GPIO_NOPULL;
79 | GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
80 | GPIO_InitStruct.Alternate = GPIO_AF10_SAI2;
81 | HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
82 |
83 | GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_14;
84 | GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
85 | GPIO_InitStruct.Pull = GPIO_NOPULL;
86 | GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
87 | GPIO_InitStruct.Alternate = GPIO_AF10_SAI2;
88 | HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
89 |
90 | /* Peripheral DMA init*/
91 | hdma_sai2_Output.Instance = DMA2_Stream6;
92 | hdma_sai2_Output.Init.Channel = DMA_CHANNEL_3;
93 | hdma_sai2_Output.Init.Direction = DMA_MEMORY_TO_PERIPH;
94 | hdma_sai2_Output.Init.PeriphInc = DMA_PINC_DISABLE;
95 | hdma_sai2_Output.Init.MemInc = DMA_MINC_ENABLE;
96 | hdma_sai2_Output.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
97 | hdma_sai2_Output.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
98 | hdma_sai2_Output.Init.Mode = DMA_CIRCULAR;
99 | hdma_sai2_Output.Init.Priority = DMA_PRIORITY_HIGH;
100 | hdma_sai2_Output.Init.FIFOMode = DMA_FIFOMODE_ENABLE;
101 | hdma_sai2_Output.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_HALFFULL;
102 | hdma_sai2_Output.Init.MemBurst = DMA_MBURST_SINGLE;
103 | hdma_sai2_Output.Init.PeriphBurst = DMA_PBURST_SINGLE;
104 | if (HAL_DMA_Init(&hdma_sai2_Output) != HAL_OK)
105 | {
106 | Error_Handler();
107 | }
108 |
109 | /* Several peripheral DMA handle pointers point to the same DMA handle.
110 | Be aware that there is only one stream to perform all the requested DMAs. */
111 | __HAL_LINKDMA(hsai,hdmarx,hdma_sai2_Output);
112 | __HAL_LINKDMA(hsai,hdmatx,hdma_sai2_Output);
113 | }
114 | }
115 |
116 |
117 | static void MX_SAI2_Init(void)
118 | {
119 | // output
120 | hsai_output.Instance = SAI2_Block_B;
121 | hsai_output.Init.AudioMode = SAI_MODEMASTER_TX;
122 | hsai_output.Init.Synchro = SAI_ASYNCHRONOUS;
123 | hsai_output.Init.OutputDrive = SAI_OUTPUTDRIVE_DISABLE;
124 |
125 | hsai_output.Init.NoDivider = SAI_MASTERDIVIDER_ENABLE;
126 | hsai_output.Init.FIFOThreshold = SAI_FIFOTHRESHOLD_FULL;
127 | hsai_output.Init.AudioFrequency = SAI_AUDIO_FREQUENCY_8K;
128 | hsai_output.Init.SynchroExt = SAI_SYNCEXT_DISABLE;
129 | hsai_output.Init.MonoStereoMode = SAI_STEREOMODE;
130 | hsai_output.Init.CompandingMode = SAI_NOCOMPANDING;
131 | hsai_output.Init.TriState = SAI_OUTPUT_NOTRELEASED;
132 |
133 | if (HAL_SAI_InitProtocol(&hsai_output, SAI_I2S_STANDARD, SAI_PROTOCOL_DATASIZE_16BIT, 2) != HAL_OK)
134 | {
135 | Error_Handler();
136 | }
137 | // input
138 | hsai_input.Instance = SAI2_Block_A;
139 | hsai_input.Init.AudioMode = SAI_MODESLAVE_RX;
