Aaaalso, ich habe drei verschiedene Boards (alle eigenbau, eins geätzt,
zwei gefräst) und drei programmer (2x dragon, 1x avrisp2) und keiner
will mit den avrs reden. Die dragons reden nicht mal mit aufgesteckten
Controllern..
Folgendes ist zu erkennen
- Kein Target wird korrekt erkannt, wenn keins dran ist.
- Target Power wird gemessen, wenn Strom anliegt
- Verpoltes Target wird erkannt..
Hier das Log vom avrisp:
tecdroid@tecdroid:~$ avrdude -p m168 -c avrisp2 -P usb -i7 -B5 -b1200
-vvvv
avrdude: Version 6.3
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/home/tecdroid/.avrduderc"
User configuration file does not exist or is not a regular
file, skipping
Using Port : usb
Using Programmer : avrisp2
Overriding Baud Rate : 1200
Setting bit clk period : 5.0
Setting isp clock delay : 7
avrdude: usbdev_open(): Found AVRISP mkII, serno: 0000B0014818
avrdude: Sent: . [01]
avrdude: Recv: . [01] . [00] . [0a] A [41] V [56] R [52] I [49] S [53] P
[50] _ [5f] M [4d] K [4b] 2 [32]
avrdude: stk500v2_getsync(): found AVRISP mkII programmer
Using p = 8.00 us for SCK (param = 6)
avrdude: Sent: . [03] . [98]
avrdude: Recv: . [03] . [00] . [06]
avrdude: Skipping parameter write; parameter value already set.
AVR Part : ATmega168
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages
MinW MaxW ReadBack
eeprom 65 20 4 0 no 512 4 0
3600 3600 0xff 0xff
Block Poll Page
Polled
MinW MaxW ReadBack
flash 65 6 128 0 yes 16384 128 128
4500 4500 0xff 0xff
Block Poll Page
Polled
MinW MaxW ReadBack
lfuse 0 0 0 0 no 1 0 0
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
hfuse 0 0 0 0 no 1 0 0
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
efuse 0 0 0 0 no 1 0 0
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
lock 0 0 0 0 no 1 0 0
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
calibration 0 0 0 0 no 1 0 0
0 0 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
signature 0 0 0 0 no 3 0 0
0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP mkII
Programmer Model: AVRISP mkII
avrdude: Sent: . [03] . [90]
avrdude: Recv: . [03] . [00] . [01]
avrdude: Sent: . [03] . [91]
avrdude: Sent: . [03] . [92]
avrdude: Recv: . [03] . [00] . [0c]
Hardware Version: 1
Firmware Version Master : 1.12
avrdude: Sent: . [03] . [94]
avrdude: Recv: . [03] . [00] [20]
Vtarget : 3.2 V
SCK period : 8.00 us
avrdude: Sent: . [10] . [c8] d [64] . [19] [20] . [00] S [53] . [03] .
[ac] S [53] . [00] . [00]
avrdude: Recv: . [10] . [c0]
avrdude: stk500v2_command(): command failed
avrdude: Sent: . [03] . [a1]
avrdude: Recv: . [03] . [00] ' [27]
avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status:
MOSI fail, RST fail, SCK fail, Target reverse inserted
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: Sent: . [11] . [01] . [01]
avrdude: Recv: . [11] . [00]
avrdude done. Thank you.
-vvvv
file, skipping
Using Port : usb
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
MinW MaxW ReadBack
3600 3600 0xff 0xff
Block Poll Page
Polled
MinW MaxW ReadBack
4500 4500 0xff 0xff
Block Poll Page
Polled
MinW MaxW ReadBack
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
0 0 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
0 0 0x00 0x00
Hardware Version: 1
Vtarget : 3.2 V
avrdude: Recv: . [03] . [00] . [00]
Unknown status 0x00
this check.
und hier das vom dragon
tecdroid@tecdroid:~$ avrdude -p m168 -c dragon_isp -P usb -i7 -B5 -b1200
-vvvv
file, skipping
Using Port : usb
Using Programmer : dragon_isp
avrdude: stk500v2_dragon_isp_open()
avrdude: usbdev_open(): Found AVRDRAGON, serno: 00A200007679
avrdude: jtagmkII_getsync()
avrdude: jtagmkII_getsync(): Sending sign-on command:
avrdude: jtagmkII_send(): sending 1 bytes
avrdude: Sent: . [1b] . [00] . [00] . [01] . [00] . [00] . [00] . [0e] .
[01] . [f3] . [97]
avrdude: jtagmkII_recv():
avrdude: jtagmkII_recv(): Got message seqno 0 (command_sequence == 0)
avrdude: Recv: . [86] . [01] . [ff] . [0b] . [06] . [01] . [ff] . [0b] .
