1 | #include <avr/io.h>
2 | #include <avr/interrupt.h>
3 | #include <util/delay.h>
4 | #include "spi.h" // definition der funktionen
5 | #include "nRF24L01.h"
6 | #include "nrf24l01_function.h" // definition der funktion
7 |
8 |
9 | #define BIT(x) (1 << (x))
10 | #define SETBITS(x,y) ((x) |= (y))
11 | #define CLEARBITS(x,y) ((x) &= (~(y)))
12 | #define TOGGLEBITS(x,y) ((x) ^= (y))
13 | #define SETBIT(x,y) SETBITS((x), (BIT((y))))
14 | #define CLEARBIT(x,y) CLEARBITS((x), (BIT((y))))
15 | #define TOGGLEBIT(x,y) TOGGLEBITS((x), (BIT((y))))
16 |
17 | #define DD_CE 1
18 | #define DD_CSN 2
19 | #define DD_SCK 7
20 | #define DD_MOSI 5
21 | #define DD_MISO 6
22 | #define DD_IRQ 0
23 |
24 | ISR (TIMER0_OVF_vect);
25 | ISR (INT0_vect);
26 | void extern_interrupt_init(void);
27 | void timer_interrupt_init(void);
28 | void io_init(void);
29 | void slave_function(void);
30 | void master_function(void);
31 |
32 | volatile unsigned int counter = 0;
33 | volatile unsigned int sekunde_over = 0;
34 | volatile unsigned int received_data = 0;
35 | volatile unsigned int new_data = 0;
36 |
37 | int main(void){
38 | unsigned int k=0;
39 | spi_init();
40 | extern_interrupt_init(); // INT0 -> falling edge
41 | timer_interrupt_init(); // Timer0 -> 1ms
42 | io_init(); // PD5 -> output -> low
43 | sei(); // Global Interrupts activate
44 | while (1){
45 | // steht im ersten ATtiny
46 | if(sekunde_over) WriteToNrf(W_TX_PAYLOAD, 0x01);
47 |
48 | // steht im zweiten ATtiny
49 | if(new_data){
50 | for(k=0; k<received_data; k++){
51 | SETBIT(PORTD, 5); // schaltet LED ein
52 | _delay_ms(100);
53 | CLEARBIT(PORTD, 5);// schaltet LED aus
54 | _delay_ms(100);
55 | }
56 | new_data = 0;
57 | }
58 | }
59 | }
60 |
61 |
62 | void extern_interrupt_init(void){
63 | DDRB &= ~(1 << DDB6); // External Interrupt on INT0
64 |
65 | MCUCR |= (1 << ISC01); // INT0 falling edge
66 | MCUCR &= ~(1 << ISC00); // INT0 falling edge
67 |
68 | GIMSK |= (1 << INT0); // enable INT0 interrupt
69 | }
70 |
71 | void timer_interrupt_init(void){
72 | // Timer 0
73 | TCCR0A = (1 << WGM01); // CTC Modus
74 | TCCR0B = (1 << CS01) ; // prescaler 8 -> 1Mhz/8 = 125kHz
75 | OCR0A = 125-1; // -> 1ms Interrupt
76 | // Overflow Interrupt allow
77 | TIMSK |= (1 << OCIE0A);
78 | }
79 |
80 | void io_init(void){
81 | // LED as output
82 | //DDRD |= (1 << PD5);
83 | //PORTD &= ~(1 << PD5);
84 | SETBIT(DDRD, 5);
85 | CLEARBIT(PORTD, 5);
86 | }
87 |
88 |
89 | ISR (TIMER0_COMPA_vect){
90 | static unsigned int millisekunde = 0;
91 | static unsigned int sekunde = 0;
92 |
93 | millisekunde++;
94 |
95 | if(millisekunde == 1000){
96 | millisekunde = 0;
97 | sekunde_over = 1;
98 | sekunde++;
99 |
100 | if(sekunde == 60){
101 | sekunde = 0;
102 | }
103 | }
104 | }
105 |
106 | ISR(INT0_vect){
107 | if(new_data==0){
108 | cli(); // Disable global interrupt
109 | CLEARBIT(PORTB, DD_CE); // CE low - stop sending/listening
110 | new_data = 1;
111 | received_data = GetReg(R_RX_PAYLOAD);
112 |
113 | sei(); // enable global interrupts
114 | }
115 | }
