Hi, I'm new on the forum. I made a custom board with a xmega128a3u. I tried since some days to flash the firmware over PDI with an atmelice. But with avrdude under linux, I can read the signature once and after that I just received an error message : xxx@i3tux ~ $ sudo avrdude -p x128a3u -c atmelice_pdi -v avrdude: Version 6.3, compiled on May 21 2017 at 13:45:34 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch System wide configuration file is "/usr/local/etc/avrdude.conf" User configuration file is "/home/moi/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : usb Using Programmer : atmelice_pdi avrdude: usbdev_open(): Found Atmel-ICE CMSIS-DAP, serno: J41800055455 avrdude: Found CMSIS-DAP compliant device, using EDBG protocol AVR Part : ATxmega128A3U Chip Erase delay : 0 us PAGEL : P00 BS2 : P00 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 0 StabDelay : 0 CmdexeDelay : 0 SyncLoops : 0 ByteDelay : 0 PollIndex : 0 PollValue : 0x00 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 prodsig 0 0 0 0 no 50 50 0 0 0 0x00 0x00 fuse1 0 0 0 0 no 1 0 0 0 0 0x00 0x00 fuse2 0 0 0 0 no 1 0 0 0 0 0x00 0x00 fuse4 0 0 0 0 no 1 0 0 0 0 0x00 0x00 fuse5 0 0 0 0 no 1 0 0 0 0 0x00 0x00 lock 0 0 0 0 no 1 0 0 0 0 0x00 0x00 data 0 0 0 0 no 0 0 0 0 0 0x00 0x00 eeprom 0 0 0 0 no 2048 32 0 0 0 0x00 0x00 application 0 0 0 0 no 131072 512 0 0 0 0x00 0x00 apptable 0 0 0 0 no 8192 512 0 0 0 0x00 0x00 boot 0 0 0 0 no 8192 512 0 0 0 0x00 0x00 flash 0 0 0 0 no 139264 512 0 0 0 0x00 0x00 usersig 0 0 0 0 no 512 512 0 0 0 0x00 0x00 fuse0 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Programmer Type : JTAGICE3_PDI Description : Atmel-ICE (ARM/AVR) in PDI mode ICE hardware version: 0 ICE firmware version: 1.38 (rel. 129) Serial number : J41800055455 Vtarget : 3.63 V JTAG clock megaAVR/program: 1000 kHz JTAG clock megaAVR/debug: 1000 kHz JTAG clock Xmega: 32 kHz PDI clock Xmega : 4000 kHz avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e9742 (probably x128a3u) avrdude done. Thank you. xxx@i3tux ~ $ sudo avrdude -p x128a3u -c atmelice_pdi -v avrdude: Version 6.3, compiled on May 21 2017 at 13:45:34 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch System wide configuration file is "/usr/local/etc/avrdude.conf" User configuration file is "/home/moi/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : usb Using Programmer : atmelice_pdi avrdude: usbdev_open(): Found Atmel-ICE CMSIS-DAP, serno: J41800055455 avrdude: Found CMSIS-DAP compliant device, using EDBG protocol AVR Part : ATxmega128A3U Chip Erase delay : 0 us PAGEL : P00 BS2 : P00 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 0 StabDelay : 0 CmdexeDelay : 0 SyncLoops : 0 ByteDelay : 0 PollIndex : 0 PollValue : 0x00 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 prodsig 0 0 0 0 no 50 50 0 0 0 0x00 0x00 fuse1 0 0 0 0 no 1 0 0 0 0 0x00 0x00 fuse2 0 0 0 0 no 1 0 0 0 0 0x00 0x00 fuse4 0 0 0 0 no 1 0 0 0 0 0x00 0x00 fuse5 0 0 0 0 no 1 0 0 0 0 0x00 0x00 lock 0 0 0 0 no 1 0 0 0 0 0x00 0x00 data 0 0 0 0 no 0 0 0 0 0 0x00 0x00 eeprom 0 0 0 0 no 2048 32 0 0 0 0x00 0x00 application 0 0 0 0 no 131072 512 0 0 0 0x00 0x00 apptable 0 0 0 0 no 8192 512 0 0 0 0x00 0x00 boot 0 0 0 0 no 8192 512 0 0 0 0x00 0x00 flash 0 0 0 0 no 139264 512 0 0 0 0x00 0x00 usersig 0 0 0 0 no 512 512 0 0 0 0x00 0x00 fuse0 0 0 0 0 no 1 0 0 0 0 0x00 0x00 Programmer Type : JTAGICE3_PDI Description : Atmel-ICE (ARM/AVR) in PDI mode ICE hardware version: 0 ICE firmware version: 1.38 (rel. 129) Serial number : J41800055455 Vtarget : 3.62 V JTAG clock megaAVR/program: 1000 kHz JTAG clock megaAVR/debug: 1000 kHz JTAG clock Xmega: 32 kHz PDI clock Xmega : 4000 kHz avrdude: bad response to AVR sign-on command: 0xa0 avrdude: retrying with external reset applied avrdude: bad response to AVR sign-on command: 0xa0 avrdude: retrying with external reset applied avrdude: JTAGEN fuse disabled? avrdude: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check. avrdude done. Thank you. I check and re-checked the connection. I have a Xplained A1 Dev board, and I don't have any problem to flash it with the atmelice and pdi connection. Has someone any Idee about this problem??
Hi, wenn Sie wollen, kann ich auf Deutsch übersetzen. Gruß, Alex
