1 | /*
2 | Driving a DVD drive spindle three-phase motor
3 |
4 | This code was used for the stroboscope project
5 |
6 | This example code is in the public domain. Based on several Arduino code samples
7 |
8 | http://elabz.com/
9 |
10 | */
11 |
12 | // constants won't change. They're used here to
13 | // set pin numbers:
14 | const int buttonPin = 8;// the number of the direction pushbutton pin
15 | const int ledPin = 7; // the number of the status LED pin (not the flash LED)
16 | const int potPin = 0; // pot controls the RPM speed
17 | const int potPinFlash = 1; // pot controls the flash speed
18 | const int motorPin1 =9;
19 | const int motorPin2 =10;
20 | const int motorPin3 =11;
21 | const int flashPin =12;
22 | const int motorDelay=5; // together with pot controls the RPM
23 | const int flashDelay=2; // controls duration of flash
24 | const int frames=12; // has to be divisible by 3 in this version
25 | const int serialDelay = 2000; //debug only
26 | long serialLast =0; //debug only
27 | // Variables will change:
28 | boolean ledState = false; // the current state of the status LED output pin
29 | int buttonState; // the current reading from the direction input pin
30 | int potState; // the current reading from the RPM speed potentiometer
31 | int potStateFlash; // the current reading from the flash rate potentiometer
32 | int lastButtonState = LOW;
33 | int debounceDelay = 50; // the debounce time; increase if the output flickers
34 | boolean direct = true; // direction true=forward, false=backward
35 |
36 | /*
37 | int pwmSin[] = {127,110,94,78,64,50,37,26,17,10,4,1,0,1,4,10,17,26,37,50,64,78,94,110,127,144,160,176,191,204,217,228,237,244,250,253,254,253,250,244,237,228,217,204,191,176,160,144,127
38 | }; // array of PWM duty values for 8-bit timer - sine function
39 | */
40 |
41 | int pwmSin[]={511,444,379,315,256,200,150,106,68,39,17,4,0,4,17,39,68,106,150,200,256,315,379,444,511,578,643,707,767,822,872,916,954,983,1005,1018,1022,1018,1005,983,954,916,872,822,767,707,643,578,511
42 | }; // array of PWM duty values for 10-bit timer - sine function
43 |
44 | int increment;
45 | int flashIncrement = 0;
46 | int currentFlash=0;
47 | int currentStepA=0;
48 | int currentStepB=16;
49 | int currentStepC=32;
50 | // the following variables are long's because the time, measured in miliseconds,
51 | // will quickly become a bigger number than can be stored in an int.
52 | long lastDebounceTime = 0; // the last time the output pin was toggled
53 | long motorDelayActual = 0; // the actual delay, based on pot value and motor delay set above
54 | long flashDelayActual = 0;
55 | long flashDelayPerCycle = 0;
56 | long lastMotorDelayTime = 0;
57 | long flashTime = 0; // how long has flash been ON
58 | long flashTimeOFF = 0; // how long has flash been OFF
59 |
60 | void setup() {
61 |
62 | TCCR1B = TCCR1B & 0b11111000 | 0x01; // set PWM frequency @ 31250 Hz for Pins 9 and 10
63 | TCCR2B = TCCR2B & 0b11111000 | 0x01; // set PWM frequency @ 31250 Hz for Pins 11 and 3 (3 not used)
64 | // ICR1 = 255 ; // 8 bit resolution
65 | ICR1 = 1023 ; // 10 bit resolution
66 |
67 |
68 | pinMode(buttonPin, INPUT);
69 | pinMode(potPin, INPUT);
70 | pinMode(potPinFlash, INPUT);
71 | pinMode(ledPin, OUTPUT);
72 | pinMode(motorPin1, OUTPUT);
73 | pinMode(motorPin2, OUTPUT);
74 | pinMode(motorPin3, OUTPUT);
75 | pinMode(flashPin, OUTPUT);
76 | digitalWrite(flashPin, LOW);
77 | }
78 |
79 | void loop() {
80 | // read the state of the switch into a local variable:
81 | int reading = digitalRead(buttonPin);
82 |
83 | // check to see if you just pressed the button
84 | // (i.e. the input went from LOW to HIGH), and you've waited
85 | // long enough since the last press to ignore any noise:
86 |
87 | // If the switch changed, due to noise or pressing:
88 | if (reading != lastButtonState) {
89 | // reset the debouncing timer
90 | lastDebounceTime = millis();
91 | }
92 |
93 | if ((millis() - lastDebounceTime) > debounceDelay) {
94 | // whatever the reading is at, it's been there for longer
95 | // than the debounce delay, so take it as the actual current state:
96 | buttonState = reading;
97 | direct = !direct;
98 | ledState = !ledState;
99 | lastButtonState = reading;
100 | }
101 |
102 | // set the LED using the state of the button:
103 | digitalWrite(ledPin, ledState);
104 |
105 | // save the reading. Next time through the loop,
106 | // it'll be the lastButtonState:
107 |
108 | potStateFlash = analogRead(potPinFlash);
109 | potState = analogRead(potPin);
110 | motorDelayActual = potState * motorDelay / 100;
111 | // flashDelayActual = flashDelay+potStateFlash/200; // if we were controlling it with a POT
112 | flashDelayActual = flashDelay;
113 | move();
114 |
115 |
116 | }
117 |
118 |
119 |
120 | void move()
121 | {
122 | if((millis() - flashTime) > flashDelayActual)
123 | {
124 | digitalWrite(flashPin, HIGH);
125 |
126 | }
127 |
128 |
129 | if((millis() - lastMotorDelayTime) > motorDelayActual)
130 | { // delay time passed, move one step
131 |
132 |
133 | if (direct==true)
134 | {
135 | increment = 1;
136 | } else {
137 | increment = -1;
138 | }
139 | currentStepA = currentStepA + increment;
140 | if(currentStepA > 47) currentStepA = 0;
141 | if(currentStepA<0) currentStepA =47;
142 |
143 | currentStepB = currentStepB + increment;
144 | if(currentStepB > 47) currentStepB = 0;
145 | if(currentStepB<0) currentStepB =47;
146 |
147 | currentStepC = currentStepC + increment;
148 | if(currentStepC > 47) currentStepC = 0;
149 | if(currentStepC<0) currentStepC =47;
150 |
151 | lastMotorDelayTime = millis();
152 | //flashDelayPerCycle = flashDelayPerCycle + flashDelayPerCycle;
153 | currentFlash = currentFlash + 1;
154 | if(currentFlash>24)
155 | {
156 |
157 | digitalWrite(flashPin, LOW);
158 | currentFlash=0;
159 | flashTime = millis();
160 | flashDelayActual = millis();
161 |
162 |
163 | }
164 |
165 |
166 | }
167 |
168 | analogWrite(motorPin1, pwmSin[currentStepA]);
169 | analogWrite(motorPin2, pwmSin[currentStepB]);
170 | analogWrite(motorPin3, pwmSin[currentStepC]);
171 |
172 | }
