1 | #include <ShiftRegister74HC595.h>
2 |
3 | //config variables
4 | #define NUM_LED_COLUMNS (4)
5 | #define NUM_LED_ROWS (4)
6 | #define NUM_COLORS (1)
7 |
8 | // Global variables
9 | static bool LED_buffer[NUM_LED_COLUMNS][NUM_LED_ROWS];
10 | static int32_t next_advance;
11 | static uint8_t led_index;
12 |
13 | static const uint8_t ledcolumnpins[NUM_LED_COLUMNS] = {4,2,23,8};;
14 | static const uint8_t colorpins[NUM_LED_ROWS] = {21,17,12,7};
15 |
16 |
17 | ShiftRegister74HC595 sr (3, 7, 8, 6);
18 |
19 |
20 | static void setuppins()
21 | {
22 | uint8_t i;
23 |
24 | // initialize all of the output pins
25 |
26 | // LED column lines
27 | for(i = 0; i < NUM_LED_COLUMNS; i++)
28 | {
29 | // with nothing selected by default
30 | sr.set(ledcolumnpins[i], HIGH);
31 | }
32 |
33 | // LED row lines
34 | for(i = 0; i < NUM_LED_ROWS; i++)
35 | {
36 | // with nothing driven by default
37 | sr.set(colorpins[i], LOW);
38 | }
39 |
40 | }
41 |
42 | static void scan()
43 | {
44 | static uint8_t current = 0;
45 | uint8_t val;
46 | uint8_t i, j;
47 |
48 | // Select a column
49 | sr.set(ledcolumnpins[current], LOW);
50 |
51 | // write the row pins
52 | for(i = 0; i < NUM_LED_ROWS; i++)
53 | {
54 | if(LED_buffer[current][i])
55 | {
56 | sr.set(colorpins[i], HIGH);
57 | }
58 | }
59 |
60 | delay(1);
61 |
62 | sr.set(ledcolumnpins[current], HIGH);
63 |
64 | for(i = 0; i < NUM_LED_ROWS; i++)
65 | {
66 | sr.set(colorpins[i], LOW);
67 | }
68 |
69 | // Move on to the next column
70 | current++;
71 | if (current >= NUM_LED_COLUMNS)
72 | {
73 | current = 0;
74 | }
75 |
76 | }
77 |
78 | void setup()
79 | {
80 | // put your setup code here, to run once:
81 | Serial.begin(115200);
82 | Serial.print("Starting Setup...");
83 |
84 | // setup hardware
85 | setuppins();
86 |
87 | // init global variables
88 | next_advance = millis() + 1000;
89 | led_index = 0;
90 |
91 | // Initialize the LED display array
92 | for(uint8_t i = 0; i < NUM_LED_COLUMNS; i++)
93 | {
94 | for(uint8_t j = 0; j < NUM_LED_ROWS; j++)
95 | {
96 | LED_buffer[i][j] = false;
97 | }
98 | }
99 | // Set the first LED in the buffer on
100 | LED_buffer[0][0] = true;
101 |
102 | Serial.println("Setup Complete.");
103 |
104 | }
105 |
106 | void loop()
107 | {
108 | // put your main code here, to run repeatedly:
109 |
110 | scan();
111 |
112 | if(millis() >= next_advance)
113 | {
114 | next_advance = millis()+1000;
115 |
116 | // Vorherige LED Aus
117 | LED_buffer[led_index/NUM_LED_COLUMNS][led_index%NUM_LED_COLUMNS] = false;
118 |
119 | // Led 0-15 auswählen
120 | led_index++;
121 |
122 | // Nicht über die Maxiimale Array Size (16m in dem Fall)
123 | led_index %= (NUM_LED_COLUMNS * NUM_LED_ROWS);
124 |
125 | // Neue Led ausrechnen und anzeigen
126 | LED_buffer[led_index/NUM_LED_COLUMNS][led_index%NUM_LED_COLUMNS] = true;
127 | }
128 | }