140 | hsai_input.Init.Synchro = SAI_SYNCHRONOUS;
141 | hsai_input.Init.OutputDrive = SAI_OUTPUTDRIVE_DISABLE;
142 |
143 | // hsai_input.Init.NoDivider = SAI_MASTERDIVIDER_ENABLE;
144 | hsai_input.Init.FIFOThreshold = SAI_FIFOTHRESHOLD_FULL;
145 | /// hsai_input.Init.AudioFrequency = SAI_AUDIO_FREQUENCY_8K;
146 | hsai_input.Init.SynchroExt = SAI_SYNCEXT_DISABLE;
147 | hsai_input.Init.MonoStereoMode = SAI_STEREOMODE;
148 | hsai_input.Init.CompandingMode = SAI_NOCOMPANDING;
149 | hsai_input.Init.TriState = SAI_OUTPUT_RELEASED;
150 |
151 | if (HAL_SAI_InitProtocol(&hsai_input, SAI_I2S_STANDARD, SAI_PROTOCOL_DATASIZE_16BIT, 2) != HAL_OK)
152 | {
153 | Error_Handler();
154 | }
155 |
156 | }
157 |
158 | static void MX_DMA_Init(void)
159 | {
160 | /* DMA controller clock enable */
161 | __HAL_RCC_DMA2_CLK_ENABLE();
162 |
163 | /* DMA interrupt init */
164 | /* DMA2_Stream4_IRQn interrupt configuration */
165 | HAL_NVIC_SetPriority(DMA2_Stream4_IRQn, MEDIA_AL_IRQ_PREPRIO , MEDIA_AL_IRQ_SUBRIO);
166 | HAL_NVIC_EnableIRQ(DMA2_Stream4_IRQn);
167 |
168 | /* DMA2_Stream6_IRQn interrupt configuration */
169 | HAL_NVIC_SetPriority(DMA2_Stream6_IRQn, MEDIA_AL_IRQ_PREPRIO , MEDIA_AL_IRQ_SUBRIO);
170 | HAL_NVIC_EnableIRQ(DMA2_Stream6_IRQn);
171 | }
172 |
173 | void DMA2_Stream4_IRQHandler(void)
174 | {
175 | HAL_DMA_IRQHandler( hsai_input.hdmarx );
176 | }
177 |
178 | void DMA2_Stream6_IRQHandler(void)
179 | {
180 | HAL_DMA_IRQHandler( hsai_output.hdmatx );
181 | }
182 |
183 | static void Start_Stream( uint8_t* Play, uint8_t* Record, uint32_t Size ){
184 | HAL_SAI_Transmit_DMA( &hsai_output, (uint8_t *)Play , Size );
185 | HAL_SAI_Receive_DMA( &hsai_input , (uint8_t *)Record , Size );
186 | }
187 |
188 |
189 | //PLAYBACK
190 | void HAL_SAI_TxCpltCallback(SAI_HandleTypeDef *hsai)
191 | {
192 | if( hsai->Instance == SAI2_Block_B ){
193 | }else if( hsai->Instance == SAI2_Block_A ){
194 |
195 | }
196 | }
197 | void HAL_SAI_TxHalfCpltCallback(SAI_HandleTypeDef *hsai)
198 | {
199 | if( hsai->Instance == SAI2_Block_B ){
200 | }else if( hsai->Instance == SAI2_Block_A ){
201 |
202 | }
203 | }
204 |
205 | //RECORD
206 | void HAL_SAI_RxCpltCallback(SAI_HandleTypeDef *hsai)
207 | {
208 | if( hsai->Instance == SAI2_Block_B ){
209 | }else if( hsai->Instance == SAI2_Block_A ){
210 | }
211 | }
212 | void HAL_SAI_RxHalfCpltCallback(SAI_HandleTypeDef *hsai)
213 | {
214 | if( hsai->Instance == SAI2_Block_B ){
215 | }else if( hsai->Instance == SAI2_Block_A ){
216 | }
217 | }
218 |
219 | void HAL_SAI_ErrorCallback(SAI_HandleTypeDef *hsai)
220 | {
221 | if( hsai->Instance == SAI2_Block_B ){
222 | }else if( hsai->Instance == SAI2_Block_A ){
223 | }
224 | }
