1 | /*
2 | * When the Analog Watchdog is tripped this callback function gets executed
3 | */
4 | void HAL_ADC_LevelOutOfWindowCallback(ADC_HandleTypeDef* hadc)
5 | {
6 | DMA_Stream_TypeDef * dmaStreamTypeDefInstance = hadc->DMA_Handle->Instance;
7 |
8 | // (1) Stop ongoing DMA transfer with setting EN to Zero
9 | dmaStreamTypeDefInstance->CR &= ~DMA_SxCR_EN;
10 | //DMA Channel is stopped when EN is 0
11 | uint8_t i = 0;
12 | while(hadc->DMA_Handle->Instance->CR & DMA_SxCR_EN )
13 | {
14 | //DMA not Stopping )-;
15 | if(i>100)
16 | _Error_Handler(__FILE__, __LINE__);
17 | i++;
18 | }
19 | //DMA now is stopped and can be reconfigured
20 |
21 | //Read the position of the last circular write operation - needed for later move operations and is away when restarting
22 | uint32_t ndtr = dmaStreamTypeDefInstance->NDTR;
23 |
24 | // (2) Set Peripherial Register
25 | // Nothing TODO
26 |
27 | // (3) Set Memory Address
28 | dmaStreamTypeDefInstance->M0AR = (uint32_t)memoryPostRecordPtr;
29 |
30 | // (4) Configure Item Numbers
31 | dmaStreamTypeDefInstance->NDTR = memoryPostRecord;
32 |
33 | // (5) Set DMA channel
34 | // (6) Set Flow CNTRL
35 | // (7) Configure Stream Priority
36 | // (8) FIFO Mode
37 | // (9) Configure Direction, increment, data widths, circular and interrupts
38 | // Disable Circular mode Enable DMA
39 | dmaStreamTypeDefInstance->CR &= (~DMA_SxCR_CIRC);
40 |
41 | // (10) (Re)Enable DMA
42 | dmaStreamTypeDefInstance->CR |= DMA_SxCR_EN ;
43 |
44 | if(hadc1.Instance->SR & ADC_SR_OVR)
45 | HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_SET);
46 | if(!(dmaStreamTypeDefInstance->CR&DMA_SxCR_EN))
47 | HAL_GPIO_WritePin(white_Led_GPIO_Port, white_Led_Pin, GPIO_PIN_SET);
48 |
49 |
50 |
51 | //Disable Analog Watchdog before exiting
52 | hadc->Instance->CR1 &= (~ADC_CR1_AWDEN);
53 |
54 | //Calculate the position of the last circular write operation
55 | uint32_t elementPos = memoryCyclicSize - 1 - ndtr;
56 | uint16_t* ndtrPtr = &memoryCyclicPtr[elementPos];
57 |
58 | //Set LD2 LED
59 | HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_SET);
60 |
61 | systemState = LinearRecordingAndDataRearrangement;
62 | }