[06] . [07] . [00] . [a2] . [00] . [00] v [76] y [79] A [41] V [56] R
[52] D [44] R [52] A [41] G [47] O [4f] N [4e] . [00]
Raw message:
0x86 0x01 0xff 0x0b 0x06 0x01 0xff 0x0b 0x06 0x07 0x00 0xa2 0x00 0x00
0x76 0x79
0x41 0x56 0x52 0x44 0x52 0x41 0x47 0x4f 0x4e 0x00
Sign-on succeeded
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
boot-loader FW version: 255
firmware version: 6.11
hardware version: 1
S_MCU:
hardware version: 7
Serial number: 00:a2:00:00:76:79
Device ID: AVRDRAGON
avrdude: jtagmkII_setparm()
avrdude: jtagmkII_setparm(): Sending set parameter command (parm 0x03, 1
bytes):
avrdude: jtagmkII_send(): sending 3 bytes
avrdude: Sent: . [1b] . [01] . [00] . [03] . [00] . [00] . [00] . [0e] .
[02] . [03] . [03] . [89] f [66]
avrdude: jtagmkII_recv(): Got message seqno 1 (command_sequence == 1)
avrdude: Recv: . [80]
Raw message:
0x80
OK
avrdude: jtagmkII_getsync(): Sending get sync command:
avrdude: Sent: . [1b] . [02] . [00] . [01] . [00] . [00] . [00] . [0e] .
[0f] . [e2] u [75]
avrdude: jtagmkII_recv(): Got message seqno 2 (command_sequence == 2)
Raw message:
0x80
OK
avrdude: jtagmkII_send(): sending 5 bytes
avrdude: Sent: . [1b] . [03] . [00] . [05] . [00] . [00] . [00] . [0e] /
[2f] . [03] . [00] . [03] . [98] . [a5] v [76]
avrdude: jtagmkII_recv(): Got message seqno 3 (command_sequence == 3)
avrdude: Recv: . [88] . [03] . [00] . [06]
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
MinW MaxW ReadBack
3600 3600 0xff 0xff
Block Poll Page
Polled
MinW MaxW ReadBack
4500 4500 0xff 0xff
Block Poll Page
Polled
MinW MaxW ReadBack
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
4500 4500 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
0 0 0x00 0x00
Block Poll Page
Polled
MinW MaxW ReadBack
0 0 0x00 0x00
Programmer Type : DRAGON_ISP
Description : Atmel AVR Dragon in ISP mode
avrdude: jtagmkII_getparm()
avrdude: jtagmkII_getparm(): Sending get parameter command (parm 0x06):
avrdude: jtagmkII_send(): sending 2 bytes
avrdude: Sent: . [1b] . [04] . [00] . [02] . [00] . [00] . [00] . [0e] .
[03] . [06] . [8e] . [04]
avrdude: jtagmkII_recv(): Got message seqno 4 (command_sequence == 4)
avrdude: Recv: . [81] * [2a] . [0c]
Raw message:
0x81 0x2a 0x0c
parameter values:
0x2a 0x0c
Vtarget : 3.1 V
avrdude: Sent: . [1b] . [05] . [00] . [05] . [00] . [00] . [00] . [0e] /
[2f] . [03] . [00] . [03] . [98] h [68] q [71]
avrdude: jtagmkII_recv(): Got message seqno 5 (command_sequence == 5)
avrdude: jtagmkII_send(): sending 15 bytes
avrdude: Sent: . [1b] . [06] . [00] . [0f] . [00] . [00] . [00] . [0e] /
[2f] . [02] . [00] . [10] . [c8] d [64] . [19] [20] . [00] S [53] .
[03] . [ac] S [53] . [00] . [00] . [8a] . [d6]
avrdude: jtagmkII_recv(): Got message seqno 6 (command_sequence == 6)
avrdude: Recv: . [88] . [10] . [c0]
this check.
avrdude: jtagmkII_send(): sending 6 bytes
avrdude: Sent: . [1b] . [07] . [00] . [06] . [00] . [00] . [00] . [0e] /
[2f] . [02] . [00] . [11] . [01] . [01] s [73] . [fe]
avrdude: jtagmkII_recv(): Got message seqno 7 (command_sequence == 7)
avrdude: Recv: . [88] . [11] . [00]
avrdude: stk500v2_jtagmkII_close()
avrdude: jtagmkII_close()
avrdude: jtagmkII_close(): Sending sign-off command:
avrdude: Sent: . [1b] . [08] . [00] . [01] . [00] . [00] . [00] . [0e] .
[00] . [c6] . [ab]
avrdude: jtagmkII_recv(): Got message seqno 8 (command_sequence == 8)
Raw message:
0x80
OK
Wie man sieht hab ich den Vorgang schon extrem ausgebremst und dennoch
kommts nicht klar.. Hat wer eine Idee?
Das Problem war direkt unter meiner Nase.. oder eher dahinter.. also zwischen meinen Ohren.. Ich Trottel habe MISO und MOSI auf einem Zwischenadapter vertauscht.. Das klärt zumindest 2 der 3 boards.. Board 3 muss ich mal noch verifizieren was da kaputt ist..
