1 | I2C_HandleTypeDef hi2c1;
2 | DMA_HandleTypeDef hdma_i2c1_rx;
3 | DMA_HandleTypeDef hdma_i2c1_tx;
4 |
5 | static void MX_GPIO_Init(void);
6 | static void MX_DMA_Init(void);
7 | static void MX_I2C1_Init(void);
8 |
9 | int main(void)
10 | {
11 |
12 | HAL_Init();
13 |
14 | SystemClock_Config();
15 |
16 | MX_GPIO_Init();
17 | MX_DMA_Init();
18 | MX_I2C1_Init();
19 |
20 | // Enable MPU6050 and use Gyro PLL as clock source
21 | uint8_t buf = MPU6050_CLOCK_PLL_XGYRO;
22 | if (HAL_I2C_Mem_Write_DMA(&hi2c1, MPU6050_ADDRESS_AD0_LOW << 1, MPU6050_RA_PWR_MGMT_1, I2C_MEMADD_SIZE_8BIT, &buf, 1) != HAL_OK) {
23 | Error_Handler();
24 | }
25 |
26 | // (Hier kommt noch mehr Code...)
27 | }
28 |
29 | /* I2C1 init function */
30 | static void MX_I2C1_Init(void)
31 | {
32 | hi2c1.Instance = I2C1;
33 | hi2c1.Init.ClockSpeed = 100000;
34 | hi2c1.Init.DutyCycle = I2C_DUTYCYCLE_2;
35 | hi2c1.Init.OwnAddress1 = 0;
36 | hi2c1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
37 | hi2c1.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
38 | hi2c1.Init.OwnAddress2 = 0;
39 | hi2c1.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
40 | hi2c1.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
41 |
42 | /* Peripheral clock enable */
43 | if (HAL_I2C_Init(&hi2c1) != HAL_OK)
44 | {
45 | Error_Handler();
46 | }
47 |
48 | }
49 |
50 | static void MX_DMA_Init(void)
51 | {
52 | __HAL_RCC_DMA1_CLK_ENABLE();
53 |
54 | /* DMA interrupt init */
55 | /* DMA1_Channel6_IRQn interrupt configuration */
56 | HAL_NVIC_SetPriority(DMA1_Channel6_IRQn, 0, 0);
57 | HAL_NVIC_EnableIRQ(DMA1_Channel6_IRQn);
58 |
59 | /* DMA1_Channel7_IRQn interrupt configuration */
60 | HAL_NVIC_SetPriority(DMA1_Channel7_IRQn, 0, 0);
61 | HAL_NVIC_EnableIRQ(DMA1_Channel7_IRQn);
62 | }
63 |
64 | void HAL_I2C_MspInit(I2C_HandleTypeDef* hi2c)
65 | {
66 |
67 | GPIO_InitTypeDef GPIO_InitStruct;
68 | if(hi2c->Instance==I2C1)
69 | {
70 | /**I2C1 GPIO Configuration
71 | PB6 ------> I2C1_SCL
72 | PB7 ------> I2C1_SDA
73 | */
74 | GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7;
75 | GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
76 | GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
77 | HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
78 |
79 | /* Peripheral clock enable */
80 |
81 | __HAL_RCC_I2C1_CLK_ENABLE();
82 | hdma_i2c1_rx.Instance = DMA1_Channel7;
83 | hdma_i2c1_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
84 | hdma_i2c1_rx.Init.PeriphInc = DMA_PINC_DISABLE;
85 | hdma_i2c1_rx.Init.MemInc = DMA_MINC_ENABLE;
86 | hdma_i2c1_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
87 | hdma_i2c1_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
88 | hdma_i2c1_rx.Init.Mode = DMA_NORMAL;
89 | hdma_i2c1_rx.Init.Priority = DMA_PRIORITY_LOW;
90 |
91 | if (HAL_DMA_Init(&hdma_i2c1_rx) != HAL_OK) {
92 | Error_Handler();
93 | }
94 |
95 | __HAL_LINKDMA(hi2c,hdmarx,hdma_i2c1_rx);
96 |
97 | hdma_i2c1_tx.Instance = DMA1_Channel6;
98 | hdma_i2c1_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
99 | hdma_i2c1_tx.Init.PeriphInc = DMA_PINC_DISABLE;
100 | hdma_i2c1_tx.Init.MemInc = DMA_MINC_ENABLE;
101 | hdma_i2c1_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
102 | hdma_i2c1_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
103 | hdma_i2c1_tx.Init.Mode = DMA_NORMAL;
104 | hdma_i2c1_tx.Init.Priority = DMA_PRIORITY_LOW;
105 |
106 | if (HAL_DMA_Init(&hdma_i2c1_tx) != HAL_OK) {
107 | Error_Handler();
108 | }
109 |
110 | __HAL_LINKDMA(hi2c,hdmatx,hdma_i2c1_tx);
111 |
112 | }
113 |
114 | }
