1 | // Purpose of this example:
2 | // Explanation of GPIO and INTC modules on AVR32 UC3 chips.
3 |
4 | // Hardware requirements:
5 | // EVK1101 & JTAGICE mkII.
6 |
7 | // Application description:
8 | // LED0 always blinks steadily.
9 | // Press on PB2 and LED1 is turned on. Release PB2 and LED1 is turned off.
10 | // Press on PB3 and LED2 is turned on. Release PB3 and LED2 is turned off.
11 |
12 |
13 | //_____ I N C L U D E S ___________________________________________________
14 |
15 | #include "compiler.h"
16 | #include "board.h"
17 | #include "gpio.h"
18 | #include "pm.h"
19 | #include "intc.h"
20 |
21 |
22 |
23 | //--------------------------------------------------------------------------
24 | __attribute__((__interrupt__))
25 | static void int_handler_port1_line0 (void)
26 | {
27 | if( gpio_get_pin_interrupt_flag( GPIO_PUSH_BUTTON_0 ) )
28 | { // PB2 generated the interrupt.
29 | LED_Toggle( LED1 );
30 | // Clear the interrupt flag of the pin PB2 is mapped to.
31 | gpio_clear_pin_interrupt_flag(GPIO_PUSH_BUTTON_0);
32 | }
33 | if( gpio_get_pin_interrupt_flag( GPIO_PUSH_BUTTON_1 ) )
34 | { // PB3 generated the interrupt.
35 | LED_Toggle( LED2 );
36 | // Clear the interrupt flag of the pin PB3 is mapped to.
37 | gpio_clear_pin_interrupt_flag(GPIO_PUSH_BUTTON_1);
38 | }
39 | }
40 | //--------------------------------------------------------------------------
41 |
42 |
43 | //--------------------------------------------------------------------------
44 | int main(void)
45 | {
46 | int i = 0;
47 | int j = 0;
48 | int x = 0;
49 |
50 |
51 | // switch to oscillator 0
52 | pm_switch_to_osc0(&AVR32_PM, FOSC0, OSC0_STARTUP);
53 |
54 | // Set all leds initial state.
55 | LED_Off( LED0 | LED1 | LED2 | LED3 );
56 |
57 | // GPIO config
58 | // configure push button to produce IT on input change
59 | // NOTE 1: GPIO_PUSH_BUTTON_0 & GPIO_PUSH_BUTTON_1 are defines you can find in
60 | // evk1101.h under /BOARDS/EVK1101/.
61 | // See the implementation of gpio_enable_pin_interrupt() in gpio.c under
62 | // /DRIVERS/GPIO/.
63 | gpio_enable_pin_interrupt(GPIO_PUSH_BUTTON_0 , GPIO_PIN_CHANGE); // PB2
64 | gpio_enable_pin_interrupt(GPIO_PUSH_BUTTON_1 , GPIO_PIN_CHANGE); // PB3
65 | // NOTE 2: GPIO_PUSH_BUTTON_0 & GPIO_PUSH_BUTTON_1 are in the same port.
66 | // (i.e. port 1, cf section 21.5 of the UC3B0256 datasheet for the computation
67 | // of a port knowing the pin, and see the evk1101 schematics (or the evk1101.h
68 | // file) + the section 12.8 of the UC3B0256 datasheet to know the pin mapping
69 | // of the pushbuttons).
70 | // Consider GPIO_PUSH_BUTTON_0 as an example: from evk1101.h, we see that
71 | // GPIO_PUSH_BUTTON_0 is AVR32_PIN_PB02. Open the UC3B0256 datasheet, go to
72 | // section 12.8, in the array look for pin PB02, we see that it is mapped to
73 | // GPIO 34. Using section 21.5, the formula to know the port of a pin is:
74 | // GPIO port = floor((GPIO number) / 32), so for GPIO_PUSH_BUTTON_0 we get:
75 | // floor(34/32) = 1.
76 | // Applying the same reasoning for GPIO_PUSH_BUTTON_1 (which is GPIO 35), we
77 | // find that it belongs to port 1 too.
78 |
79 | // NOTE 3: the 32 in the formula 'GPIO port = floor((GPIO number) / 32)'
80 | // corresponds to the fact that "The pins are managed as 32-bit ports" (see
81 | // section 21.5 second sentence): i.e. every port holds 32 pins max.
82 |
83 | // Interrupts config
84 | Disable_global_interrupt ();
85 | INTC_init_interrupts ();
86 | // register push button handler for PB2 and PB3
87 | INTC_register_interrupt( &int_handler_port1_line0, AVR32_GPIO_IRQ_0 + (GPIO_PUSH_BUTTON_0/8), INT0);
88 | INTC_register_interrupt( &int_handler_port1_line0, AVR32_GPIO_IRQ_0 + (GPIO_PUSH_BUTTON_1/8), INT0);
89 | // NOTE 4: reading section 21.4.7, paragraph 2:
90 | // "In every port there are four interrupt lines connected to the interrupt
91 | // controller. Every eigth interrupts in the port are ored together to form an
92 | // interrupt line."
93 | // So, for example, for port 1 :
94 | // GPIO32->GPIO39 : port 1 interrupt line 0 (for int-of-pin32, int-of-pin33,
95 | // int-of-pin34, int-of-pin35, int-of-pin36, int-of-pin37,
96 | // int-of-pin38 and int-of-pin39)
97 | // GPIO40->GPIO47 : port 1 interrupt line 1,
98 | // GPIO48->GPIO55 : port 1 interrupt line 2,
99 | // GPIO56->GPIO63 : port 1 interrupt line 3.
100 | //
101 | // That is why we use the formula "AVR32_GPIO_IRQ_0 + (GPIO_PUSH_BUTTON_0/8)"
102 | // to register the PB2; AVR32_GPIO_IRQ_0 is used as the base interrupt line
103 | // and we add '(GPIO_PUSH_BUTTON_0/8)' to register the corresponding interrupt
104 | // line.
105 |
106 | // NOTE 5: Since PB2 and PB3 are mapped to the GPIO pin GPIO34 and GPIO35, we
107 | // see that they belong to the same interrupt line. Two consequences in this
108 | // particular case:
109 | // 1) it's no use to register both. We left both registration in the code for
110 | // clarity's sake.
111 | // 2) we'll discriminate the cause of the interrupt (PB2 or PB3) in the
112 | // interrupt handler looking at the gpio_port1.ifr register.
113 | // See int_handler_gpio0() implementation.
114 |
115 | Enable_global_interrupt ();
116 |
117 | while (TRUE)
118 | {
119 | if (i == 100000)
120 | {
121 | i = 0;
122 | if (j == 2)
123 | {
124 | x = !x;
125 | if (x == 0)
126 | {
127 | LED_Off (LED0);
128 | }
129 | else
130 | {
131 | LED_On (LED0);
132 | }
133 | j = 0;
134 | }
135 | j++;
136 | }
137 | i++;
138 | }
139 | }
