1 | #include "semihosting.h"
2 | #include <stdio.h>
3 | #include <stm32f0xx_conf.h>
4 |
5 | GPIO_InitTypeDef GPIO_InitStructure;
6 | SPI_InitTypeDef SPI_InitStructure;
7 |
8 |
9 | void SPI_Configure(void)
10 | {
11 | SPI_InitTypeDef SPI_InitStructure;
12 |
13 | RCC_APB1PeriphResetCmd(RCC_APB1Periph_SPI2, ENABLE);
14 |
15 | SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;
16 | SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //
17 | SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
18 | SPI_InitStructure.SPI_CPOL=SPI_CPOL_High;
19 | SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
20 | SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
21 | SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64; //
22 | SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
23 | SPI_InitStructure.SPI_CRCPolynomial = 7;
24 | SPI_Init(SPI2, &SPI_InitStructure);
25 | SPI_RxFIFOThresholdConfig(SPI2, SPI_RxFIFOThreshold_QF);
26 | SPI_Cmd(SPI2, ENABLE);
27 |
28 |
29 |
30 | }
31 |
32 |
33 | /*void LED_init(void){
34 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
35 | GPIO_InitStructure.GPIO_Mode=GPIO_Mode_OUT;
36 | GPIO_InitStructure.GPIO_Pin=(GPIO_Pin_9 | GPIO_Pin_8);
37 | GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
38 | GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_NOPULL;
39 | GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
40 | GPIO_Init(GPIOC,&GPIO_InitStructure);
41 |
42 | }*/
43 |
44 | void CS_config1(void)
45 | {
46 |
47 | // Definition von CLK und MOSI
48 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
49 |
50 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_15;
51 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
52 | GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
53 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
54 | GPIO_Init(GPIOB, &GPIO_InitStructure);
55 |
56 |
57 |
58 | // Defintion von Slave Select Pins
59 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
60 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12;
61 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
62 | GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
63 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
64 |
65 | GPIO_Init(GPIOB, &GPIO_InitStructure);
66 |
67 |
68 | GPIO_PinAFConfig(GPIOB,GPIO_PinSource13,GPIO_AF_0);
69 | GPIO_PinAFConfig(GPIOB,GPIO_PinSource15,GPIO_AF_0);
70 |
71 |
72 | }
73 |
74 | uint8_t send_and_read_byte(uint8_t cmd) // Funktionsdefinition
75 | {
76 | // cmd ist die zu sendende Variable
77 | uint8_t result;
78 | GPIO_SetBits(GPIOB, GPIO_Pin_12);
79 | while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET); //wait buffer empty
80 | SPI_SendData8(SPI2, cmd);
81 | while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) == SET); //wait finish sending // Read receiving FIFO until it is empty
82 | while (SPI_GetReceptionFIFOStatus(SPI2) != SPI_ReceptionFIFOStatus_Empty) {
83 | SPI_ReceiveData8(SPI2);
84 | }
85 | SPI_BiDirectionalLineConfig(SPI2, SPI_Direction_Rx);
86 | while (!(SPI2->SR & SPI_I2S_FLAG_RXNE)); // wait data received
87 | GPIO_ResetBits(GPIOB, GPIO_Pin_12); // CS high
88 | SPI2->CR1 |= SPI_Direction_Tx; // Set Tx mode to stop Rx clock
89 | result = SPI_ReceiveData8(SPI2);
90 | return result;
91 | }
92 |
93 | int main(void)
94 | {
95 | uint8_t counter=0;
96 | //LED_init();
97 | //input_config();
98 | //CS_config2();
99 | CS_config1();
100 | SPI_Configure();
101 |
102 | GPIO_ResetBits(GPIOB, GPIO_Pin_11);
103 |
104 | while(1) {
105 |
106 | counter=send_and_read_byte(0x0F);
107 |
108 | }
109 |
110 | }
