hi
ich versuche es kurz zu fassen:
µC: STM32F745
LCDC: Epson S1D13781
TFT: 3,5" 24bit RGB
benutzt wird CubeMX und die HAL lib
Der S1D13781 über indirect 8bit mode am FSMC verbunden:
1 | /** FMC GPIO Configuration
2 | PE2 ------> FMC_A23 ---> P/C#
3 | PD14 ------> FMC_D0 ---> DB0
4 | PD15 ------> FMC_D1 ---> DB1
5 | PD0 ------> FMC_D2 ---> DB2
6 | PD1 ------> FMC_D3 ---> DB3
7 | PE7 ------> FMC_D4 ---> DB4
8 | PE8 ------> FMC_D5 ---> DB5
9 | PE9 ------> FMC_D6 ---> DB6
10 | PE10 ------> FMC_D7 ---> DB7
11 | PD4 ------> FMC_NOE ---> RD
12 | PD5 ------> FMC_NWE ---> WR
13 | PD7 ------> FMC_NE1 ---> CS
14 | */
15 | // GPIO Parameter:
16 | GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
17 | GPIO_InitStruct.Pull = GPIO_PULLUP;
18 | GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
19 | GPIO_InitStruct.Alternate = GPIO_AF12_FMC;
FSMC ist folgendermaßen initialisiert:
1 | static void MX_FMC_Init(void)
2 | {
3 | FMC_NORSRAM_TimingTypeDef Timing;
4 |
5 | /** Perform the SRAM1 memory initialization sequence
6 | */
7 | hsram1.Instance = FMC_NORSRAM_DEVICE;
8 | hsram1.Extended = FMC_NORSRAM_EXTENDED_DEVICE;
9 | /* hsram1.Init */
10 | hsram1.Init.NSBank = FMC_NORSRAM_BANK1;
11 | hsram1.Init.DataAddressMux = FMC_DATA_ADDRESS_MUX_DISABLE;
12 | hsram1.Init.MemoryType = FMC_MEMORY_TYPE_SRAM;
13 | hsram1.Init.MemoryDataWidth = FMC_NORSRAM_MEM_BUS_WIDTH_8;
14 | hsram1.Init.BurstAccessMode = FMC_BURST_ACCESS_MODE_DISABLE;
15 | hsram1.Init.WaitSignalPolarity = FMC_WAIT_SIGNAL_POLARITY_LOW;
16 | hsram1.Init.WaitSignalActive = FMC_WAIT_TIMING_BEFORE_WS;
17 | hsram1.Init.WriteOperation = FMC_WRITE_OPERATION_ENABLE;
18 | hsram1.Init.WaitSignal = FMC_WAIT_SIGNAL_DISABLE;
19 | hsram1.Init.ExtendedMode = FMC_EXTENDED_MODE_DISABLE;
20 | hsram1.Init.AsynchronousWait = FMC_ASYNCHRONOUS_WAIT_DISABLE;
21 | hsram1.Init.WriteBurst = FMC_WRITE_BURST_DISABLE;
22 | hsram1.Init.ContinuousClock = FMC_CONTINUOUS_CLOCK_SYNC_ONLY;
23 | hsram1.Init.WriteFifo = FMC_WRITE_FIFO_DISABLE;
24 | hsram1.Init.PageSize = FMC_PAGE_SIZE_NONE;
25 | /* Timing */
26 | Timing.AddressSetupTime = 10;
27 | Timing.AddressHoldTime = 0;
28 | Timing.DataSetupTime = 40;
29 | Timing.BusTurnAroundDuration = 0;
30 | Timing.CLKDivision = 0;
31 | Timing.DataLatency = 0;
32 | Timing.AccessMode = FMC_ACCESS_MODE_B;
33 | if (HAL_SRAM_Init(&hsram1, &Timing, NULL ) != HAL_OK)
34 | {
35 | Error_Handler();
36 | }
37 |
38 | /*Configure GPIO pin : PA8 */
39 | GPIO_InitStruct.Pin = GPIO_PIN_8;
40 | GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
41 | GPIO_InitStruct.Pull = GPIO_NOPULL;
42 | GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
43 | GPIO_InitStruct.Alternate = GPIO_AF0_MCO;
44 | HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
45 |
46 | HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSI, RCC_MCODIV_2);// 8Mhz
47 | }
mit den Modi und den Timings habe ich schon gespielt.
Daraus ergeben sich folgende Adressen:
1 | volatile char * LCD_COMMAND_ptr = ((char *) 0x60000000);
2 | volatile char * LCD_DATA_ptr = ((char *) (0x60000000 + ( 1 << 23))); // RS an pin A23
Laut datenblatt des S1D13781 :
1 | //write :
2 | *LCD_COMMAND_ptr = (UInt8) addr;
3 | *LCD_COMMAND_ptr = (UInt8)(addr>> 8);
4 | *LCD_COMMAND_ptr = (UInt8)(addr>>16);
5 |
6 | *LCD_DATA_ptr = (UInt8) val;
7 | *LCD_DATA_ptr = (UInt8)(val>> 8);
8 |
9 | // read
10 | *LCD_COMMAND_ptr = (UInt8) addr;
11 | *LCD_COMMAND_ptr = (UInt8)(addr>> 8);
12 | *LCD_COMMAND_ptr = (UInt8)(addr>>16);
13 | UInt16 Value = (UInt16)*LCD_DATA_ptr<<0;
14 | Value |= (UInt16)*LCD_DATA_ptr<<8;
Jedoch kommt nicht das heraus was im Datenblatt steht
Hat vieleicht jemand den Epson controler am laufen und kann tips geben?
Oder mache ich am FSMC was falsch?
Vielen dank
Grüße
