Hallo zusammen, ich versuche gerade meinen Arduino mit Labview zu verbinden. Dabei schlägt schon die Beispiel-Datei "LIFA-Base" beim Hochladen fehl. Die Fehlermeldung: ... warning: left shift count >= width of type duration=(command[8]+ (command[7]<<8)+ (command[6]<<16)+(command[5]<<24)); .... Weis jemand was dabei zu tun ist? Danke schon mal im Voraus
Bzw. hier mal etwas mehr von der Fehlermeldung C:\Users\AD-Mess\Documents\LIFA\3\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino: In function 'void processCommand(unsigned char*)': C:\Users\AD-Mess\Documents\LIFA\3\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:150:60: warning: left shift count >= width of type duration=(command[8]+ (command[7]<<8)+ (command[6]<<16)+(command[5]<<24)); ^ C:\Users\AD-Mess\Documents\LIFA\3\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LabVIEWInterface.ino:150:77: warning: left shift count >= width of type duration=(command[8]+ (command[7]<<8)+ (command[6]<<16)+(command[5]<<24)); ^ In file included from C:\Users\AD-Mess\Documents\LIFA\3\LabVIEW Interface for Arduino\Firmware\LIFA_Base\PID_Windup_neu.ino:5:0: C:\Users\Piontekt\Arduino\arduino-1.8.3-windows\arduino-1.8.3\libraries\ LIFA_Base/LabVIEWInterface.h: At global scope: LabVIEWInterface.h:35: error: redefinition of 'unsigned char currentCommand [15]' unsigned char currentCommand[COMMANDLENGTH]; // The Current Command For The Arduino To Process ^ In file included from C:\Users\AD-Mess\Documents\LIFA\3\LabVIEW Interface for Arduino\Firmware\LIFA_Base\LIFA_Base.ino:26:0: sketch\LabVIEWInterface.h:35:16: note: 'unsigned char currentCommand [15]' previously declared here unsigned char currentCommand[COMMANDLENGTH]; // The Current Command For The Arduino To Process ^ In file included from C:\Users\AD-Mess\Documents\LIFA\3\LabVIEW Interface for Arduino\Firmware\LIFA_Base\PID_Windup_neu.ino:5:0: LabVIEWInterface.h:37: error: redefinition of 'unsigned char acqMode' unsigned char acqMode;
