verkauft 2x LT1013CN8 - Low Power, Precision Rail-to-Rail Output Dual Op Amp URL: www.linear.com/product/LT1013 Gehäuse: DIL-8 - Input Voltage Range Extends to Ground - Output Swings to Ground While Sinking Current - Pin Compatible to 1458 and 324 with Precision Specs - Guaranteed Offset Voltage: 150μV Max - Guaranteed Low Drift: 2μV/°C Max - Guaranteed Offset Current: 0.8nA Max - Guaranteed High Gain - 5mA Load Current: 1.5 Million Min - 17mA Load Current: 0.8 Million Min - Guaranteed Low Supply Current: 500μA Max - Low Voltage Noise, 0.1Hz to 10Hz: 0.55μVP-P - Low Current Noise—Better than 0P-07, 0.07pA/√Hz
